Sheaves Cleaning Question
This is a discussion on Sheaves Cleaning Question within the Ranger Discussions forums, part of the Polaris Ranger Forums category; Do I remember reading somewhere that you can clean the sheaves with brake dust cleaner because it evaporates quickly?...
Results 1 to 4 of 4
Thread: Sheaves Cleaning Question
    (Bob) Elite Member bobb's Avatar
    Feb 2007
    DE
    359 times
    You want to use something that doesn't leave a residue behind. Household isopropyl alcohol also works.
    24 times
    A fine scotchbrite pad and alcohol is a common technique used - if installing a new belt - it should be cleaned with soapy water prior to installation.
    (Tom) 1000+ Member GPER's Avatar
    Nov 2008
    Kettering, Ohio
    That is some good info to know.
