Winch wiring
Winch wiring
This is a discussion on Winch wiring within the Mid-Size Rangers forums, part of the Polaris Ranger Forums category; Hi, I am new to the group, my first post. I just got my new Ranger 400, camo, 2011. The dealer told me that it ...
Results 1 to 10 of 16
Thread: Winch wiring
    (ejh) Starting Member ejkkj's Avatar
    Mar 2011
    MD
    Winch wiring
    Hi, I am new to the group, my first post. I just got my new Ranger 400, camo, 2011. The dealer told me that it was pre-wired for a winch but i did some checking and did not see any pre-wiring. Anyone know if it is pre-wired, if so where it might it be? thanks..
    Ranger 400 camo 2011
    (GARY) Starting Member MN400's Avatar
    Dec 2010
    REDWOOD FALLS, MN
    Keyed hot terminal under hood on terminal strip ( top stud) and pick up ground anywhere. Welcome to the forum!!!!!!!!!!!!!!!!!
    2012 RZR570
    2010 RANGER 400 (TRADED)
    2009 RZR170
    (Jason) Veteran Member hoojs12840's Avatar
    May 2010
    Sharpsburg,MD
    If you need anymore help let me know. I did mine a few months ago.
    Where in MD do you live?
    The difference between genius and stupidity is genius knows it's limitations.
    Mar 2011
    MD
    Thanks for the help, I live in Woodbine.
    I saw the terminal strip under the hood but did not think it would work for a winch. But I will try it. I need to buy a mount for a warn winch, I have the winch already, plus I would like to put a receiver hitch on the front too, any suggestions on mounts would be appreciated. thanks again
    May 2010
    Sharpsburg,MD
    You really can't mount a hitch and a winch mount on the front.They use the same space.
    You can mount the hitch and get a winch mount that can go on the front or rear.
    (Kris) 1000+ Member revrnd's Avatar
    Feb 2011
    Apsley, Ontario
    98 times
    Quote Originally Posted by hoojs12840
    That's what I'm planning on doing. EMP has a winch mount kit w/ receiver (use multi mount) for the mid-size:
    http://www.extrememetalproducts.com/...b5b80b90ea1ed5
    2011 Ranger 500EFI
    Aftermarket stuff:
    ITP Baja Cross tires
    RAM GPS mount
    EQUUS water temp' gauge
    EQUUS voltmeter
    EMP front hitch receiver mount
    WARN RT40 winch
    DDM Tuning 55W HID headlights
    Ironton 18W LED driving lights
    LED backup light
    Kolpin side mirrors
    Homemade stuff:
    roof
    backglass
    rear bumper
    under seat & hood mud guards
    winch multi mount
    half doors
    half windshield
    checkerplate floorboards
    Mar 2011
    MD
    Would it be possible to use this mount for the winch
    EMP Winch Mount Kit for Polaris Ranger 400 and 500 (small body
    And this mount for the receiver:
    '09 + Polaris Ranger Front Bottom Mount 2" Receiver (Except 09' Crew)
    Part # K100810
    At: http://www.utvpartsandaccessories.co..._mounts.htm#20 Winch Connection Wiring Harness
    Or do they interfere with each other?
    Feb 2011
    Apsley, Ontario
    98 times
    Connector Question
    The multi mount wiring kits have connectors to plug the winch power leads into @ the front & rear of the Ranger. I've seen a pic where the owner mounted the rear connector, but unsure about the front. Do I mount the connector under the hood out of the elements (but you have to open the hood to access it) or attach it to the front bumper or grille?
    Suggestions are welcome.
    2011 Ranger 500EFI
    Aftermarket stuff:
    RAM GPS mount
    EQUUS voltmeter
    WARN RT40 winch
    LED backup light
    Kolpin side mirrors
    Homemade stuff:
    roof
    backglass
    rear bumper
    winch multi mount
    half doors
    half windshield
    (Jake) Regular Member ratmanz13's Avatar
    Oct 2010
    Western New York
    My winch has a rather large solenoid that bumps the power to 200amps which I mounted to a plate I installed near the battery box. I then ran my cable harness under the floor panel along the OEM wiring harness and ultimately to the winch.. So you're wiring will depend on what kind of winch you get.
    (K-man) 1000+ Member Kaveman's Avatar
    Apr 2008
    Alaska
    Quote Originally Posted by ratmanz13
    Just a piece of information to avoid any confusion.... Solenoids don't have the ability to bump power. The 200 amp rating simply means that the internal contacts are sufficient to handle a 200 amp load. A solenoid just makes and breaks a circuit and is basically an electrically operated switch.
    So easy, even a Kaveman can do it!...
2011 polaris ranger 800 winch wiring
do i need a winch mount for my polaris ranger 400
install winch solenoid connector on a 2008 polaris ranger crew
installsuper whinch on 400 polaris ranger
polaris ranger winch install
polaris ranger winch wiring video
polaris solenoid hitch wiring
ranger 400 winch install
winch solenoid ranger crew
wiring a winch on a polaris ranger 400
