First oil change, mid size ranger
This is a discussion on First oil change, mid size ranger within the Mid-Size Rangers forums, part of the Polaris Ranger Forums category; OK, it's broken in (not broken, thank God). Time to change the oil on the 2011 500 efi. It looks like to me that I ...
Results 1 to 10 of 20
Thread: First oil change, mid size ranger
    (Charles) Regular Member rangermac's Avatar
    Jan 2011
    Southeast Kentucky
    OK, it's broken in (not broken, thank God). Time to change the oil on the 2011 500 efi. It looks like to me that I have to remove the main skid plate. Has anyone done this without having to do that? Thanks in advance for any info, suggestions etc.
    (douglas) Veteran Member doug63's Avatar
    United States
    don't forget that most of the oil is drained from the dry sump next to the battery. a slight amount from the crankase. follow the manual. doug
    Jan 2011
    Southeast Kentucky
    Doug, thanks for the reply. But that's what I'm doing, just following the manual. In order to get the rest of the oil out of the sump it looks like I have to take the skid plate off. That's what I was asking. Do I, or is there a trick?
    United States
    don't know. have not done it yet. i only have 13 hours on mine. doug
    United States
    I just read the owner's manual and it states that the drain in on the right lower area of the ENGINE crankase. Holds about a cup (8oz)you might be able to reach it to the left of the gas tank. doug
    Jan 2011
    Southeast Kentucky
    Well, yeah. I'd already checked to see where the drain is. That's why I made the post. I don't see any way to get to it without taking the skid plate off. Just thought there might be a way. I don't know why Polaris didn't put a hole in the plate under the drain plug, and an easier way to get to the plug itself. Oh well . . . .
    (The+Fallen) Veteran Member camoranger400's Avatar
    Oct 2010
    United states of America
    I used a socket wrench a long extension and a socket universal to get the right angle. there wasn't much oil in there so I just placed some shop towels under the drain to catch the oil.
    Jan 2011
    Southeast Kentucky
    Thanks a lot. A universal joint socket makes sense. I hadn't thought of that. And if a towel will take care of the oil, then that's the way I'll go. Thanks again.
    (lovenit) Regular Member lovenit's Avatar
    utah
    For the small amount of oil that comes out of the crank case I don't think it's worth the trouble to get the drain plug out.I had no more than 2 teaspoons of oil.I will not remove the drain plug next time.
    2010 Ranger 400
    1998 Polaris Magnum 450
    1996 Polaris Sportsman 500
    All ATV's still being used.
    687 times
    Quote Originally Posted by lovenit
    I would remove the drain plug just to see if there are any metal shavings on it, if for no other reason. JMO
changing oil in polaris 800 midsize youtube
changing oil in polaris ranger 500
how to change oil on polaris ranger 800 midsize
how to change the oil in a polaris ranger 500 efi midsize crew
how to remove a 2013 polaris ranger 500 efi skid plate
oil change 2011 polaris ranger 500
polaris ranger 400 motor dry sump
polaris ranger 800 midsize oil change
polaris ranger ext oil change
when to change oil in polaris ranger 800 midsize
