Have an audio system? Get in here! :) - Page 2
This is a discussion on Have an audio system? Get in here! :) within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; Rayford wanna sell the sound bar...
Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 108
Like Tree16Likes
Thread: Have an audio system? Get in here! :)
    Regular Member Etxmatt's Avatar
    Feb 2014
    (Raymond) Elite Member rayford118's Avatar
    Alexandria, LA
    already have once i get new roof installed. if he decides to back out ill let you know. letting it go for about half price.
    2013 Polaris Ranger 900 XP LE
    28" S/W Outlaw Radials on ITP SS 212s, 5000lb Viper Elite Winch,
    Audio Formz Roof, Dragon Fire Doors, Backwoods Armor Forward Arched A Arms,
    BA Arched Rear, BA Adjustable Lift, Front and Rear Brushguards,
    Poly Hard Windshield, Poly Rear Panel, SATV Bed Rack, Center Console
    2011 Polaris Ranger XP LE
    27X11X14 ITP Mudlite XTR on ITP SS 212s, 4500lb Polaris Winch
    J Strong Roof (lights and radio), Forward A-Arm
    Pre Runner Front and Rear Brushguards
    J Strong Windshield, Box Rack, Center Console
    Motoactiv Suicide Doors
    Feb 2014
    I sure would like it what is retail?
    (Dean) Elite Member slowroller's Avatar
    Aug 2012
    MS
    83 times
    Quote Originally Posted by slg1976 View Post
    Slow roller did you have any engine noise from your radio/amp set up? I'm getting a little noise on mine.
    No sir... Clear as it can be. Do you have a good ground, going to amplifier? Might check your ground. Also, lower quality speaker wire could be the cause. I did use a quality, tinned marine grade 12ga speaker wire. Do you have noise from the radio, without the amp? Could possibly be an issue with just the amp.
    Feb 2014
    (Dennis) Starting Member Earthling's Avatar
    Jan 2014
    Pilot Hill, CA
    Quote Originally Posted by rayford118 View Post
    You are the first person ive have ever heard say that the cab in the Ranger 900 is loud or are you talking about the 800.
    Neither. I have the 2004 TM which certainly is loud. I assumed, given the nature of the beast, that all models have their fair share of noise.
    - Dennis
    www.goldfinch-acres.com
    2004 Ranger TM
    Yamaha Kodiak ATV
    Kubota B21
    Jan 2014
    Pilot Hill, CA
    Quote Originally Posted by slowroller View Post
    Speaker connections are low impedance, won't pick up engine noise, regardless of quality.
    The noise may be ground-related. I would check any higher impedance wiring, like inputs, for proper grounding. Or the unit itself. Also try moving the ground reference, that is, the main ground connection to the amp closer to, or right to the battery terminal.
    - Dennis
    2004 Ranger TM
    Yamaha Kodiak ATV
    Kubota B21
    Alexandria, LA
    Quote Originally Posted by Etxmatt View Post
    retail is 650.
    installed the audio formz roof tonight and it is a great setup. well worth the money IMO. can really tell a difference with the upgraded speakers.
    (Sterling) Veteran Member Bamarider's Avatar
    Feb 2013
    Lower Alabama
    9 times
    installed the audio formz roof tonight and it is a great setup. well worth the money IMO. can really tell a difference with the upgraded speakers.[/QUOTE]
    What speakers did you go with?
    Aug 2012
    MS
    83 times
    Quote Originally Posted by Earthling View Post
    I'm no "audiophile" by any means, but I do know that speaker wires can pick up interference from a power source. Maybe not necessarily "engine" noise, but noise just the same. Especially lower quality wire that is less shielded. Higher quality wire is generally better shielded.
    Said that too...
    I've always been told by others far more knowledgeable than I, that the amplifier ground should be no further than 18" from the unit.... As close as possible, the better. But definitely, a bad ground is usually the culprit.
    Stephen, did you remove the coating from the frame, where you grounded the amp? I removed a spot with a small grinder, for a solid bare metal ground. Then painted over it, once ground. Anyways, hope you find it. I know that can be annoying.
audio
audio system
box cosmetic sound
overhead speakers for polaris ranger
polaris ranger sound systems
polaris ranger subwoofer enclosure
polaris ranger using winch
speaker under polaris ranger seat
ssv works 8 speaker ranger crew
stereo
