Ranger EV to be charged by solar panel ...
This is a discussion on Ranger EV to be charged by solar panel ... within the Ranger EV Discussions forums, part of the Polaris Ranger Forums category; Just bought a Ranger 2017 and I want to charge the 48V string of battery directly by the voltage coming from my solar charge controller ...
  • 1 Post By yooper265
  • 1 Post By OrPist
Thread: Ranger EV to be charged by solar panel ...
    Starting Member OrPist's Avatar
    Just bought a Ranger 2017 and I want to charge the 48V string of battery directly by the voltage coming from my solar charge controller ( don't have access to grid at my cabin) .
    Anybody has already done that ?
    Veteran Member yooper265's Avatar
    Upper Peninsula
    76 times
    Is your solar panel output 48 vdc ?
    Do you have inverters for 120 ac for the cabin ?
    Yes my solar panels are 48V and I would prefer to go directly with the DC voltage
    instead of using an inverter ( probably more efficient that way and cheaper)
    Regular Member Xfaxman's Avatar
    Jan 2015
    Central Oklahoma
    19 times
    Let us know how it does.
    Hold the Control key down and click on a picture or a Link, to open it in a new Tab.
    Will do it , planning to do the installation in may !
    Upper Peninsula
    76 times
    To charge your 48 volt ranger you will need charging voltage around 54 volts , what's the output on one of your panels ?
    Even though they may state 48 volt on the specs they may put out more ?
    I doubt you would need a voltage regulator , you frostbacks don't get enough sun in one day to overcharge it
    LOL ! You 're right about the sun over here
    But will use it only from spring to fall .
    Of course a 48V system will need 58V to charge the batteries , any charge controler associated with 48V solar panel will work !
    So far , according to the technical spec, the Delta Q Quick charger provide only a 48V with 1KW max ... so far , it should work !
    Upper Peninsula
    76 times
    If you don't have one already here's the perfect excuse to get a Honda 2000 watt generator to power the ev battery charger .
    OrPist likes this.
    (DJ) Veteran Member DJWorm's Avatar
    Oct 2012
    Erie, Pa.
    36 times
    For charging the EV LSV drive batteries OFF Grid:
    1. I use a Polaris P2000i Digital Inverter/Generator
    2. Developing an on-board solar system consisting of:
    - a bed box mounted over-roof rack (tiltable to sun angle)
    - 2 thin film 12v 100w solar panels connected in series
    - a waterproof 12v > 48v charge controller
    - voltmeter/ammeter (to measure optimal sun angle)
    - ON/OFF switch
    (The solar system is not intended to be the primary charging system but rather a range extender and maintainer OFF GRID. However it can be used as the primary system over long interval use.)
    For charging the EV LSV ON GRID:
    3. Updated Delta Q Charger
    - Battery Minder OBD-48 48v Desulphator
    For charging the EV LSV winch batteries I have already installed:
    4. ON GRID (to supplement)
    - an on-board plug-in 120v > 12v 2 amp charger/maintainer/desulphator spliced into the Delta Q 120v input
    - temperature thermistor for temperature compensation
    (Battery Minder 2012-AGM 12v 2 amp charger/maintainer/desulphator)
    5. OFF GRID:
    - an on-board solar 12v > 12v 1.25 amp charge controller/maintainer/desulphator (AGM)
    - 15 watt solar panel
    - an ON/OFF switch
    - battery condition monitor
    - solar panel mounted on Siezmik hood rack
    (Battery Minder SCC-15 12v solar charger/maintainer desulphator)
    2011 Polaris Ranger EV LSV, OEM Winch, Back Glass, Rear Bumper, Brush Guard, Roof, Glacier II Plow with 5' Razor Blade, EV Motor Cooling Kit. GPS Speedo/Odo, Battery Mats, Battery Watering System, Battery Fluid Level Detectors, 1/2" full length Poly Skid Plate with Side Pod Wings, Safety Triangle, LED license plate mount, 6' whip antenna with flag and white strobe, collapsable billet whip mount, Polaris cover, 2" ball hitch. Good Day bed rack, game carrier, overhead gun rack, Moose gun rack. Gun dog bed kennel. Seizmik hood rack, light bar with 18w spot & 9w flood lights, outside rear view mirrors, rear view mirror, interior light. Superbright 18" HD dual row 45W amber LED fog light bar, 18w rear red LED fog. Battery Minder 12v, 1.25A Solar Charger/Maintainer/Desulphator with 15 watt solar panel and battery condition monitor, Battery Minder 120v > 12v, 2A Charger/Maintainer/Desulphator wired to Delta Q input, Battery Minder OBD-48 48v Desulphator. Thunderhawk inner fender guards, fender guards, A-Arm guards, cargo box seal kit. Highlifter Signature 2" lift Kit, Steering Stop Kit, Outlaw DHT front axles, Pro Series forward A-arms, Delrin bushings,1.5" billet wheel spacers. Moose 387 wheels, GBC Afterburn Street Force tires. Moose spare tire mount. Aluma UT 10 trailer. Polaris p2000i inverter/generator for backup recharging off grid. Pending: solar charging system, double adjustable shocks.
    Thanks a lot DJWorm
    I'm actually preparing a setup with the following
    a. 2 265W (24V) solar panel ( one of the two will be on the roof of the Ranger)
    b. 1 48V MPPT controller with 12-24-48V capabilities , will convert 24V (36V) from the panels to 48 V toward the batteries (58V)
    The controller will charge directly the 8 batteries
    the maximum current will be about half or less than the included "Delta-Q_QuiQ1000 (18 Amp) "
    dedicated :
    2 X 265W= 530W /58 = 9 Amp
    For a peak :
    Will also add a switch to redirect another bank of solar panel of 360W from the chalet adding another 6 amp
    this will bring an equivalent 15 Amp comparing to the normal Delta-Q charger 18 amp
    Will install all this in a month or two .... will keep you informed with pics
    yooper265 likes this.
