engine check light and seat belt light
This is a discussion on engine check light and seat belt light within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; Was duck hunting this past weekend and was 20 degrees with 9 wind chill after running out in water just covering floor boards , it ...
Like Tree5Likes
  • 1 Post By pitbull
  • 3 Post By teshreve
  • 1 Post By Hawgtied
Thread: engine check light and seat belt light
    (James ( Tony)) Regular Member Tbounds's Avatar
    May 2016
    Free State of Jones Mississippi
    6 times
    Was duck hunting this past weekend and was 20 degrees with 9 wind chill after running out in water just covering floor boards , it sat for a couple of hours on dry land while hunting .
    When i came back and cranked it went dead a couple of times and then cranked and when i put it in gear it went dead a couple of times . Then the check engine light came on and seat belt light . I ran it back out into water to retrieve gear and after running for a little while all the lights went off.
    Any ideas or should i even be concerned since they went off.
    Supporting Member pitbull's Avatar
    Dec 2015
    NW Louisiana
    292 times
    Could be a weak battery due to cold temps. These machines do crazy things on a weak batt.
    teshreve likes this.
    Pitbull
    2016 Polaris Ranger 570 Midsize
    SATV 2" Lift On Front
    EV Coil Springs On Rear
    Highlifter Max Clearance Forward A-Arms
    Interco Interforce 30x8x12
    Seizmik Vented Windshield
    Kolpin Stronghold Gun Boot And Bracket
    Custom Roof
    Custom Roof Rack/Light Bracket
    Custom Game Loader Winch Bar
    Custom Front and Rear Mud Guards
    Polaris Lock and Ride Rear Glass
    KFI Front Winch Mount
    2 Badlands 3500 Winch
    Overhead Lights
    Rear Work/Back-up Lights
    May 2016
    6 times
    battery is new with machine bought in april
    Veteran Member mason_tay's Avatar
    Jul 2016
    Wallsboro, al
    91 times
    Doesn't mean it isn't bad. But if you're determined then change the stator.
    2013 ranger xp900 LE
    6" satv lift
    Rhino axles
    12% gear reduction
    Epi mudder primary
    Highlifter snorkel
    34.5 outlaw 2
    Veteran Member yooper265's Avatar
    Upper Peninsula
    71 times
    Have you put a meter on it when its' running to check the charging voltage ?
    May 2016
    6 times
    Battery is fine
    1190 times
    Quote Originally Posted by Tbounds View Post
    Battery is fine
    Famous last words
    Especially in Rangerville.
    Did you ask it if it was fine? I ask my wife lots of questions that the answer to is "fine" (when things are obviously not fine! Lol)
    Naylor649, yooper265 and NP Chief like this.
    (Steve-o) Elite Member Naylor649's Avatar
    Jul 2015
    Southern Illinois
    218 times
    Do us a favor and check your voltage on your batter. Then I would check for corrosion in any of your terminals and wire harnesses. Just because water was at the floor board doesn't mean it wasn't splashed or had some go up higher.
    Union Electrician
    2015 900 XP Sandstone Metallic
    Fixed Glass Windshield
    Lock & Ride Rear Glass
    Lock & Ride Sport Roof
    Polaris Radio
    Polaris Extreme Bumper
    Viper Elite 4000 winch
    12" Light bar
    3" Full Outkast lift
    14" MSA Vibe wheels
    30" Pro Armor Crawler XG
    Dragonfire Doors
    Garage Products Bushings
    Fueled by Busch Light
    (Scott) Regular Member Hawgtied's Avatar
    Jan 2013
    Crosby, Texas
    9 times
    Check the terminal connections at the battery when you check the voltage. Many times the batteries are connected at the dealer just before delivery. I've had one that was not even finger tight. Once I snugged it down and the battery fully charged, it ran like a spotted ape.
    2016 900 XP EPS
    Sage Green
    4500# winch
    More accessories coming soon!
    (Tom) Veteran Member Dseldoc's Avatar
    Nov 2015
    Central California
    77 times
    When you check the battery, be sure to do it when you are cranking the engine over. You could have 12 volts at the terminals with everything static, and find far less than that cranking. Also be sure to check the voltage at the starter terminal and ground when cranking if the voltage is good at the battery. You should have about 10 volts at the battery and the starter when cranking. Anything less than that will result in slow/no cranking.
    Tom
    We may enact wise laws, but we cannot legislate sense into the head of a fool.
