Change transmission oil mid size 500 efi
This is a discussion on Change transmission oil mid size 500 efi within the Mid-Size Rangers forums, part of the Polaris Ranger Forums category; Question: Is the Owner's Manual wrong about the fill plug and drain plug on the 2011 500efi? The manual drawing shows the fill plug and ...
Results 1 to 6 of 6
Thread: Change transmission oil mid size 500 efi
    (Charles) Regular Member rangermac's Avatar
    Jan 2011
    Southeast Kentucky
    Question:
    Is the Owner's Manual wrong about the fill plug and drain plug on the 2011 500efi? The manual drawing shows the fill plug and drain plug on the same side of the transmission gear case. A visual inspection, however, seems to show the drain plug on the right (passenger) side of the engine, but no fill plug. The fill plug is on the left (driver's) side of the gearcase unless I'm looking at something else.
    Also it appears that the skid plate absolutely has to come off to get to the drain plug. Comments? Any help would be appreciated.
    (douglas) Veteran Member doug63's Avatar
    United States
    the service manual shows the fill on the left side (driver's) it looks like an allen bolt. the drain is on the right side (passenger) it is the lowest bolt that attaches the front driveshaft. it looks like an allen bolt too. doug
    Jan 2011
    Southeast Kentucky
    Quote Originally Posted by doug63
    Thanks, Doug. I hope the guys who wrote the Service Manual are not the same ones who did the Owner's Manual. I've probably a dozen or more mistakes in it, some serious. WTF?
    United States
    I have found lots of mistakes in both. I figured it was translated from chinese. doug
    (Kris) 1000+ Member revrnd's Avatar
    Feb 2011
    Apsley, Ontario
    60 times
    Re: Change transmission oil mid size 500 efi
    Quote Originally Posted by rangermac
    Question:
    Yes you're right about the diagram being wrong (I found out last week). Do you mean the engine oil drain plug requiring the skidplate removal? I don't think it's necessary to remove it to drain the tranny.
    2011 Ranger 500EFI
    Aftermarket stuff:
    ITP Baja Cross tires
    RAM GPS mount
    EQUUS water temp' gauge
    EQUUS voltmeter
    EMP front hitch receiver mount
    WARN RT40 winch
    DDM Tuning 55W HID headlights
    Ironton 18W LED driving lights
    LED backup light
    Kolpin side mirrors
    Homemade stuff:
    roof
    backglass
    rear bumper
    under seat & hood mud guards
    winch multi mount
    half doors
    half windshield
    checkerplate floorboards
    Feb 2011
    Apsley, Ontario
    60 times
    (Taken from another thread)
    I just got the 2011 Mid-size Service Manual. I see Page 7.19 contradicts page 7.2 as to the correct torque for the wheel nuts used with the alum' rims.
    Any other mistakes, could you list them here? That way others can update their manuals.
    2011 Ranger 500EFI
    Aftermarket stuff:
    RAM GPS mount
    EQUUS voltmeter
    WARN RT40 winch
    LED backup light
    Kolpin side mirrors
    Homemade stuff:
    roof
    backglass
    rear bumper
    winch multi mount
    half doors
    half windshield
2011 polaris ranger 500 efi change differential fluid
2011 polaris ranger 500 transmission drain plug
2013 polaris ranger 500 efi oil change
how to gear case fluid in a 2013 polaris ranger mid size 500 efi
how to gear oil in a 2013 polaris ranger mid size 500 efi
polaris ranger 500 gear oil side by side
polaris ranger 500 transmission fluid
polaris ranger 500 transmission oil
were is drain plug on polaris ranger transmission
where to put the tranmission oil in a polasir ranger 500efi
