2017 Polaris Ranger Crew 1000- LET THE MODS BEGIN! - Page 11
This is a discussion on 2017 Polaris Ranger Crew 1000- LET THE MODS BEGIN! within the Ranger Crew Discussions forums, part of the Polaris Ranger Forums category; A Duraclutch can't compensates for larger tires. It does not change final drive ratio. It provides a great mechanism to avoid belt slippage using a ...
Page 11 of 11 FirstFirst ... 91011
Results 101 to 110 of 110
Like Tree68Likes
Thread: 2017 Polaris Ranger Crew 1000- LET THE MODS BEGIN!
  1. #101
    1322 times
    A Duraclutch can't compensates for larger tires. It does not change final drive ratio. It provides a great mechanism to avoid belt slippage using a a seperate friction coupler. The friction coupler slips before the belt. As a side benefit, it takes off smoother. But the braking is too strong for some.
    Your oversized tires still need to be addressed even with a Duraclutch. Quote from the website of the manufacturer of Duraclutch, "No clutch/CVT can compensate for larger tires without compromising overall ratio. For large tires we recommend changing the drive train gearing to recover the overall CVT ratio." The Duraclutch is also quite expensive. For 1/4 the price (and some labor) you can actually fix the large tire problem with proper gearing.
  2. #102
    1057 times
    Tesh is absolutely correct.
    Cause and Effect!
    For every 1" of increase in tire size you loose apprx 3.5% of the units original designed torque.
    There are more things that go along with this, but I will not get into that.
    So going from your original 26" tires to let's say 34", you have lost apprx 28% of your original torque. This makes it harder on the drivetrain. This will result in sluggish acceleration, and less torque to move over obstacles.
    So you will need to offset this with lower gearing.
    You can drive it this way, but it may not live long.
    fswan and Freddy P like this.
    Toxic-21 Products.
  3. #103
    apw
    apw is offline
    (Aaron) Regular Member apw's Avatar
    Apr 2012
    South Texas
    Thanks for the info guys! I'm waiting on quotes from a couple of dealers here in south tx.
    2012 Ranger 400 SOLD
    2017 Ranger 1000 Crew Nara Bronze
    6" SATV wicked 6 lift
    32" Kanati Mongrels on MSA Kore rims
    more to come....
    (david) Veteran Member davery74's Avatar
    Mar 2011
    dripping springs, texas
    68 times
Size:  1.35 MBName:  image.jpeg
Size:  1.47 MBName:  image.jpeg
    8 Rock lights installed...I ordered two more and she should be complete.
    LockeLamora33 likes this.
  6. #105
    Mar 2011
    68 times
    Well my 9 yr old daughter has jumped on the Polaris bandwagon! She loves her Christmas present!
    teshreve, fswan and rorgan like this.
  7. #106
    1322 times
    That is so cool. Custom shoes too!
  8. #107
    Mar 2011
    68 times
    Dang right! Can't lose cool points ridin on stockers. Her doors went on today. I never had anything like this at 9.
  9. #108
    1322 times
    Nothing that cool even existed when I was 9
    You going to turbo that thang?
  10. #109
    Mar 2011
    68 times
    Turbo.....hmmmm...now that's an idea!
  11. #110
    apw
    apw is offline
    Apr 2012
    South Texas
    Quote Originally Posted by davery74 View Post
    Davery, which rock lights did you get? I've heard bad things about the cheaper offerings from overseas. I don't want to break the bank, but want something that's going to last.
    more to come....
2017 polaris ranger 1000 crew radio
2017 polaris ranger crew
gas milage
m25 rocker polaris ranger
night vision
polaris 1000 crew
polaris ranger 1000 modifications
polaris ranger crew 1000
ranger 1000 forum
