How to use 6 - 8 volt batteries
This is a discussion on How to use 6 - 8 volt batteries within the Ranger EV Discussions forums, part of the Polaris Ranger Forums category; I need to temporarily run my EV on 6 - 8 volt batteries from my golf cart. Thought I remembered seeing how to change the ...
Thread: How to use 6 - 8 volt batteries
    Starting Member ssrsc's Avatar
    Oct 2005
    Nashville TN
    I need to temporarily run my EV on 6 - 8 volt batteries from my golf cart. Thought I remembered seeing how to change the existing battery wiring to do this somewhere in this forum a few months ago, however, I have searched for hours and cannot find it.
    Can someone point me in the right direction or show how to do this?
    Thanks in advance!
    Oct 2005
    Nashville TN
    Typo here - I should have said 8 - 6 volt batteries. With that straightened out, any ideas on this?
    (DJ) Veteran Member DJWorm's Avatar
    Oct 2012
    Erie, Pa.
    34 times
    To get the 48v necessary you would need to run all 8 6v batteries in series. You would not be able to run a series/parallel wiring to increase AH.
    + wire from controller ~ +6v- ~ +6v- ~ +6v- ~ +6v- ~ +6v- ~ +6v- ~ +6v- ~ +6v- ~ - wire from controller
    6v + 6v + 6v + 6v + 6v +6v + 6v + 6v = 48v
    Total AH is the same as a single battery AH.
    Endurance will suffer.
    DO NOT USE THE DELTA Q TO RECHARGE THE 6V BATTERIES.
    2011 Polaris Ranger EV LSV, OEM Winch, Back Glass, Rear Bumper, Brush Guard, Roof, Glacier II Plow with 5' Razor Blade, EV Motor Cooling Kit. GPS Speedo/Odo, Battery Mats, Battery Watering System, Battery Fluid Level Detectors, 1/2" full length Poly Skid Plate with Side Pod Wings, Safety Triangle, LED license plate mount, 6' whip antenna with flag and white strobe, collapsable billet whip mount, Polaris cover, 2" ball hitch. Good Day bed rack, game carrier, overhead gun rack, Moose gun rack. Gun dog bed kennel. Seizmik hood rack, light bar with 18w spot & 9w flood lights, outside rear view mirrors, rear view mirror, interior light. Superbright 18" HD dual row 45W amber LED fog light bar, 18w rear red LED fog. Battery Minder 12v, 1.25A Solar Charger/Maintainer/Desulphator with 15 watt solar panel and battery condition monitor, Battery Minder 120v > 12v, 2A Charger/Maintainer/Desulphator wired to Delta Q input, Battery Minder OBD-48 48v Desulphator. Thunderhawk inner fender guards, fender guards, A-Arm guards, cargo box seal kit. Highlifter Signature 2" lift Kit, Steering Stop Kit, Outlaw DHT front axles, Pro Series forward A-arms, Delrin bushings,1.5" billet wheel spacers. Moose 387 wheels, GBC Afterburn Street Force tires. Moose spare tire mount. Aluma UT 10 trailer. Polaris p2000i inverter/generator for backup recharging off grid. Pending: solar charging system, double adjustable shocks.
