2012 ev no headlights
This is a discussion on 2012 ev no headlights within the Ranger EV Discussions forums, part of the Polaris Ranger Forums category; Hello Forum, I need some help with my ev the headlights stopped working the other day. everything else works and operates. I have a service ...
Thread: 2012 ev no headlights
    (RON) Starting Member RONZBOBCAT's Avatar
    Oct 2011
    ARIZONA
    everything else works and operates. I have a service manual so I trouble shoot the problem that way.
    1. I have no indicator light on the headlight switch.
    2. I have 28.3 volts at the switch and fuse also at the converter.
    3. I have replaced the converter once before a couple of years ago could this be the problem ?
    Veteran Member yooper265's Avatar
    Upper Peninsula
    67 times
    Not sure but before I would spend $300 for a Polari$ voltage reducer{ converter } for the headlights I would do a little creative rewiring and install one these -
    RecPro? GOLF CART Voltage Reducer Converter Regulator 36V-48V Volt To 12V 20Amp | eBay
    Oct 2011
    ARIZONA
    should I be seeing 48 volts at the converter ?
    Upper Peninsula
    67 times
    I don't have wiring diagram for a electric ranger , you mentioned you have one , look and see if there's anything tapped in the middle of the battery bank , if not then it should have 48 volts at the input to the converter .
    Upper Peninsula
    67 times
    After doing a quick google I see you should have 48 volts going in to the converter .
    This converter is nothing different { except price ! } than what is used on golf carts to reduce the 48 volts to 12 volts .
    Upper Peninsula
    67 times
    You didn't mention if you're running add on accessories { light bar , radio , etc } that would pull more current and lead to your failure , here's a link for a 30 amp unit if you are running extras .
    https://diygolfcart.com/golf-cart-vo...-to-12v-30-amp
    Oct 2011
    ARIZONA
    thanks, I think I have to get to the bottom of why there's not 48 volts to converter.
    there are no accessories off the 12 volt bar.
    Oct 2011
    ARIZONA
    ok, so I rechecked my findings and used the ground lug on the controller in stead of chassis that gave me my 49.0 volts apparently you can't use the chassis as a ground connection.
    using that ground I do have 49.0 volts at the converter. but nothing coming out, so I will order a converter.
    Upper Peninsula
    67 times
    Which converter are you ordering ?
    Regular Member EVcruise's Avatar
    Mar 2014
    Clinton. MS
    27 times
    Ronzbobcat none of the 48 volt Ev or golf cart have a chassis ground. On the Polaris EV the 12 volt ground is on of the 3 prongs under the hood by brake master cylinder or for 48V the controller or passenger side back battery negative post.
    2011 Ranger EV
    ITP Terra Cross Front 25x12x8/ Rear 25x10x12
    2" Motoart lift kit
    Thunder Hawk Front mud shields and Fender Guards
    Rear custom under bed mud shields with fender flares
    Front fender flares
    Battery minder 48v Battery maintainer/Desulfator
    Battery Tender 800 charger for winch batteries
    Pro fill Battery watering system
    Super Winch 4500 Terra Pro
    Superwinch LT2000 mounted on cargo Box
    Polaris Lock n Ride roof
    Polaris Lock n Ride rear windshield
    Kolpin Lexan Full Tilting windshield
    Camo Shock covers
    Cargo light
    Eagle Eye back up lights
    Custom Bow and Gun Racks
