MMA 2.5 lift on the way - Page 5
This is a discussion on MMA 2.5 lift on the way within the Ranger Discussions forums, part of the Polaris Ranger Forums category; I got mine on this weekend as well. The fronts go on a little easier than the rear, just because there's more in the way ...
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 60
Like Tree10Likes
Thread: MMA 2.5 lift on the way
  1. #41
    Starting Member NonTypicalCPA's Avatar
    Paw Paw, Michigan
    I got mine on this weekend as well. The fronts go on a little easier than the rear, just because there's more in the way in the rear. I put 28" Moto MTC's on 14" wheels on mine. First ride and I rubbed a little on a compressed turn. Might have to go with lifted forward a arms. The wheels and tires look killer though.
  2. #42
    Paw Paw, Michigan
  3. #43
    Paw Paw, Michigan
  4. #44
    Elite Member TacomaJD's Avatar
    229 times
    Looks good! You are saying you just installed MMA lift right? If so, you won't need lifted forward arms, just forward arms. Most of which are arched for high clearance. Lifted and arched are two totally different things.
    2016 Polaris Ranger 570 XP F/S
    2.5" Marshall Motoart lift - rides as soft as stock
    SuperATV forward arched arms
    30" EFX Motoclaws / STI HD5 beadlocks
    Multi-vent hardcoat windshield
    Canvas rear window
  5. #45
    983 times
    Looks great! Too bad you got some rubbing. Was it full of peeps?
    SlimRockett likes this.
  6. #46
    Regular Member g.schucks's Avatar
    Oct 2016
    14 times
    Quote Originally Posted by Toxic-21 View Post
    I wonder if your dealer mounted the shocks in the outer hole on the rear, that is on the outside of the frame.
    The inner hole is on the inside of the frame, easier seen if you lift the bed.
    post a pic, this will help to clear this up.
    Didn't even go look yet, (Ranger is in a seperate garage and I think I might blow over if I walk outside right now) and I know you are right. I must have not noticed there even being a mounting position inside the frame. Mine are mounted outside the frame rail. So what should be normal mounting and cam adjustment from the factory/dealer?
    g.schucks
    Sent from my SM-N920P using Tapatalk
    2017 Ranger Crew 1000 XP
    SuperATV flip out hard coated front windshield
    SuperATV hard coated rear windshield
    Dragon Fire doors
    SSS Offroad skid plate with integrated rockers
    WhoMoto MK1 roof
    Viper 4500 lb winch
    72" Denali plow
    Marshall Motoart 2.5 lift
    Waiting to be installed:
    Scorpionlok
  7. #47
    860 times
    Quote Originally Posted by g.schucks View Post
    g.schucks
    Normal for the most part, Preload in the lowest setting and the upper shock mounts, mounted to the inside holes, both front and rear.
    Where are the fronts mounted, inside or outside mounting position?
    Toxic-21 Products.
  8. #48
    Oct 2016
    14 times
    I think the fronts are in the inside spot. It took me a minute to even find the outside spot as it is a lot farther out from the out spot then I would have thought.
    g.schucks
    Dragon Fire doors
    WhoMoto MK1 roof
    Viper 4500 lb winch
    72" Denali plow
    Scorpionlok
  9. #49
    Paw Paw, Michigan
    Quote Originally Posted by TacomaJD View Post
    So just forward arms then add the MMA brackets to them? Which forward arms are recommended?
  10. #50
    Paw Paw, Michigan
    Nope, just me. But it was on a sharp turn at the bottom of a hill. I'll probably ride it and see how often it rubs, then eventually get the forward arms after winter.
