Front driveshaft removal
This is a discussion on Front driveshaft removal within the Mid-Size Rangers forums, part of the Polaris Ranger Forums category; I have a leaking pinion seal and I have removed the roll pin, which was pretty tuff, but I cant figure out how to get ...
Results 1 to 5 of 5
Thread: Front driveshaft removal
    (Randy) Regular Member ranikyke's Avatar
    Louisiana
    I have a leaking pinion seal and I have removed the roll pin, which was pretty tuff, but I cant figure out how to get the shaft out. I unbolted the gearcase to move it forward, but can't seem to get it. Do I have to remove axles and all or is there something simple I can do that I'm not thinking of? Thanks
    687 times
    To keep from removing the tranny, I had to remove the fan to be able to move the diff' far enough forward to get the driveshaft off.
    687 times
    Oh yeah.......replace that crappy roll pin with a 5/16" x 2" fine thread bolt and use plenty of anti-seize when installing. You'll thank me if you ever have to remove it again.
    Louisiana
    Got it, Thanks for the help
    (Daniel) Regular Member bookumdanno's Avatar
    West Virginia
    22 times
    Not sure what model you have buy the service manual for the 2010-2011 400/500 says to remove pin and slide shaft into transmission and sharply pull toward diff. to remove from transmission. Then pull towards right frame ans slide out back right side. I haven't had to perform this yet, only have 8.6 hours on mine.
    2011 Ranger 500 efi
    DIY: Wood Roof, Under seat mudguards, Rear view Mirror
    Venom 5000lb Winch EMP Full Windshield, ITP Mudlite XL's
    25X8-12 Front, 25X12-12 Rear
    37' Terry Quantum 5th wheel
    1959 IH Farmall Loboy
how to remove front drive shaft on polaris ranger
how to remove front drive shaft polaris ranger
how to remove front driveshaft on polaris ranger
how to replace front drive shaft seal polaris ranger
midsize polaris ranger front drive line removal
polaris ranger drive shaft removal
polaris ranger front drive shaft removal
polaris ranger remove front prop shaft
prop shaft roll pin replacement with bolt on 2012 ranger 800 xp
remove front gearcase polaris ranger
