Turf Mode?
Turf Mode?
This is a discussion on Turf Mode? within the RZR Technical forums, part of the Polaris RZR Forums category; I know this has been talked about before in the past but was wondering if anyone had anymore thoughts on trying to install turf mode ...
Results 1 to 10 of 14
Thread: Turf Mode?
    (Brian) 1000+ Member Chiefmorton's Avatar
    Moorefield Indiana
    35 times
    Turf Mode?
    I know this has been talked about before in the past but was wondering if anyone had anymore thoughts on trying to install turf mode on the RZR. I know we've got some pretty sharp members on here when it comes to wrenching on these things. The RZR is a sport machine where posi-trac is nice but there's times when single track would be nice as well, pulling in and out of the garge on the concrete, turning around on blacktop county roads, turning in the yard and not to mention it would make them steer a little easier. I could be way off base but I think it would be a nice feature for the RZR that several folks would like.
    Brian M.
    Moorefield, Indiana PRC #1240
    2016 Velocity Blue 900 H.O. Crew
    Polaris Sport Roof
    Polaris Glass Windshield
    Polaris Lock & Ride Rear Window
    Marshall Motoart 2.5" Lift
    27" Bighorns on STI HD6 Wheels
    Super ATV Front Bumper
    Badlands 5000# Winch
    Hunterworks Clutch Kit with Roller Secondary
    Another member (can't remember his name) has worked on a solution to that for a while, but I don't think he has come up with an answer yet. I find the strangest part to be that the UK model has the turf mode, but Polaris decided to delete that on the US version .
    If the solenoid is already in place and just not hooked up (I have no idea if that's the case), you could simply run a hot wire and toggle switch to enable it.
    (Larry) Veteran Member Nitehawk's Avatar
    Hungry Horse Mt
    UK Specs
    FEATURES OVERVIEW
    SPECIFICATIONS
    VIDEOS
    PHOTOS
    COMPARISONS
    REVIEWS
    SPECIFICATIONS
    RANGER RZR® 4 800 EPS ROBBY GORDON
    SHARE
    Engine
    Engine Type 4-Stroke Twin Cylinder
    Displacement 760cc High Output (H.O.)
    Fuel System Electronic Fuel Injection
    Cooling Liquid
    Drivetrain
    Transmission/Final Drive Automatic PVT H/L/N/R; Shaft
    Drive System On-Demand True AWD/2WD/ VersaTrac Turf Mode
    Engine Braking System/ Active Descent Control Not Equipped
    Suspension
    Front Suspension Dual A-Arm 9.6" (24.4 cm) Travel
    Rear Suspension Dual A-Arm, IRS 9" (22.9 cm) Travel
    Brakes
    Front/Rear Brakes 4-Wheel Hydraulic Disc with Dual-Bore Front Calipers
    Parking Brake Hand-Actuated
    Tyres Wheels
    Front Tyres / Model 25 x 10-12; 489
    Rear Tyres / Model 25 x 11-12; 489
    Wheels Stamped Steel
    Dimensions
    Wheelbase 76" (193 cm)
    Dry Weight 1,257 lb (570 kg)
    Overall Vehicle Size (LxWxH) 114 x 60 x 76" (290 x 152 x 193 cm)
    Ground Clearance 12" (30.5 cm)
    Capacities
    Fuel Capacity 9 gal (34.1 L)
    Bed Box Dimensions (LxWxH) 36.5 x 54 x 11.5" (93 x 137 x 29 cm)
    Box Capacity N.A./1,000 lb (453.6 kg)
    * Models approved for sale in California are limited to 600 lbs cargo box capacity (rear payload capacity per CARB classification) and1100 lbs total vehicle payload.
    Payload Capacity 1,500 lb (680.4 kg)
    Hitch Towing Rating 2,000 lb (907.2 kg)
    Hitch/Type Standard/2" Receiver
    Features
    Cargo System Lock & Ride
    Lighting 55W low/ 60W high, LED Tail
    Electronic Power Steering Standard
    Instrumentation Digital Gauge, Speedometer, Odometer, Tachometer, Tripmeter, Hour Meter, Clock, Gear Indicator, Fuel Gauge, Hi-Temp/Low-Batt Lights, DC Outlets (2)[u]
    2011 500 EFI
    Custom stuff- Body wrap-Top-Rear bumper-2" lift-Spare tire holder-Fuel pack mount
    Polaris rear mud blockers
    26" Maxxis BigHorns
    Rhino Front Axles
    HID's & 12" Led light Bar
    Moorefield Indiana
    35 times
    Boy that is weird. I didn't realize the UK models came with turf mode, wouldn't it have been easier for Polaris to just put it on all of their RZR's regardless of where their shipped lol. I appreciate the information guys at least this tells me it can be done, just have to figure out the details, thanks.
    Brian M.
    Polaris Sport Roof
    Moorefield Indiana
    35 times
    I've been doing a little parts research and in the process actually found a guy who'd converted his to have turf mode. A very nice writeup with all the details and pics. The bad part is the project will cost approx. 1200.00 in parts. You have to order the rear diff parts for the international RZR-4 and as another added cost you have to use the international ECU or a cheaper route by using a relay and bypass the ECU. The writeup gave the details on the relays and wiring. I would love to have the turf mode but it won't be cheap.
    Brian M.
    Polaris Sport Roof
    (Dennis) Regular Member 34ford's Avatar
    North Carolina
    You probably found my website and forum devoted to the turf mode diff for the RZR.
    Moorefield Indiana
    35 times
    Quote Originally Posted by 34ford
    Yes I sure did excellent job by the way! I hope to do this to mine someday with any luck.
    Brian M.
    Polaris Sport Roof
    Yeap, Dennis was the one that I was trying to think of (I'm horrible at remembering names ). I din't realize that he had finally found a solution....albeit, an expensive one. A man can buy a liot of tires for $1200.
    North Carolina
    Ah, but thats just the beauty of turf mode. Now my tires dont scrub.
    Turning radius is smaller too.
    Oh, I'm sure. I have so much weight on the rear of my Ranger that I get a lot of traction back there and the difference in turning radius is significant with the diff' locked.
polaris ranger turf mode
polaris ranger xp 900 versatrac turf mode
polaris rzr turf mode
polaris versatrac turf mode
turf mode delete
versa trac turf mode
versatrac turf mode
versatrac turf mode ranger
what is polaris versatrac
what is versatrac turf mode
