how can i remover rev limiter?
This is a discussion on how can i remover rev limiter? within the Ranger Technical forums, part of the Polaris Ranger Forums category; my 09 ranger 800 hits rev limiter at abou 56 or 57 mph on gps and i would like to have it removed. any products ...
Results 1 to 10 of 14
Thread: how can i remover rev limiter?
    (Kevin) Starting Member boombastic's Avatar
    Zhiibaahaasing Ontario
    my 09 ranger 800 hits rev limiter at abou 56 or 57 mph on gps and i would like to have it removed. any products that can do this?
    2010 ranger xp LE 800
    2007 GMC Crew cab( 13 sce 1/4 mile)
    2008 Arctic cat Z1 Turbo
    467 times
    You could have the ECU reflashed to raise the limiter.
    (Steve) SSW Moderator slane01's Avatar
    Sep 2007
    Attica, Michigan
    As Jerry said, get with a company like DDP to have the ECU Reflashed to raise the rev limiter. You don't want it completely removed as you may damage your engine. However, companies like DDP can reprogram it to a higher rev limit, but still stay within a safe range.
    If you want more overall power, you can also consider getting a Cam, ported head, bored throttle body, fuel controller, and clutch kit from DDP. Your machine will really wake up then
    Steve Lane
    PRC Member# 5117
    Sidexside World Member# 152
    2010 Red Ranger Crew, Polaris Tip-out Windshield, Rear Panel, & Steel Roof and Boss Snow Plow from Ball Equipment.
    (Curt) PRC Team Leader carnivore's Avatar
    Mar 2006
    Grand Ledge, Michigan
    255 times
    I agree with the first two, a 7000 RPM ECU from someone like DDP will raise your rev limit, but to get real performance you will need to get rid of the stock cam. The cam will run out of power before you hit the new raised rev limit.
    Curt
    2012 RZR XP4 900 from Ball Equipment
    Racer Tech:
    Roll cage, Nerf bars, A arms, and bumper,
    DDP clutch
    (Paul) Veteran Member ptysonjr's Avatar
    Melissa, TX
    Quote Originally Posted by carnivore
    Where would someone around Dallas, TX get this done?
    2009 Polaris Ranger H.D. - Dirty Dawg Clutch, Interco 27" Reptile Tires, ITP SS212 Black Rims, Polaris Premium Tip Out Windshield, Polaris Soft Back Panel, 2" Front End Lift, Polaris 4500 lb. Winch, Polaris isolator kit with manual assist switch, 2nd battery (30 Amp), Pure Polaris Rear Bumper, JetOffroad HID Converted Headlights, FootSaver Kit, Polaris Dash Insulation Kit, Under Seat Insulation Kit, Pro Box Roof w/Sony Head Unit
    Mar 2006
    255 times
    Quote Originally Posted by ptysonjr
    I'd call DDP, Dale has shops all over he deals with and Im pretty sure he has some in Texas.
    Curt
    Racer Tech:
    DDP clutch
    (douglas) Veteran Member doug63's Avatar
    United States
    It's easy to do but I would not recommend it. doug
    (Joseph) Elite Member HavasuJoe's Avatar
    Dec 2007
    Lake Havasu City
    Quote Originally Posted by doug63
    "Roads............Where we're going, we don't need roads."
    Mar 2006
    255 times
    Quote Originally Posted by HavasuJoe
    X2!
    Curt
    Racer Tech:
    DDP clutch
    (Todd) 1000+ Member LaDSM's Avatar
    Chino, California
    The stock soft rev limiter is 5900 and hard is 6100. THe crank will stay straight up to around 7000 RPMs. I had mine clutched their with my old cam that didnt make alot of torque. With my new cam I am round 6500 RPMs and it is fine.
    THe Turbo guys running over 7000 RPMS weld the 2 halfs of the crankshaft together and they are good to 9K
2005 polaris 700 ranger rev limiter
how to increase rzr rev limiter
nj polaris limiter removal
polaris ace rev limiter
polaris ranger rev limiter
polaris ranger revlimiter switch location
polaris ranger speed limiter
removing speed limiter on 2015 polaris ranger crew
rzr 800 rev limiter
throttle limiter on my 2014 polaris ranger 900 crew
