Will 31" tires fit? - Page 4
Will 31" tires fit?
This is a discussion on Will 31" tires fit? within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; Holy of all holes. Rides just fine....
Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: Will 31" tires fit?
  1. #31
    (Steve-o) Supporting Member Naylor649's Avatar
    Jul 2015
    Southern Illinois
    159 times
    Union Electrician
    2015 900 XP Sandstone Metallic
    Fixed Glass Windshield
    Lock & Ride Rear Glass
    Lock & Ride Sport Roof
    Polaris Radio
    Polaris Extreme Bumper
    Viper Elite 4000 winch
    12" Light bar
    3" Full Outkast lift
    14" MSA Vibe wheels
    30" Pro Armor Crawler XG
    Dragonfire Doors
    Garage Products Bushings
    Fueled by Busch Light
  2. #32
    983 times
    Entertain us and try the inside holes. It will ride a whole lot better. Promise! And you will get more traction over rough terrain under power (because the suspension will actually be working).
  3. #33
    Jul 2015
    Southern Illinois
    159 times
    Will 31" tires fit?
    Now if I go and do this. In hine sight it shouldn't mess with my alignment should it? Now I'm being serious. I was just told to move them to the outter because of rubbing issues but after you mentioned they are moved out AND up it doesn't do anything but moves the shock straight up and down I'm gathering to make stiffer but I never took it out of the stock stiffness. Good ole stiffy ness. And holy auto correct
    Union Electrician
    Polaris Radio
    12" Light bar
    14" MSA Vibe wheels
    Dragonfire Doors
  4. #34
    Elite Member TacomaJD's Avatar
    229 times
    No, unless you are moving wheel position front to back like with forward arms, or tinkering with tie rod adjustment, alignment will not be affected.
    2016 Polaris Ranger 570 XP F/S
    2.5" Marshall Motoart lift - rides as soft as stock
    SuperATV forward arched arms
    30" EFX Motoclaws / STI HD5 beadlocks
    Multi-vent hardcoat windshield
    Canvas rear window
  5. #35
    229 times
    But technically if you lift at all, it messes with the alignment because the tie rods pull the tires inward as the suspension stretches out, but we won't get into all that. Lol
    Canvas rear window
  6. #36
    (Cody) Starting Member islandrunner's Avatar
    Maurice, LA
    Well went with the HL a-arms and 2" HL lift kit, 30" outbacks ....love the result.... this thing is a beast!! I could have went with 31" tires I believe....differently have the room plus my shock are on the softest setting.
  7. #37
    Veteran Member mason_tay's Avatar
    Jul 2016
    Wallsboro, al
    72 times
    Those outbacks look good
    2013 ranger xp900 LE
    6" satv lift
    Rhino axles
    12% gear reduction
    Epi mudder primary
    Highlifter snorkel
    34.5 outlaw 2
  8. #38
    983 times
    Sweet looking ride!
  9. #39
    Jul 2015
    Southern Illinois
    159 times
    X2 on the tires. Machine looks good!
    Union Electrician
    Polaris Radio
    12" Light bar
    14" MSA Vibe wheels
    Dragonfire Doors
