Adjustment of Valves on 2008 Ranger 4x4 500 EFI
This is a discussion on Adjustment of Valves on 2008 Ranger 4x4 500 EFI within the Ranger Technical forums, part of the Polaris Ranger Forums category; Hello Do I need to have the valves adjusted on my machine as part of routine maintenance? I was under the assumption that the valves ...
Thread: Adjustment of Valves on 2008 Ranger 4x4 500 EFI
    (Bruce) Starting Member hsgsports's Avatar
    Aug 2007
    Hello
    Do I need to have the valves adjusted on my machine as part of routine maintenance? I was under the assumption that the valves are hydraulically adjusted and don't need to be manually adjusted.
    285 times
    Yes, the 500's require periodic valve adjustment. The 700 and 800 do not.
    Aug 2007
    thank you
2008 polaris ranger 500 valve settings
polaris 500 ranger valve adjustment
polaris ranger 500 valve adjustment
valve adjustment polaris ranger 500
valve adjustment polaris ranger efi500
valve setting on polaris 500 ranger
