EV LSV DOT Street/Summer tires:
This is a discussion on EV LSV DOT Street/Summer tires: within the Ranger EV Discussions forums, part of the Polaris Ranger Forums category; EV LSV Street/Summer tires: These will yield better wet/dry traction on the street, better stability and less rolling resistance. Also permitted on golf course. NOTE: ...
Results 1 to 5 of 5
  • 1 Post By DJWorm
Thread: EV LSV DOT Street/Summer tires:
    (DJ) Veteran Member DJWorm's Avatar
    Oct 2012
    Erie, Pa.
    35 times
    NOTE: I do not go off road very much in the summer but see a lot of street use.
    Will post more pics after mounting on vehicle.
    GBC DOT Afterburn Street Force 25 X 8.0 X R12 Front
    GBC DOT Afterburn Street Force 25 X 10.0 X R12 Rear
    ON
    Moose 387X polished aluminum 12 X 7.0 FRONT
    Moose 387X polished aluminum 12 x 8.0 Rear
    Here is the finished product mounted on the EV LSV.
    Note: It has a 2" lift and 1 1/2" billet wheel spacers....guess its time to add those fender flares......
Size:  1.24 MBName:  IMG-20160718-00389.jpg
Size:  1.22 MBName:  IMG-20160718-00387.jpg
Size:  1.14 MBName:  IMG-20160718-00390.jpg
    What to do with the OEM tires and wheels ?...... I'll save them for Winter snow plowing and hunting in the Fall....in the meantime .......
    I added a Moose Lock & Ride spare tire mount in the bed box. Mount is reversible and can be mounted with tire inside or outside box and is fully adjustable for different size tires and wheels. Can be mounted on left or right side of box, on front of box (inside only) and tailgate (position may be too heavy to open and close tailgate). I chose to mount OEM Carlisle on OEM steel rim inside box on right side.
Size:  1,010.5 KBName:  IMG-20160718-00385.jpg
    NOTE: I now carry a ratchet, extension, socket for the OEM nuts and washers, a set of the OEM lug nuts and washers (flat) and a socket for the new wheel lug nuts (tapered) in the glove box.
    Hooterray likes this.
    2011 Polaris Ranger EV LSV, OEM Winch, Back Glass, Rear Bumper, Brush Guard, Roof, Glacier II Plow with 5' Razor Blade, EV Motor Cooling Kit. GPS Speedo/Odo, Battery Mats, Battery Watering System, Battery Fluid Level Detectors, 1/2" full length Poly Skid Plate with Side Pod Wings, Safety Triangle, LED license plate mount, 6' whip antenna with flag and white strobe, collapsable billet whip mount, Polaris cover, 2" ball hitch. Good Day bed rack, game carrier, overhead gun rack, Moose gun rack. Gun dog bed kennel. Seizmik hood rack, light bar with 18w spot & 9w flood lights, outside rear view mirrors, rear view mirror, interior light. Superbright 18" HD dual row 45W amber LED fog light bar, 18w rear red LED fog. Battery Minder 12v, 1.25A Solar Charger/Maintainer/Desulphator with 15 watt solar panel and battery condition monitor, Battery Minder 120v > 12v, 2A Charger/Maintainer/Desulphator wired to Delta Q input, Battery Minder OBD-48 48v Desulphator. Thunderhawk inner fender guards, fender guards, A-Arm guards, cargo box seal kit. Highlifter Signature 2" lift Kit, Steering Stop Kit, Outlaw DHT front axles, Pro Series forward A-arms, Delrin bushings,1.5" billet wheel spacers. Moose 387 wheels, GBC Afterburn Street Force tires. Moose spare tire mount. Aluma UT 10 trailer. Polaris p2000i inverter/generator for backup recharging off grid. Pending: solar charging system, double adjustable shocks.
    RJ is online now
    (Rod) Veteran Member RJ's Avatar
    85 times
    Hey DJ,. Do they measure a true 25? I've considered those tires myself for summer use.
    Oct 2012
    Erie, Pa.
    35 times
    @ RJ:
    Yes, a true 25" OD depending on inflation.
    - Recommended inflation = 12 PSI (500# load)
    - Max. Inflation = 35 PSI
    On the street I will probably run a higher pressure, like 20-25 PSI to get less rolling resistance and better endurance, predicated on wear pattern.
    Off road I will run less pressure for better traction, 12-15 PSI.
    RJ is online now
    85 times
    Thank you sir!
    Don't forget to post a pic of them on your rig!
    Oct 2012
    Erie, Pa.
    35 times
    New pics posted ....mounted on vehicle......
