Ranger 900 seat help
This is a discussion on Ranger 900 seat help within the Ranger Discussions forums, part of the Polaris Ranger Forums category; Hello all, I need some help. In order to install my new poly rear panel on my 900 I had to lift up and out ...
Results 1 to 10 of 13
Like Tree8Likes
Thread: Ranger 900 seat help
    Regular Member Jefflac02's Avatar
    Jul 2014
    25 times
    Hello all, I need some help. In order to install my new poly rear panel on my 900 I had to lift up and out on the back of the passenger seat in order to get to the bolt hole to tighten it. I can't for the life of me figure out how to lift the seat back to get it back in the grooves on the rear of the cab
    Thanks for the help!!
    1001 times
    The passenger seat back has 3 T25 (torx) screws holding it on. Each is accessible via holes in the external plastic panel below the rear window. But be careful! Dropping the screws may result in a cussing fit. Suggest you instead put some grunt into it and warp, bend, or otherwise will the seat to lift enough.
    Jefflac02 likes this.
    1001 times
    Hmm... Might be 4 screws. I only remember 3, but the parts diagram shows 4
    No matter, removing and especially replacing those screws is teh suck.
    FYI The Polaris glass rear panel doesn't have this problem and installs and uninstalls in 15 seconds. Not joking.
    (Rock) Elite Member rocknroll's Avatar
    between monkeys eyebrow and possum trot
    301 times
    Mine has 5 screws in it. The outside 4 have holes through the back to access them but the middle one doesn't. %#$*. Had to take the top of the back panel loose to get to it.
    Edit: Redo. I just put my seat back in. It actually has 6 in it, 2 in the middle. Top one is hidden. I didn't put it in.
    2017 900 XP with the one piece full width seat back.
    Jul 2014
    25 times
    When I get teshreve money I will get the glass rear panel. And the tilt glass for the front.
    I got the rear panel for a steal $150 brand new, so I couldn't pass it up. Better than nothing for now. But my upgrade plans are a stereo roof with front and rear glass. Gotta save some money. Start my new job on Monday.
    Thanks to you both for the help
    teshreve likes this.
    Veteran Member Ole Nasty's Avatar
    Jan 2014
    163 times
    I got that same problem but on the driver seat
    2016 Ranger 900 XP Crew Titanium Matte
    SATV 6" lift, 32" Mudder Inlaws, Snorkeled, Full Glass Windshield
    Gone
    2015 Polaris Sportsman 570 EPS
    2014 Polaris Ranger 800 EFI
    2011 Grizzly 700 EPS
    2005 Yamaha Rhino 660
    2009 Polaris Sporstman 500HO
    Youtube-OleNasty79
    Facebook-OleNasty79
    (Steve-o) Supporting Member Naylor649's Avatar
    Jul 2015
    Southern Illinois
    159 times
    Quote Originally Posted by Ole Nasty View Post
    Ya me too nasty since day one.
    Union Electrician
    2015 900 XP Sandstone Metallic
    Fixed Glass Windshield
    Lock & Ride Rear Glass
    Lock & Ride Sport Roof
    Polaris Radio
    Polaris Extreme Bumper
    Viper Elite 4000 winch
    12" Light bar
    3" Full Outkast lift
    14" MSA Vibe wheels
    30" Pro Armor Crawler XG
    Dragonfire Doors
    Garage Products Bushings
    Fueled by Busch Light
    1001 times
    Steve-o, you don't have the adjustable driver's seat? I thought all the LE and/or PS and/or SE 900's came with that?
    Anyways, I wish I didn't. Never use it and the mechanism is like 30 lbs. The seat is a tank!
    But I'd still want the split bench and the "cut and sew" multi color jazz.
    Naylor649 likes this.
    Jul 2014
    25 times
    I was going to ask if their seat was fixed? I'm 5'10" and I like to be able to slide it forward. Easier to set my parking brake.
    Jul 2015
    Southern Illinois
    159 times
    No I do but it still has them clips on the rear. I never use mine ether and my ole lady's legs are to short that even when adjusted she can't reach the pedals . That makes sence. Insert dunce hat here...
    Union Electrician
    Polaris Radio
    12" Light bar
    14" MSA Vibe wheels
    Dragonfire Doors
