2011 ranger crew 500efi will not run!
This is a discussion on 2011 ranger crew 500efi will not run! within the Mid-Size Rangers forums, part of the Polaris Ranger Forums category; Do we have any Polaris mechanics here? It will start and run but it feels like it is stalling out when you it the gas... ...
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 65
Thread: 2011 ranger crew 500efi will not run!
    (kevin) Veteran Member Mudillac's Avatar
    Jan 2011
    Marion, Arkansas
    Do we have any Polaris mechanics here? It will start and run but it feels like it is stalling out when you it the gas... It acts like it is running out of gas. If you start up a hill or down a hill it stalls completely out and dies. Then it takes a while to start it. It doesn't just do it only on hills it does it on level ground too. It also sounds like it is backfiring inside the airbox. Even when it's running it doesn't have the power that it is spose to have... It's very sluggish. It acts like it's flooding out or running out of gas. Nothing is flashing on the gauge cluster... No check engine light on. I did get some water in the airbox the last time I rode it... The water did make it into the oil but it wasn't alot. I've drained the oil many times.... Cleaned the air box and filter. Please help!
    11 Ranger 500 crew
    snorkeled
    2 inch lift
    2 inch forward A-arms
    UNI
    28inch radial outlaws
    (Duane) Elite Member etuke's Avatar
    Mar 2011
    NL
    7 times
    did water get into the fuel tank?
    2013 800 Midsize LE
    Half Windshield
    Diamondplate roof
    2" Lift kit
    LED Reverse lights
    Driving Lights
    Polaris Bumper
    Viper 5000lb Winch
    Eagle Plow
    Jan 2011
    Marion, Arkansas
    I don't think so... I didnt run it in deep water... I splash some water into the air intake tube on the front of the bike and got sucked into the air box. I'm going to try some heat or alcohol or something in the gas to see if that will clean it up.
    11 Ranger 500 crew
    snorkeled
    2 inch lift
    UNI
    (john) Elite Member jokout's Avatar
    iowa
    40 times
    I may also be tempted to siphon/drain as much of the gas in the tank as posible to give the feul treatment a better chance to succeed...while it may sound off the wall, you could also replace the plug, seems like we have had a lot of sparkplug issues lately!
    Cheers!
    2014 RANGER 570 EFI
    Polaris steel cab doors and rear panel
    split folding windshield
    custom roof w/overhead console
    Sony Bluetooth audio system
    Maxxis Bighorn 2.0s
    ITP SS212 wheels
    4500# Viper Max winch
    40" LED light bar and LED work light
    66" American Eagle Snowplow
    Destroyed by fire
    2011 Ranger 400 HO w/2" lift & Rhino axles
    Polaris roof, two-piece folding windshield, back panel, 1/2 windshield, custom box rack, custom snorkle system, RZR bucket seats, custom center console, Viper Max 4500# winch, relocated deep cycle battery, LED cab lite, Pioneer stereo, ITP 212 rims and Swamplite tires, clutch spacer mod, Blazer Flood lites, 66" American Eagle snowplow
    (Jason) Veteran Member hoojs12840's Avatar
    May 2010
    Sharpsburg,MD
    I filled my intake tube from hitting water to fast and it went in under the hood also on my Ranger 400. It's a carb, but it would not run at all.
    When I took the air filter out it ran fine. WHen i pput it back on it wouldn't. Come to find out there was water in the intake tube. Since it is so long and lays flat we had to stand the Ranger up on the rear bumper vertically and let it drain, then it ran fine.
    Did you take the prefilter out from under the hood at the intake tube opening?
    I think the shape of the hood forces water to roll over top and into the back of the intake tube.
    The difference between genius and stupidity is genius knows it's limitations.
    Jan 2011
    Marion, Arkansas
    I disconnected all that and built a snorkel set up for it. But that is how the original problem started... All that water was in that tube and when I started up a hill all of it ran into my air box and into the motor. Now it is still acting like water is in it.. It keeps stalling out... It will run for a few mins the act like it's running out of gas.
    11 Ranger 500 crew
    snorkeled
    2 inch lift
    UNI
    Jan 2011
    Marion, Arkansas
    I may go ahead and get a new plug and air filter to see if that helps.
    11 Ranger 500 crew
    snorkeled
    2 inch lift
    UNI
    (Jeff) Starting Member pizzaguy's Avatar
    Oct 2010
    United States
    Before you do anything else, go get a new sparkplug. It sounds exactly like what mine did and I remembered reading advice from someone else on this forum a while back and changed the plug. Problem solved!!!
    Jan 2011
    Marion, Arkansas
    Ok.... How was yours acting?
    11 Ranger 500 crew
    snorkeled
    2 inch lift
    UNI
    Oct 2010
    United States
    Wife was using it doing yard work in the morning and it was running fine. She started it about noon and it would cough,spit ,sputter, and fart. It had no power and would backfire. Told her to shut it off 'til fixed. A $2.45 plug was a cheap fix. I now have 2 spares at home.
08 ranger 800 dies when hit gas
2011 polaris ranger 500 crew sucked in water
2011 polaris ranger 500 efi out of time
2011 polaris ranger crew 500 clutch going out second time whats wrong
polaris 500 efi not getting fuel
polaris mud stopper
polaris ranger 500 efi will not start
polaris ranger mud blockers
