Rev/Speed Limiter
This is a discussion on Rev/Speed Limiter within the Ranger Technical forums, part of the Polaris Ranger Forums category; Hi...Does anyone know if there is a way to disable the Rev/Speed Limiter on the 500efi?...
Thread: Rev/Speed Limiter
    (Trent) Starting Member TSG31t's Avatar
    Jun 2012
    Minnesota
    Rev/Speed Limiter
    2012 Ranger 500 EFI - 14'' Diesels with 26'' Moto MTC Tires. Speedwerx Hot Seat slip on pipe. More to come.
    https://lh5.googleusercontent.com/-n...00/Revised.jpg
    (Ruben) Starting Member yimcyco's Avatar
    Jan 2012
    tenesssee
    limiter
    there should be a spacer in drive clutch that can be removed acts as a speed limiter
    (Thomas) Starting Member Hellion25's Avatar
    Apr 2013
    NE FL
    Any more help
2009 polaris ranger 500 efi rev limiter
2009 polaris ranger 500 speed limiter
disable polaris governor
disable rev limiter on 500 efi
how to remove governor on polaris ranger
polaris ranger speed limiter
remove governor polaris ranger
remove polaris ranger 500 efi rev limiter
remove rev limiter polaris ranger 500 efi
