EV LSV Battery Life !
This is a discussion on EV LSV Battery Life ! within the Ranger EV Discussions forums, part of the Polaris Ranger Forums category; Pleasantly surprised .....so far. I have a 2011 EV LSV manufactured late in 2010. It was a factory demo and I bought it with 40 ...
Results 1 to 6 of 6
Thread: EV LSV Battery Life !
    (DJ) Veteran Member DJWorm's Avatar
    Oct 2012
    Erie, Pa.
    35 times
    Pleasantly surprised .....so far. I have a 2011 EV LSV manufactured late in 2010. It was a factory demo and I bought it with 40 hours on it. I found that the factory did not follow their own battery maintenance procedures ( dirty compartment, 1 loose terminal nut, a lot of almost dry cells).
    SO....@50 hours (2012):
    - removed and cleaned all batteries.
    - replaced 1 battery due to a loose +anode pole. (Duracell equivalent from Sam's Club)
    - added 1 tablespoon of Epsom salts to each cell.
    - refilled all cells with distilled water.
    - checked all cells with hydrometer....all within spec.
    - checked all batteries with voltmeter....all within spec.
    - installed Battery Mat(s).
    - replaced 1 interconnect cable.
    - reinstalled batteries.
    - installed all stainless steel nuts, washers and lock washers on battery terminals.
    - torqued all hardware to spec.
    - sprayed all battery and electrical connections with protectant.
    - installed Pro Fill Battery watering system.
    - installed optical battery fluid level detectors.
    - installed full skid plate with side wings and Thunderhawk front fender guards to reduce ingestion of debris into battery compartment.
    Meticulously maintain batteries, check hardware torque and refill with distilled water. Keep unit plugged in all the time. Stored outside summer and winter.
    @100 hours (2014):
    - had Dealer Service Dept. use electronic battery tester to leak down and test all batteries.
    - replaced 1 original battery due to decreasing voltage
    - installed Battery Minder OBD-48 Desulfator
    @150 hours (2016):
    - replaced 1 original battery due to decreased voltage
    - replaced both 12v AGM winch batteries (both dead).
    - installed Battery Minder 15 amp solar charger/maintainer/desulfator on winch batteries.
    I had expected to replace all the original batteries this year but was surprised that 5 are still functioning to spec.
    I feel that the Epson salts introduced early in their cycle, the Battery Minder desulfator added and the meticulous maintenance with the Pro Fill watering system has added to their longevity.....going on 6 years.
    The solar charger should maintain the AGM winch batteries better.
    2011 Polaris Ranger EV LSV, OEM Winch, Back Glass, Rear Bumper, Brush Guard, Roof, Glacier II Plow with 5' Razor Blade, EV Motor Cooling Kit. GPS Speedo/Odo, Battery Mats, Battery Watering System, Battery Fluid Level Detectors, 1/2" full length Poly Skid Plate with Side Pod Wings, Safety Triangle, LED license plate mount, 6' whip antenna with flag and white strobe, collapsable billet whip mount, Polaris cover, 2" ball hitch. Good Day bed rack, game carrier, overhead gun rack, Moose gun rack. Gun dog bed kennel. Seizmik hood rack, light bar with 18w spot & 9w flood lights, outside rear view mirrors, rear view mirror, interior light. Superbright 18" HD dual row 45W amber LED fog light bar, 18w rear red LED fog. Battery Minder 12v, 1.25A Solar Charger/Maintainer/Desulphator with 15 watt solar panel and battery condition monitor, Battery Minder 120v > 12v, 2A Charger/Maintainer/Desulphator wired to Delta Q input, Battery Minder OBD-48 48v Desulphator. Thunderhawk inner fender guards, fender guards, A-Arm guards, cargo box seal kit. Highlifter Signature 2" lift Kit, Steering Stop Kit, Outlaw DHT front axles, Pro Series forward A-arms, Delrin bushings,1.5" billet wheel spacers. Moose 387 wheels, GBC Afterburn Street Force tires. Moose spare tire mount. Aluma UT 10 trailer. Polaris p2000i inverter/generator for backup recharging off grid. Pending: solar charging system, double adjustable shocks.
    Starting Member capnbo53's Avatar
    Dec 2015
    Thanks for the information.
    2016 Ranger EV Avalanche Grey/Polaris Sport Roof/Seizmik Full Folding Versa-Fold Windshield
    Polaris Lock & Ride Pro-Fit Glass Rear Panel/KFI Rear Tube HD Bumper/Great Day Inc Quick Draw Overhead Gun Rack/Formosa UTV storage cover 120"Lx62"Wx75"H/Seizmik pursuit side view mirrors 18073/Polaris 2875320 2" Receiver Hitch Tongue and 2" Ball/Viper Elite 4,500 lb Wide Spool Winch - Polaris Ranger EX4500SE-BK65-MA11208-MA11901/Optima 31D Marine Deep Cycle Battery/Battery Tender 021-0156 Plus 12V Battery Charger/EZ turn signal and horn kit/MICTUNING 18W square LED Flood 60 degree back up light/Polaris 2879969 Rear View Mirror/Dragonfire Racing Removable Led Dome Light Kit 11-0001/Deflect-O RSMVT Slow Moving Vehicle Reflective Triangle/Deflecto 99-0325-00 Vehicle Placard Slow-Moving Vehicle Sign Mounting Kit/Pro Armor SIXR 14" wheels/ Grim Reaper tires 26/ 9.00/14R front, 26 11.00/14R rear, cargo bed liner, chain saw holder, Super Daves rear outer and shock bushings, atvguard shop front and rear bed mud protectors, gun grabber rifle holder.
    (Jay) Starting Member JRobyn's Avatar
    Apr 2016
    Middle Tn
    Link for the optical fluid level detectors?
    Oct 2012
    Erie, Pa.
    35 times
    Optical Battery Level Detector from Jan Water Products:
    Battery Watering Systems, Marine Dock Products, Solar Dock Lights
    Part# JWP-BA 134 Standard length 2 1/16" $2.50 ea.
    Order one for each battery. Install in one of the center cells. (Center cells loose fluid faster)
    You'll need 8.....one for each power drive battery.
    NOTE: will not work in AGM winch batteries.
    You'll also need:
    .50" Special Drill Bit Part # JWP - BA - 107 $30.00
    This drill bit allows drilling the correct size recepticle hole into the battery case top to the right depth and removes the drill curl without depositing debris into the battery cell and without damaging the cell.
    Be sure to center the bit before drilling. I.e. make sure you are lined up correctly.....use the center line of the fill cap to position.
    These make it easy to check the battery level and tell you exactly when to refill.
Size:  13.0 KBName:  fr_drill_sm.jpg
    Apr 2016
    Middle Tn
    Thanks, but I'm skeptical that I could bring myself to intentionally drill a hole in my batteries! Guess I'll just keep unscrewing the caps.
    Oct 2012
    Erie, Pa.
    35 times
    Its really not that dangerous.
    - The drill bit works so that the debris curl is ejected in one piece up and out and does not fall into the cell.
    - The drill bit has a stop on it so that you cannot drill too deep.
    The critical part is that you align the new hole with the center of the cell. This is easily done visually by using the centerline of the fill cap hole.
    Its really quite easy.
    Since adding a visual indicator to each battery and the watering system I have never needed to remove a cell cap.
battery life on ranger ev
