Ranger 900 Spark Plug Number?
This is a discussion on Ranger 900 Spark Plug Number? within the 2013 Model Polaris Rangers/RZRs forums, part of the The RANGER STATION ~ Rangers and RZRs category; I want a spare set of spark plugs for my Ranger. Does anyone know the spark plug number for the new Ranger 900? Thanks Thomas...
Thread: Ranger 900 Spark Plug Number?
    (Thomas) Veteran Member dogdoc's Avatar
    Jan 2009
    Georgia
    Thomas
    If the plugs are the same as the RZR 900 (and you should verify that because I don't have access to a Ranger 900 parts manual yet), the OEM plug is a Champion RG4YCX. I don't like Champion plugs, so when I did my first service, I upgraded to the NGK Iridium CR9EIX.
    Jan 2009
    Georgia
    Should I just go ahead and Change out the plugs and save the champion as spares? Hopefully someone will chime in who is lucky enough to already have a 900.
    Thomas
    2013 Ranger XP 900 Camo
    Tilt Out Windshield
    Steel Roof
    Glass Rear Panel
    Maxxis Bighorns
    Backwoods Armor Loaded
    09 Ranger XP "Sold"
    Quote Originally Posted by dogdoc
    Should I just go ahead and Change out the plugs and save the champion as spares?.......
    Chances are that you'll never have an issue with the Champion plugs. My dislike of them comes from racing 2-strokes years ago and nothing other than an NGK would last any length of time without fouling. I've just been an NGK kinda guy ever since
    Changing them definitely isn't going to HURT anything..........and if it were me, yes I would keep the Champions as the spares.
    Maybe somebody will chime in to confirm the plug number info'.
    (Shawn) Banned Daddy tried's Avatar
    Aug 2012
    Sorry I don't have the number to the plugs but I put 6 hrs on mine and they fouled out dealer fixed no questions asked
    Quote Originally Posted by Daddy tried
    It could have been something as simple as too much assembly lube left on the piston/cylinders during the assembly process. I'm guessing that the next set will not have that issue, but please keep us posted.
    On a separate but similar note........another member mentioned having his spark arrestor screen get stopped up on his XP4. So I checked mine and found the same after only about 30 hours of use. I cleaned it and felt a noticeable power increase afterward. I'm not sure if the Ranger 900 uses a similar screen, but it would be worth checking and keeping an eye on if it does. Again, I feel it could be contributed to some assembly lube getting spit out of the engine on it's first run, but that's purely speculation.
    (Eric) Veteran Member Newt's Avatar
    Jul 2010
    Olive Hill Ky
    I have always removed mine and trowed them on the self,and I allready took it out of the new ranger as well. I read on the rzr forum some where that it actuly gave the rzr like 1 horse power on the dino after removing it.Thats just what I read I dont know wheather it is true or not, but I just took them out any way, no one checks them in ky that Iam aware of.
    Jul 2010
    Olive Hill Ky
    I also changed my plugs as well I dont care for champions plugs either
    Z71
    Z71 is offline
    (Mike) Elite Member Z71's Avatar
    U.P. of Michigan
    46 times
    I been researching oil and filter info. I will leave it to you to make heads or tails of it.
    From page 76 of owners manual Ranger XP 900 -
    Spark Plug/Gap RG4YCX / 0.7-0.9 mm
    From Polaris web site parts guide
    Assemblies : 2013 RGR RANGER 900 XP ALL OPTIONS - R13UH88/UH9
    Usage : 3022462 Plug, Spark 2
    Year Product Model Assembly
    2013 RGR RANGER RZR XP 900 EFI ELECTRICAL, IGNITION - R13JT87AD/AL/EAL
    2013 RGR RANGER 900 XP ALL OPTIONS ELECTRICAL, IGNITION - R13UH88/UH9E ALL OPTIONS
    2013 RGR RZR 570 EFI ELECTRICAL, IGNITION - R13VH57AD/6EAK
    2013 RGR RANGER RZR XP 4 900 EFI (0 ELECTRICAL, IGNITION - R13XT87AA/9EAK
    2013 RGR RANGER RZR 4 XP 900 PS INTL ELECTRICAL, IGNITION - R13XT9EFX
    2012 RGR RANGER RZR XP 900 EFI ELECTRICAL, IGNITION - R12JT87AB/AD/AS/AW/9EAW
    2012 RGR RANGER RZR 570 EFI ELECTRICAL, IGNITION - R12VH57AD
    2012 RGR RANGER RZR 570 EFI INTL ELECTRICAL, IGNITION - R12VH57FX
    2012 RGR RANGER RZR 4 XP 900 ELECTRICAL, IGNITION - R12XT87AA/9EAS
    fyi - Oil filter has not changed but shows engine oil capacity as 2.5 qts. (in owners manual pdf copy)
    fyi - The 900 is 875 cc
    Mike
    2016 RZR 900 EPS Trail - Matte Turbo Silver
    Protected by AMSOIL Synthetic Lubricants
    Based on Mike's post, the plugs are the same as detailed in my original response. I don't own stock in NGK, but without a doubt I would pick those plugs over OEM. JMO
2013 polaris 900 xp spark plug num
2013 polaris ranger 900 spark plugs
2015 ranger 900 sparkplug ngk
2016 polaris ranger 900 xp spark plugs
2016 ranger xp 900 spark plugs
how to change spark plugs xp 900 raz 2013
polaris ranger 900xp spark plugs
polaris rzr 900 xp spark plug
what is the plug gap on a 2012 polaris rzr 900 xp
