First oil change
First oil change
This is a discussion on First oil change within the Mid-Size Rangers forums, part of the Polaris Ranger Forums category; So just got done with first oil change on 2011 500 efi at 10 hrs per dealer recomendation. Followed owners manual...kind of sorry I did ...
Results 1 to 10 of 14
Thread: First oil change
    (Noal) Starting Member backwoods11's Avatar
    Midland, MI
    First oil change
    So just got done with first oil change on 2011 500 efi at 10 hrs per dealer recomendation. Followed owners manual...kind of sorry I did the oil line drain and prime. I clamped and idled acording to the owners manual, but never heard the air rushing like the owner manual said so now I'm worried. Anybody have the same issue?
    (Jon) Regular Member saiersj's Avatar
    Larimore ND
    I had the same problem when I primed my 400 but it was a self-inflicted wound. I didn't shut the motor down after 10-20 seconds and to make matters worse I did it twice before I figured it out! :(
    Jon
    2010 Ranger 400
    (douglas) Veteran Member doug63's Avatar
    United States
    You guys are scaring me. how exactly do you prime correctly? I am due for my first oil change and I don't want to mess up. doug
    Midland, MI
    Jon,
    The manual is terrible as it doesn't really say if you should shut the motor down or leave it running when you take off the clamp. So are you saying that you 1)clamp, 2)run the motor 10-20 sec 3) shut it off 4) release the clamp and you hear the air rush?
    (Duane) Elite Member etuke's Avatar
    Mar 2011
    NL
    8 times
    did mine and got it right first try,not that hard.clamp the hose before the cut ,start the engine for 20 secs ,shut off then release clamp.Even drained the base of the engine that some said was very difficult but wasn't too bad at all.Don't be affraid to try thats 90% of the battle.
    2013 800 Midsize LE
    Half Windshield
    Diamondplate roof
    2" Lift kit
    LED Reverse lights
    Driving Lights
    Polaris Bumper
    Viper 5000lb Winch
    Eagle Plow
    (Don) Regular Member Librarian's Avatar
    Aug 2005
    New Vienna Ohio
    My dealer has been in business for two decades. He says cleaning the screen and priming is unnecessary. I believe him.
    Aug 2005
    New Vienna Ohio
    Larimore ND
    That is correct Noal and you are right the manual does not specially say to shut the engine down apparently it's implied.
    Jon
    2010 Ranger 400
    (john) Elite Member jokout's Avatar
    iowa
    92 times
    not a bad idea to do the complete change the first time around to make sure you get any stray metal filings from the break-in period and manufacturing! Subsequent changes often are a bit more abreviated. Many don't drain the engine crankcase every time and many don't clean the return filter screen. Personally, I do the screen every spring, more to clean out the moisture, (milk), accumilated from winter use more then anything else, and pull the plug wire and crank the engine to pump the remaining pint or so of remaining dirty oil from the crankcase. Not everyones cup of tea but it has worked well for me for years on all of my Polaris ATVs and now the Ranger
    Cheers
    2014 RANGER 570 EFI
    Polaris steel cab doors and rear panel
    split folding windshield
    RZR 900 Bucket Seats
    Custom center console
    custom roof w/overhead console
    Sony Bluetooth audio system
    Maxxis Bighorn 2.0s
    ITP SS212 wheels
    Dirty Dawg Performance clutch kit
    4500# Viper Max winch
    Relocated 850 CCA Marine Battery
    40" LED light bar and LED work light
    66" American Eagle Snowplow
    Destroyed by fire
    2011 Ranger 400 HO w/2" lift & Rhino axles
    Polaris roof, two-piece folding windshield, back panel, 1/2 windshield, custom box rack, custom snorkle system, RZR bucket seats, custom center console, Viper Max 4500# winch, relocated deep cycle battery, LED cab lite, Pioneer stereo, ITP 212 rims and Swamplite tires, clutch spacer mod, Blazer Flood lites, 66" American Eagle snowplow
    Midland, MI
    Thanks for all the info. So this is what I did. I never could confirm I primed the pump corectly, fortunatley I drained the crankcase when I did the initial oil change. All I did was open the crankcase bolt to ensure oil made it from the resevoir (i.e, oil came out). Confirmed my logic with the local Polaris shop and they agreed.
first oil change on my polaris crew 900 consist of
how do you change the oil on a ranger 800 midsize
how to change oil in apolaris ranger 800 midsize
how to change oil on 2013 ranger 800 midsize
how to change oil on a midsize polaris 800
how to change oil polaris ranger 800 midsize
how too change oil in a 2011 400 polaris utv ranger
polaris ranger 900 first oil change
polaris ranger first oil change
when do ranger 500 first oil change
