MMA 2.5 lift on the way
This is a discussion on MMA 2.5 lift on the way within the Ranger Discussions forums, part of the Polaris Ranger Forums category; Since the addition of the windshield, roof, plow mount etc... I have been looking to get some ground clearance back. I have already had to ...
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Like Tree10Likes
Thread: MMA 2.5 lift on the way
    Regular Member g.schucks's Avatar
    Oct 2016
    14 times
    Since the addition of the windshield, roof, plow mount etc... I have been looking to get some ground clearance back. I have already had to clean out the play mount and I really do not want to bang that on a rock and end up bending one of the ears. I looked at the highlifter brackets and they are very tempting at only a little over $100, but I ended up with the MMA 2.5. I really like that it is a welded bracket and not two separate pieces for each shock mount... My post today is asking for advice on how I should have the shocks setup as well. I have not touched the shocks at all from the dealer and I don't want to mess anything up but wow this thing does a nose dive when it picks up the plow! What setup should i be running for the stock shocks? I am running stock wheels and tires and will be until I wear them out probably. Should I make a change to plow and then go back if I am riding in the woods?
    TIA,
    g.schucks
    2017 Ranger Crew 1000 XP
    SuperATV flip out hard coated front windshield
    SuperATV hard coated rear windshield
    Dragon Fire doors
    SSS Offroad skid plate with integrated rockers
    WhoMoto MK1 roof
    Viper 4500 lb winch
    72" Denali plow
    Marshall Motoart 2.5 lift
    Waiting to be installed:
    Scorpionlok
    982 times
    Maxing the preload on the front shocks (metal ring thing with detents on each shock) will help with plow nose diving but will make the ride rougher. Moving the top of the front shocks to the outer hole will have a similar but not as big of an affect. The ride really goes downhill at this point. If you do this to all 4 shocks you'll gain an inch or maybe 2. I'd try maxing front preload only, testing, moving front shock out, testing, doing both to rear shocks and adding a few hundred lbs of blast weight all the way to the back of the bed, testing, and then finally ordering stiffer springs for the front. For plowing you actually want to be low and heavy. So maybe just try the ballast idea when plowing
    I am just rambling at this point.
    982 times
    I had a plow for my Sportsman 700 years ago. The thing would plow way way better when I had wife or friends or total strangers sitting on the rear rack facing backwards. Leveled it out, slammed it down and she'd move snow like a dozer. And it was fun getting cussed at too.
    Elite Member TacomaJD's Avatar
    229 times
    Good call on the MMA lift. The HL lift sucks. It is an upper bracket lift, and makes it ride like a steel wheeled wagon. The MMA lift retains soft ride and is a lower bracket lift, and much easier to install. I'd leave your shocks as they are, install the lift, then try out your plow and then make incrememtal adjustments if needed.
    2016 Polaris Ranger 570 XP F/S
    2.5" Marshall Motoart lift - rides as soft as stock
    SuperATV forward arched arms
    30" EFX Motoclaws / STI HD5 beadlocks
    Multi-vent hardcoat windshield
    Canvas rear window
    Regular Member bret5's Avatar
    Aug 2015
    pa
    26 times
    I set all four shocks to the middle position. To me it feels much more stable when riding in the woods (at stock setting it felt to tippy) but still a nice ride.
    15 ranger 570 fs
    emp windshield - emp rear windshield - emp mirrors
    sports roof
    glacier pro plow system (all hydro)
    Polaris canvas doors
    (Benz) silent rider muffler
    Oct 2016
    14 times
    Quote Originally Posted by bret5 View Post
    I feel like my crew is a little "tippy" as well. I have not touched the shocks yet so I think I might adjust the snail cam(?) to about the middle as well and give it a ride. It is at the lowest (softest) setting from the factory? Just to make sure that I understand correctly, that changes the shock rate and moving it up form the bottom will make the ride stiffer? Moving the shock to a different bolt would just change the ride heigth?
    Lift should be in today, but it finally has snowed here for the first time this year... I am sitting at work doing nothing waiting for 4PM to see if there is enough for me to hook up the plow and try her out.
    Dragon Fire doors
    WhoMoto MK1 roof
    Viper 4500 lb winch
    72" Denali plow
    Scorpionlok
    Starting Member NonTypicalCPA's Avatar
    Paw Paw, Michigan
    My MMA lift just came in the mail today, as well as my new wheels and tires. Looking forward to trying them out. Just curious what tool everyone uses to adjust the spring tension on the shocks?
    Veteran Member NP Chief's Avatar
    Sep 2016
    80 times
    Quote Originally Posted by NonTypicalCPA View Post
    Spanner wrench
    2013 Ranger 800 Crew - Sage Green
    30" Gorilla Silverbacks
    14" MSA Diesels
    4" Precision Offroad forward A-arm lift
    Precision Offroad front and back bumper
    Full front windshield
    Vinyl rear window
    Badlands 2500 winch
    2 - 40" LED lightbars
    LED dome light
    Custom black diamond plate top with matching radio box
    Pioneer CD/MP3 player
    4 - 6" Kicker marine speakers
    2 - 2" tweeters
    JL Audio marine amp
    Oct 2016
    14 times
    Have not used it yet, but I was planning on the tool that came in the tool kit.
    g.schucks
    Dragon Fire doors
    WhoMoto MK1 roof
    Viper 4500 lb winch
    72" Denali plow
    Scorpionlok
    229 times
    Channel locks.
    Canvas rear window
