Ranger EV - Page 16
Ranger EV
This is a discussion on Ranger EV within the Ranger EV Discussions forums, part of the Polaris Ranger Forums category; Finally took delivery!...
Page 16 of 16 FirstFirst ... 6141516
Results 151 to 160 of 160
Thread: Ranger EV
  1. #151
    Regular Member PCHunter's Avatar
    Sep 2014
    10 times
    Finally got the 2015 EV
    Attached Images Attached Images
    4Nines likes this.
  2. #152
    Regular Member EVcruise's Avatar
    Mar 2014
    Clinton. MS
    27 times
    You either love them or hate them. I have had my share of problems with my 2011. i've had several different electric 4x4 hunting carts and the Polaris is by far the best set up as far as the frame and suspension and also torque. Most of them ride like tanks. I have several buddies with them and i help them w their issues. I hunt small tracks of land and i will not go back to gas machine as long as there is a electric out there. I only use it for hunting and care nothing for joy riding except to run the batteries down n recharge. I used this year at the deer club to haul fertilizer n seed and on my GPS clocked 18 miles and ran it down to 30%. Yea it seems one thing after the next but i think its the best option for hunting.
    Thats my story n I'm sticking to it!!
    4Nines likes this.
    2014 Ranger EV
    200AH Li-ion battery conversion
    ITP Terra Cross Front 25x12x8/ Rear 25x10x12
    2" Motoart lift kit
    Thunder Hawk Front mud shields and Fender Guards
    Rear custom under bed mud shields with fender flares
    Front fender flares
    Overhead gun and Bow rack
    Superwinch LT2000 mounted on cargo Box
    Polaris Lock n Ride roof
    Polaris Lock n Ride rear windshield
    Kolpin Lexan Full Tilting windshield
    Camo Shock covers
    Cargo light
    Eagle Eye back up lights
  3. #153
    1190 times
    Quote Originally Posted by PCHunter View Post
    The EV has the new body style now? Looks nice!
    Which roof is that?
    How fast does it go? Can I drive it?
    (Marti) Starting Member Marti's Avatar
    Oct 2014
    Willard, MO
    battery hold down bolts, stainless steel replacements?
    Has anybody been able to find replacement bolts to hold down the batteries, in stainless steel? They're the M8x1.25-320mm ones.
  6. #155
    Sep 2014
    10 times
    The EV has the new body style now? Looks nice! Thanks
    Which roof is that? It is the steel roof with the LX cab system
    How fast does it go? Says 25 mph which is fast enough to get to the deer stand. Can I drive it? Well you would need to be way down south first
    I bet your 900 EPS drives much better.
  7. #156
    Regular Member Xfaxman's Avatar
    Jan 2015
    Central Oklahoma
    19 times
    Smile 2013 Ranger EV
    Pictures from the day after we got it.
    Hold the Control key down and click on a picture or a Link, to open it in a new Tab.
  8. #157
    Starting Member dws1's Avatar
    Jan 2015
    Does anyone know if you can run the "Normal" battery charger for the main UTV batteries, and an additional on board "Battery Tender 800" only to the 2 smaller "accessory" batteries hooked up through the Accessory Battery kit? Would/should I put some sort of isolation in line??
    Thanks-David
  9. #158
    Jan 2015
    Central Oklahoma
    19 times
    Should work, but since the recommendation is to raise the hood while charging, I would just connect the Battery Tender when plugging in the Delta-Q.
    Since I live where the summer time is hot, and I am old and forgetful, I removed the charging cord plug from the dash. Now I have to open the hood to plug in the extension cord.
  10. #159
    Jan 2015
    Thanks Xfxaman- Any thoughts on if the factory harness has isolation built into it to prevent the 12volt tender feeding/tainting the battery banks?
  11. #160
    Jan 2015
    Central Oklahoma
    19 times
    It would not be connected to the 48 volt battery.
    It would be connected to the 12 volt converter and should not affect it.
    Seems like someone on here has done it, maybe he will see your question and post his results.
ev charger schematic
polaris ev charger light sequence
polaris ev ranger problems
polaris ranger ev battery problems
polaris ranger ev forum
polaris ranger ev problems
polaris ranger ev throttle problems
ranger ev
ranger ev melting battery terminal
what is the total width of a polaris ranger ev
