Polaris Stereo Kit Install with photos
This is a discussion on Polaris Stereo Kit Install with photos within the Ranger Crew 900 Discussions forums, part of the Polaris Ranger Forums category; INITIAL INFORMATION: I installed the Polaris Stereo Kit p/n 2879248 on my 2014 Polaris Crew 900. PACKAGING: The stereo kit arrived in undamaged condition and ...
  • 2 Post By Gary Lenon
Thread: Polaris Stereo Kit Install with photos
    (Gary) Retired Moderator Gary Lenon's Avatar
    Jun 2004
    82 times
    PACKAGING: The stereo kit arrived in undamaged condition and all of the items listed in the kit contents on the instruction
    sheet were included.
    INSTALLATION: I started out by reading through the directions. Then I proceeded by placing my vehicle in Park and removing the key.
    Next I removed the dash cap by prying the four (4) plastic push pins along the front edge of the dash cap up with a small screwdriver and then removing them. The dash cap then just lifts off.
    Next I removed the stock dash control panel by removing the two bottom screws. Make sure you save the screws for your new stereo console panel. (see photo below of old control panel that was removed)
    Now I removed the switches from the old panel and installed them into the new stereo control panel. Then I inserted the new panel into the dash and secured it using the two (2) screws I saved earlier.
    Now from the front of the vehicle I reached down into the dash cavity and plugged in the USB and auxiliary plugs into the back of the auxiliary port. Now I plugged the connectors from the main wire harness back into the corresponding switches removed earlier. I matched the terminals on the back of the switches with wires coming out of the back of the connector.
    I routed the radio wire harness on top of the stamping along the main harness and into the holes in the frame cross member. Then I plugged the main radio harness into the main radio connector. (the included instructions clearly show the wiring process)
    I ran a red and black cable to the battery and mounted a fuse box under the hood for power. The fuse block pictured below is a Blue Sea Systems 50525 ST Blade-6 circuits with a negative bus and cover.
    Then I removed the LH cup holder to install the left speaker. I reached into the hole to locate the LH speaker wires. I connected the speaker harness to the main harness and then pushed the connector through the existing hole.
    I next installed the LH speaker inserting the speaker tabs into the existing holes behind the cup holder opening. This was a little difficult, but with patience it snapped into place. Then I installed three (3) screws to secure the speaker. I then followed the same procedure on the RH speaker.
    I next attached the antenna, by peeling off the backing and pressing it firmly on the bulkhead. I attached the powered antenna wires with the red to keyed power and the black to ground.
    Here is a photo of the completed stereo.
    Review: I have to say this stereo has some very nice sound. The radio itself picks up FM stations just as well as the one in my truck and car!
    RZR Rich and JJaxon like this.
    Psalm 118:24... This is the day which the LORD hath made; we will rejoice
    and be glad in it.
    (Neal) Retired Moderator oneal's Avatar
    Aug 2005
    Ohio
    27 times
    Nice write up Gary, I really like those stereo's !
    Neal
    Today is my personal best for most consecutive days alive.
    65 times
    Good write-up/install job Gary, turned out nice!
    You only mention installing the 2 front speakers, are there provisions for installing 2 rear speakers and if so, do you plan on doing so at a later time?
    (Carl) Elite Member Seastacker's Avatar
    Feb 2013
    228 times
    Great write up, install looks great! I wish they had a nice clean OEM kit like that for the mid-size machines. I would gladly pay a little bit of a premium to have a nice clean factory looking install like that!
    '13 Ranger 500 EFI (Red)
    26" Outlaw MST tires, MSA Elixr wheels. Polaris sport roof. Polaris half windshield and EMP full fold down windshield. EMP canvas back panel. Mud Guard kit front and rear. Viper Max 4000# Winch w / Synthetic rope. Polaris rear bumper, Lock and ride chainsaw scabbard. Odyssey 925 battery.
    Other stuff:
    01' Ford F-250 Diesel
    85' Honda ATC 250R
    (Ben) Regular Member Osgood's Avatar
    May 2013
    Osgood, in
    How weather resistant are those speakers? I have to wonder if direct water exposure will be a problem.
    2014 Ranger 900 Crew, Sunset Red Metallic LE with Sport Roof, rear bumper, overhead radio,rear glass and tip out windshield.
    (Thomas) Veteran Member Duckhunter1's Avatar
    Jan 2013
    Ward, Arkansas
    My father in law has the same stereo it has seen some rain and the ranger always gets a good pressure wash and shine after every ride he's never had any issues with the radio or speakers
    Operation Iraqi Freedom Veteran
    Operation Enduring Freedom Veteran
    2014 Titanium Metallic LE Ranger 900
    Pure Polaris Lock and Ride Windsheild
    Pure Polaris Lock and Ride Rear Window
    Pure Polaris Lock and Ride Roof
    Pure Polaris Front Bumper
    Pure Polaris Stereo
    5000LB ProMark Winch
    12'' Double Row SeeLite
    Moto Alliance Orange Synthetic Rope
    Outkast 3'' Foward/Rear Arched A-arm Lift
    HighLifter Steering Stops
    29.5'' Terminators
    Rhino Axles/Gorilla Boot's
    2 Orange 6' Tribal Whips
    Starting Member money814's Avatar
    Jun 2014
    Is the auto antenna (blue wire on infinity prv250) the remote wire for the amp?
    Jan 2013
    Ward, Arkansas
    Iam running the same stereo been in water over the speakers. I also pressure wash mine after every ride no issues yet. My father in law has had the same stereo for almost 2 yrs now he does not go as deep as me but definitely washes it whenever it gets dirty no issues with his either. For the money I am very pleased. No drilling or bulky box mounted above my head
    Pure Polaris Stereo
    29.5'' Terminators
    (Dean) Elite Member slowroller's Avatar
    Aug 2012
    MS
    82 times
    Quote Originally Posted by money814 View Post
    Yes it is.
    (Rusty) Veteran Member BlueCrew's Avatar
    Jul 2013
    Nettleton,MS
    23 times
    What size speakers are in this kit?
how to install a radio in a polaris ranger
how to install a radio on a 2016 polaris ranger
how to install radio in polaris ranger
installation of a polaris dash radio
polaris ranger 900 speaker locations
polaris ranger radio install
polaris ranger radio installation instructions
polaris ranger radio wiring
polaris ranger stereo kit
polaris ranger xp dash mounted audio install
