Adjustment of parking brake
This is a discussion on Adjustment of parking brake within the Ranger Technical forums, part of the Polaris Ranger Forums category; Anyone know how to get some more "bite" outta the parking brake on 12 ranger? mine seems pretty weak! Thanks...
Results 1 to 8 of 8
Thread: Adjustment of parking brake
    (Panhead) Regular Member JonnyBones's Avatar
    Oct 2011
    East Central, Florida
    2012 Polaris Ranger Xp EPS Browning edition
    30" outlaw radials on diesel wheels
    3" HL lift kit
    Gorilla axles on rear
    HL steering stops
    extended front wheel tubs
    Rear spotlights
    GPS
    lock and ride boxes
    lock and ride gun scabbards
    pair of 24 led 4" lights
    warn winch
    diamond plate top
    Oct 2011
    C'mon I know one of you guys knows how to adjust the parking brake on 12 ranger
    3" HL lift kit
    HL steering stops
    Rear spotlights
    GPS
    lock and ride boxes
    warn winch
    diamond plate top
    pwm
    pwm is offline
    (Phil) Rally Committee pwm's Avatar
    Knoxville, TN
    6 times
    If it is like my 10, there is a cable with an adjustment nut on the end. CW to tighten if I remember correctly. Get used to it because it is another terrible Polaris design and you will be doing it very often.
    2010 Ranger XP 800
    PP Windshield F&B, EMP EXT Bumper, Warn 40XT, Kobalt Box, Backwoods Armor 2" Lift/Arched Forward A-Arms, ProArmor Doors, DJ Fab Heat Shield, KFI Front Hitch, UTV Tech Mud Guard & Grill Insert, Crow 4-point Harness, Hi Lift Jack, 27" Horns, SS108's, Garmin 76csx, IPOD 80GB w/Otter Box, ATV Trail Tunes Sounds, Dual Battery Setup, 2-way Radio, PWM Built Spare Tire/Gas Carrier, Diamond Back Top & Floor Mats, HID's, FlexSteel Seats
    PWM's Pix
    Oct 2011
    Thanks where is the nut on the cable located?
    3" HL lift kit
    HL steering stops
    Rear spotlights
    GPS
    lock and ride boxes
    warn winch
    diamond plate top
    pwm
    pwm is offline
    Knoxville, TN
    6 times
    At the end were the brake pads are located under the bed on the drivers side.
    2010 Ranger XP 800
    PWM's Pix
    (Darcy) Elite Member darcydw's Avatar
    Sep 2006
    Valleyview Alberta
    Perhaps the old fix will work: Nethawk's E-Brake Fix [url=http://www.prcforum.com/viewtopic.php?t=377] I don't know how new of machines this applies to. Clearances may be an issue.
    I put heavier brake pads on mine like Nethawk's plans use which worked great. At least until someone put the brake on too lightly and forgot to remove it when driving. Then it went back to same old, same old.
    Darcy
    2012 Rhino 700 Red, 26" Terra Cross
    2009 Grizzly 700 EPS camo, 26" MudBugs (His)
    2009 Grizzly 550 EPS camo, 26" MudBugs (Hers)
    (DARRELL) Elite Member brokenparted's Avatar
    PASS CHRISTIAN MISSISSIPPI
    On my 2010 if the park break handle is applied any amount at all , the electronics will produce a engine stutter to remined you it is on
    My life is an open book...Just aint many pages!!http://i1137.photobucket.com/albums/...y2010002-2.jpg
    (Laud) 1000+ Member Whtshos's Avatar
    DFW TX
    Shims (fender washers) help a bit also.
    If I remember right, I put them behind the plate that rides on the three bearing balls that apply the pressure.
    --'09 700XP-- Home made roof, Dual Batteries,Viper 4500 synthetic, EMP CV Guards, Whelen Strobes
    2" Pro Lift, Snorkeled, blinkers, 55W Aux Lights w/guard, remote spotlight, STI 14" Blades/27" TSL Radial Swampers, Nerf Bars
    --'09 Browning Crew-- Viper Max 5000, 2" lift, Full Roof and Rack, Forward A-Arms, 27" Bighorns, Strobes
    Odyssey Batteries, Tunes on Top, EMP full Windshield, Nerf Bars, Front Brush guard with wrap sides.
2012 polaris ranger brake adjustment
how to adjust parking brake on 2010 polaris ranger
how to adjust parking brake on polaris ranger
how to adjust parking brake on polaris ranger 500
how to adjust parking brake on polaris ranger 800 crew
how to adjust parking brake on ranger 700 xp
parking brake on a 2010 polaris ranger 800
polaris ranger 800 parking brake adjustment
polaris ranger park brake adjustment
polaris ranger parking brake adjustment
