Winch Switch
This is a discussion on Winch Switch within the Ranger XP 900 Discussions forums, part of the Polaris Ranger Forums category; I just got my switches in from OTRATTW today and im pretty sure ive got it figured out how to wire my radio switch but ...
Results 1 to 7 of 7
Thread: Winch Switch
    (Raymond) Elite Member rayford118's Avatar
    Alexandria, LA
    Winch Switch
    I just got my switches in from OTRATTW today and im pretty sure ive got it figured out how to wire my radio switch but im needing some help with my winch switch. Does anyone here have any pics of the back of their winch rocker switches to use as a guide? or anything of help. I remember seeing one pic of a switch showing a "hotwire" kinda from one power to two in order to get the lights of the switch to work but i cant find it. Thanks for the help
    2013 Polaris Ranger 900 XP LE
    28" S/W Outlaw Radials on ITP SS 212s, 5000lb Viper Elite Winch,
    Audio Formz Roof, Dragon Fire Doors, Backwoods Armor Forward Arched A Arms,
    BA Arched Rear, BA Adjustable Lift, Front and Rear Brushguards,
    Poly Hard Windshield, Poly Rear Panel, SATV Bed Rack, Center Console
    2011 Polaris Ranger XP LE
    27X11X14 ITP Mudlite XTR on ITP SS 212s, 4500lb Polaris Winch
    J Strong Roof (lights and radio), Forward A-Arm
    Pre Runner Front and Rear Brushguards
    J Strong Windshield, Box Rack, Center Console
    Motoactiv Suicide Doors
    Alexandria, LA
    here is what the switch looks like and the diagram. I have the regular ATV winch switch from Motoalliance. Going to take it apart but need to know which wires go where for this switch.
    (Travis) Veteran Member travellerwiz's Avatar
    Dec 2012
    Alberta
    Ok.. Not too difficult based on the diagram..
    Do you want the lights to light up when you rock the switch.. or on all the time?
    Dec 2012
    Alberta
    As to the winch wiring...
    I'm pretty sure that is a split backplane switch. If you have a multimeter you can check if there is continuity between #1 and #4.. If no continuity, then you only need to use one side of the switch (the other side could be used for a rear winch).
    You will hook the hot wire from the contactor to #2, then the "Out" wire to #1 and the "In" wire to #3. You can test which is which by touching each of the wires to the hot wire and seeing which way the winch moves.
    Make a "Y" cable that goes to 7 and 9 and then to ground (-)..
    If you want lights on all the time. Make a "Y" that goes from #2, #8, #10.. If you want only when rocked.. Make a jumper that goes from #8 to #1 and another that goes from #3 to # 10.
    Alexandria, LA
    thanks for the help guys. having this first tutorial makes it seem easy now.
    Dec 2012
    Alberta
    One more thing...
    If you winch is wired correctly then the Hot from the contactor will only be Hot with the ignition on..
    If wired incorrectly, then the Hot wire is Hot all the time and your switch lights could be on all the time killing your battery..
    Alexandria, LA
    yeah i found the ignition wire the other night that is only on when key is on. FYI it is the outside orange wire on ignition switch. Will have pics of everything in my build thread
2013 polaris ranger 800 winch switch
2014 polaris ranger crew 900 winch wiring
how to wire radio polaris 900xp
polaris ranger 900 xp winch switch
polaris ranger xp 900 2014 winch rocker switch
toggle switch wiring polaris ranger
where is th hot wire for a winch on a 2013 polaris ranger xp
winch switch location polaris crew
wiring atv winch to ranger key switch
wiring rocker switches on polaris ranger
