under the hood electrical block?
This is a discussion on under the hood electrical block? within the Ranger XP 900 Discussions forums, part of the Polaris Ranger Forums category; I have my winch selinoid wired to one of the three terminals bit other two are not hot?? Any ideas? Fuse for them somewhere???...
Results 1 to 9 of 9
Thread: under the hood electrical block?
    (Jason) Veteran Member BLKRinnyrdr's Avatar
    Florida Panhandle
    (Ken) 1000+ Member Roadrunner's Avatar
    Casa Grande, AZ USA
    39 times
    I picked up a 6 spade fuse block from my local auto parts house and put it on the wall of the box the ECU is in under the seat on the battery side of the box. I now can run several accessories off it and makes for a neat installation. Each spade terminal has it's own fuse. I use it for my Signal lights, cab lights and winch. The under the hood the switch must be on to have power to it and you are right only one pole is hot.
    Ken
    1324 Roadrunner 12/29/05
    Casa Grande, Arizona
    www.3dflags.com
    Florida Panhandle
    What the heck are the other two for? I cant get it to ground? So dont think it is ground? Just puzzles me why they put three in there and only one is hot?
    Casa Grande, AZ USA
    39 times
    It is a three pole block and they only made one hot. There is no ground and they have it grounded some place else. Keep mine depending on the amount of accessories running off it fusing may not be large enough to carry all the loads you are putting on it. That is why I went the fuse block route I did. Not only does it have a hot bar, but also a grounding bar.
    Ken
    www.3dflags.com
    (Travis) Veteran Member travellerwiz's Avatar
    Dec 2012
    Alberta
    Exactly.. Lots of guys wire the 2 other lugs to the positive and negative on the winch relay. This gives you key hot, full time hot and negative.. Just remember that anything you hook to the full time hot must have a fuse of its own..
    (Forde) Supporting Member fswan's Avatar
    363 times
    Some more discussion on the 900 power strip...
    http://www.prcforum.com/viewtopic.ph...hlight=#476509
    Forde
    Everything happens for a reason and that reason is usually physics.
    Florida Panhandle
    Thanks for the redirect. I am wondering about pulling my amp and winch selinoid off the same line. Anyone know what size fuse that keyed post has on it??
    (Moe) Starting Member Moe Man 57's Avatar
    Central Ia.
    When u turn the Key On, the outside one is hot & Center is ground, & the other one is hot all time
    Happy R R Ranger Ridin
    2013 Red XP 900
    Moe
    Florida Panhandle
    I only have one hot accesory post no constant! Just gonna wotk with the one for now. Keep some extra fuses and not use the radio when winching
ranger xp900 under hood terminal block
