oil change in a 2009 ranger crew
This is a discussion on oil change in a 2009 ranger crew within the Ranger Technical forums, part of the Polaris Ranger Forums category; Could someone please direct me to a sticky detailing step-by-step directions on changing the oil in my 2009 polaris ranger crew?...
Results 1 to 6 of 6
Thread: oil change in a 2009 ranger crew
    (John) Starting Member mach1john's Avatar
    (Jeff) Regular Member Wrench81's Avatar
    Yuma, AZ
    I cannot but I can give you pointers. Remove the drainplug, it is a metric allen and will be very tight. let it drain and reinstall the plug but don't try to put it back as tight as it was you should just need to snug it. Swap the filter which is not tricky, screw on the new one making sure it's straight and spins on freely until the gasket contacts the sealing surface then tighten another 1/4 to 1/2 turn by hand. Pour in 2 quarts of new oil through the dipstick tube then start and run the engine for a short time, kill it and check the oil level. 2 quarts is a slight overfill but I understand most people have been running it as such. Check fluid levels and conditions in the other 3 boxes then go have fun. HTH
    '09 XP
    Belts are cheap. Go have fun!
    Know guns, Know safety, Know freedom
    No guns, No safety, No freedom
    (Ken) 1000+ Member Roadrunner's Avatar
    Casa Grande, AZ USA
    99 times
    The engine oil drain plug is a 6mm allen. Use caution on the rear diff drain plug and do not over tighten it or you may strip the threads out. I think the shop manual states 17 in pounds of torque to tighten it. That is not a lot.
    Ken
    1324 Roadrunner 12/29/05
    Casa Grande, Arizona
    www.3dflags.com
    41 times
    John, Remember to lube the rubber gasket on the new oil filter with fresh oil before installation. Exercise caution when reinstalling the drain plug - hand start it first to insure it's not cross threaded - as stated previously - do not over tighten the drain plug. After starting and while it's running - check for leaks.
    Lucas Oils: ChiefMorton posted this info,
    Engine - Lucas 0W-40 2 quarts
    Front Diff - Lucas 75/90 gear oil, 5 oz.
    Rear Diff - Lucas 75/90 gear oil, 18 oz.
    Tranny - Lucas Semi-synthetic Sure Shift Transmission fluid, 15.2 oz
    JL Squared Inc offers two "Lucas Oil" Oil Kits
    1.) Complete Lubricant Change w/ oil filter 2.) Oil w/ oil filter.
    1.) Complete Lubricant Change Kit includes
    2 quarts - 0W40 synthetic Motorcycle oil
    2 quarts- Syn 75/90 Gear Oil
    2 quarts- Semi- Syn ATF
    Oil Filter
    Price For PRC members $48.00 Plus shipping
    Retail $ 66.99
    2.)Oil Change Kit
    2 quarts 0W40 Synthetic Motorcycle Oil
    Oil Filter
    Price For PRC members $23.00 Plus Shipping
    Retail $30.99
    You can order these kits by email at LeAnn@jl2inc.com or place order by phone @ 317-783-3340.
    Yuma, AZ
    Quote Originally Posted by RZR Rich
    John, Remember to lube the rubber gasket on the new oil filter with fresh oil before installation. .
    Yessir and make sure the old filter gasket is still attached to the old filter. I shoulda mentioned that.
    Quote Originally Posted by Roadrunner
    Not much at all that aluminum is soft...
    '09 XP
    thanks everyone!!!
09 polaris ranger oil plug
2009 polaris ranger crew oil filter location
2009 polaris ranger oil
2009 polaris ranger oil change
how much oil does a polaris 2009 ranger crew
how much oil goes in 2009 polaris ranger crew
how to change oil in polaris ranger freedom
oil change 2009 polaris ranger
oil change on polaris ranger crew cab 2009
polaris ranger 2009 oil change
