Stalling and surging 2010 ranger 6x6 800 EFI
This is a discussion on Stalling and surging 2010 ranger 6x6 800 EFI within the Ranger Technical forums, part of the Polaris Ranger Forums category; We use our Ranger on the farm to haul hay and plow snow, and check fences, generally get around the property. Our 2010 6x6 Ranger ...
Results 1 to 8 of 8
Thread: Stalling and surging 2010 ranger 6x6 800 EFI
    (JK) Starting Member Serenity Acres's Avatar
    Dec 2011
    St Clairsville
    We use our Ranger on the farm to haul hay and plow snow, and check fences, generally get around the property. Our 2010 6x6 Ranger started sputtering and stalling while still under warranty. It is unpredictable in this behavior but certainly handicapping when it occurs. We took it back to the dealer and they sent it back stating they could not reproduce the problem. It has continued to sputter and stall unexpectedly, every few days or so, often completely stalling out. Sometimes it runs better after restarting from a stall, sometimes it keeps sputtering. Recently it started surging upon startup, a dangerous situation which nearly put one of us over the hill. We then promptly sent it back to the dealer and they said "the throttle cable was bound up at the gas pedal". Supposedly fixed it, changed oil & filter and $212.49 later, it's still stalling out and who knows if the engine is going to rev on its own again and take off full throttle like it did before.
    Until it's fixed it's going to be called Danger instead of Ranger.
    Welcome to PRC.
    Is it showing any codes?
    Dec 2011
    St Clairsville
    Stalling/surging
    One code on throttle this last time which the dealer cleared TPS learn error
    I would suspect a broken wire to the TPS or IAC (idle air control).
    (Alan) 1000+ Member Rockin Ranger Rider's Avatar
    J.K. and good luck isolating the problem
    65 times
    Welcome to the PRC JK.
    Veteran Member Walkthedog's Avatar
    Apr 2006
    10 times
    I'm having the same problem, btw... Replaced the Tbap and still doing it...
    Is there a pointer to a thread with the fix with the TPS and the Idler Air thingy?
    Dec 2011
    St Clairsville
    Still stalling
    Still stalling out. Also when it came back from dealer repair the steering column is messed up. Tilt wheel function won't lock and the steering wheels all over the place! Not happy!!
12 800 ranger surging at idle
2010 polaris ranger 500 power surge
2010 polaris ranger 500 surging
2010 polaris ranger 800 stalling
2011 polaris ranger 800 engine surges under load
2011 polaris ranger 800 stalls
2011 ranger 6x6 stalling
polaris ranger 800 missing and fast idle
polaris ranger 800 stalls delay cranking
polaris800 ranger stalls
