2008 RZR 800 fuel management modules
This is a discussion on 2008 RZR 800 fuel management modules within the RZR Problems & Solutions forums, part of the Polaris RZR Forums category; I replaced the exhaust system on my RZR recently and it is running very bad! it smells like it is running to rich. I can ...
Thread: 2008 RZR 800 fuel management modules
    Starting Member Justone1992's Avatar
    Sep 2016
    I replaced the exhaust system on my RZR recently and it is running very bad! it smells like it is running to rich. I can pull the new air filter out and it runs a little better but still wont go over 45 mph. i have replaced the plugs and wires already. it has been suggested that i have to get a fuel mgt module.
    Caribbean
    1384 times
    sounds rich Just, are you sure the TBAP harness didn't get damaged putting the new exhaust on ? It ran fine before the new pipes ? Did check for stored EFI codes ?
    Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting WHAT A RUSH, WHAT A RIDE. WHOA !
    2007 Polaris Ranger700 XP LE
    (Mike) 1000+ Member mtimesplitter167's Avatar
    arizona
    571 times
    Quote Originally Posted by Justone1992 View Post
    Like JM said check for damaged wires. If you need a fuel tuner,here you go.
    Fuel Moto Micro EFI Tuner
    Three can keep a secret if 2 are dead.
