Installing cab
Installing cab
This is a discussion on Installing cab within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; In the middle of putting the cab on. My window/wiper kit isn't in yet and I was wondering if I need to put the window ...
Results 1 to 5 of 5
Thread: Installing cab
    (Russ) Veteran Member RussB's Avatar
    Jan 2011
    B.C. Canada
    Installing cab
    In the middle of putting the cab on. My window/wiper kit isn't in yet and I was wondering if I need to put the window in before I put the roof on ? or can I go ahead and install the roof ?
    2013 900XP Org. Madness. Winch, Front & Rear brushgaurds, Prem. roof, Windshield with wiper, Interior Light, Doors, Poly back panel, LED's front and rear, Heater, Glazier Pro plow,
    2007 Browning Ed. 700XP Traded !
    (Chris) Regular Member cfe45's Avatar
    Fond du Lac, WI
    Remeber you got to run the lines for the washer fluid if you want that hooked up...
    Jan 2011
    B.C. Canada
    Yes.. thank you. I will leave the head liner out so I can run the wires and washer fluid tube to wiper.
    Jan 2011
    B.C. Canada
    put the roof on ! hope I can get the windsheild in without taking it back off. It was tough to get it to click in with the roof seal on it. doors and back window installed today as well.. Starting to look pretty good.
    Veteran Member radman's Avatar
    Apr 2006
    RussB
    If you have the tip out windshield, the windshield needs to go on first. The hinge at the top has a screw/tork head and the roof will interfere with getting to those screw heads.
