code 51
This is a discussion on code 51 within the Ranger Technical forums, part of the Polaris Ranger Forums category; does anyone know what this code means and how to fix it?...
Results 1 to 7 of 7
Thread: code 51
    (Michael) Regular Member mikedirtbike's Avatar
    May 2010
    walker,wv
    code 51
    (Cesar) 1000+ Member Cesar's Avatar
    Nov 2007
    Greeneville, TN. USA
    Take a look at this:
    51: Injector 1: Open Load
    51: Injector 1: Short Circuit to Ground
    51: Injector 1: Short Circuit to Battery
    I pulled this off the important parts page on our forum. Not sure how to fix it but I'm sure Carnivore or others will chime in soon with a fix.
    2010XP, 2" Prolift, 26" Bighorns on ITP SS 108, Polaris steel cab, tool bar with spare tire mount, EMP cv boot guards, dual batteries, Viper 4000 lb. winch, fog lights, reverse lights, cab light, extreme front bumper, SuperATV extreme rear bumper, SuperATV curved front fender protectors, HID lights, Polaris custom steering wheel, Polaris running boards, Rugged Ridge fire extinguisher holder, Big Sky gun rack, Dual storage boxes, Maier Custom Hood, OTRATTW switches, Imperial Aux. fan., BA Forward A Arms.
    "keep your powder dry"
    "When in doubt...choke them out!"
    May 2010
    walker,wv
    Quote Originally Posted by Cesar
    I don't understand what that means.. this is my first FI motor.
    (Ken) 1000+ Member Roadrunner's Avatar
    Casa Grande, AZ USA
    101 times
    What year model is your Ranger? These codes mean different things. Could be a broken wire in the fuel injector harness right at the fuel injector, could be a broken TBAP harness wire. On my 2006 Ranger it was the PCM that was tossing false codes. So we need a bit more info so we can try to help you.
    Ken
    1324 Roadrunner 12/29/05
    Casa Grande, Arizona
    www.3dflags.com
    May 2010
    walker,wv
    Quote Originally Posted by Roadrunner
    sorry about that..I have a 2010 ranger 800 xp. yesterday out riding i seen the wrench fashing on the gauge so i turned the key off and on. Like i've read on here and got the 51 code..
    (Adam) 1000+ Member POS POLARIS's Avatar
    Mar 2009
    north country
    270 times
    not to rain on everyone's parade here but injector codes on these units don't mean much.
    on both our 06 and 07 they have BOTH injector codes and have no running problems. These units will throw the codes for injectors even when the machine is running fine. I'm not saying that you couldn't have a problem, but if your ranger is still running fine and nothing has changed that you've noticed, I wouldn't lose a moments rest about it. our 06 ranger has had those codes since I bought it at 780 hours and still has them running the same injectors at 1950 hours. no problems.
    I talked to a few polaris techs about this and they've run into the same issue. if an injector starts running slightly outside of the computers tolerances for it, it will throw the code even when it's running fine...
    you could put a new injector in, but I would strongly advise that you're wasting your money.
    if it is running poorly, then I'd do like others suggested. check the wiring and connectors for the injectors, see if you can find any wires rubbed through or a loose connector.
    Good luck!
    -2006 700xp 2300hours /traded/
    -2007 700xp 1650hours /traded/
    -2012 ranger Diesel TURBO'D / 600 hours/traded/
    -2011 ranger XP / 1450 hours
    -2011 ranger XP / 2100 hours
    -2012 ranger HD / 1850 hours
    How many liberal progressives does it take to defend America?
    No one knows… they’ve never tried.
    May 2010
    walker,wv
    Quote Originally Posted by POS POLARIS
    Good luck!
    thanks for the info..I'll try and pull some wire connectors and maybe put some dielectric on them to see if that's it.
2010 poaris ranger 800 what is code 51 mean
code 51 2010 polaris ranger 800 xp
polaris error code 51 on ranger xp 800
polaris ranger 800 code 51
ranger code 51 fix
