1) Looking for the item number for a K/N for a 570?
2) How much better are the K/N's working over stock or other after market filters on the 570? I know in the past I have ran K/N's on other atvs and got good results just wanted to ask and make sure there isnt anything better for the 570..??... thanks!
You're going to get quite a few mixed opinions on this one...I for one enjoy the performance gains of a K&N Air Filter BUT I (personally) don't believe they are the best suited air filter for off-road purposes (ie. extremely dusty conditions). K&N Air Filters are made up of a cotton-gauze material and when compared to an OEM paper air filter, it's really easy to understand how the K&N can increase performance; they simply allow more air to enter the motor. However, over years of researching and conducting tests I've come to believe that this isn't necessarily a good thing in all cases. In order for the K&N Filter to allow more air into the motor, the filtration element has to be less restrictive than the one it's replacing. Obviously, cotton-gauze is going to allow more air to pass threw it than a solid piece of paper but this isn't a perfect world, so you must take into consideration that you're not only letting more air in, you're also letting more debris pass by the filter element. This is ultimately why we oil our K&N Air Filters. The oil helps to trap larger deposits and debris within the filter material in order to keep it from entering the motor. BUT the oil can not stop all debris SO, eye's point back to the filtration element...the cotton-gauze. By utilizing a slightly more restrictive material for filtering the air that enters your motor you can better safeguard it against these smaller deposits. It's this reason why I prefer to use a 2-Stage Foam Filter (Uni or TwinAir). I have been using these style air filters for off-road use for years and I can safely say that the performance difference between foam and cotton-gauze is very minimal AND I feel more confident that my air filter is safe guarding my engine from harmful dirt and debris.
I have run Uni-Filters for years on my off road bikes. The oiled multi layer foam design seems to do a better job w/ the dirt and dust. I have always used their oil as well and it is extremly tacky which seems to attract and capture the dust and dirt.
Get on parts site and see if the filtesr cross over to each other..by thsi i mean see if factory filters will interchange. If they do, then yes, the uni-fitler will work! Glad ya changed mind on getting an uni instead!! K&N aint no good in most of our opinions when it comes to dirt life!
The sock (in personal opinion) was K&N's way of putting a band-aid over their filters in hopes to regain some of the off-road riders interests. That being said, the pre-filters (or socks) are obviously effective in minimizing the amount of debris and/or deposits that can enter your engine but they're not meant to be oiled so other than restricting flow, I don't see this as an acceptable solution to the original problem...
I put the k&n pre filter over my stock filter to catch the big stuff.
49.4K members
