2009 700 ranger xp starter problem
This is a discussion on 2009 700 ranger xp starter problem within the Ranger Problems & Solutions forums, part of the Polaris Ranger Forums category; my ranger starts fine when its cold but once it warms up it will not start at all ,when i try turning it over the ...
Results 1 to 10 of 14
Thread: 2009 700 ranger xp starter problem
    (adrian) Starting Member misterman39's Avatar
    Jun 2009
    prince george,british columbia
    my ranger starts fine when its cold but once it warms up it will not start at all ,when i try turning it over the starter makes a loud whining noise.
    (Mark) Veteran Member simoniz's Avatar
    Dec 2007
    Browns Summit NC
    It's probably the starter bendix. Mine has went bad on my 09 Ranger.
    2008 Yamaha Grizzly 700 EPS
    2012 Liquid Silver XP900
    2012 Liquid Silver XP4 900
    2012 Suzuki DRZ400S
    2012 Suzuki V-Strom Adventure
    06 Triton TR20 w/225 Mercury ProXS
    2012 Dodge 3500 Dually "DIESEL POWER"
    (Curt) Retired Moderator carnivore's Avatar
    Mar 2006
    Grand Ledge, Michigan
    430 times
    We have heard of that a few times here on the 09s. Like simonize said its likely the bendix.
    Curt
    2012 RZR XP4 900 from Ball Equipment
    Racer Tech:
    Roll cage, Nerf bars, A arms, and bumper,
    DDP clutch
    (Harvey) Regular Member BDSUSA's Avatar
    Feb 2009
    Kuna, Idaho
    My starter would not engage when hot with less than 50 hours - - the dealer replaced the bendix (warranty). Sounds like this might be a common problem with the '09 XPs.
    (Laud) 1000+ Member Whtshos's Avatar
    DFW TX
    Ours is going in for the same problem tomorrow along with a 22 code. I'll let the warranty take care of it before it runs out.
    --'09 700XP-- Home made roof, Dual Batteries,Viper 4500 synthetic, EMP CV Guards, Whelen Strobes
    2" Pro Lift, Snorkeled, blinkers, 55W Aux Lights w/guard, remote spotlight, STI 14" Blades/27" TSL Radial Swampers, Nerf Bars
    --'09 Browning Crew-- Viper Max 5000, 2" lift, Full Roof and Rack, Forward A-Arms, 27" Bighorns, Strobes
    Odyssey Batteries, Tunes on Top, EMP full Windshield, Nerf Bars, Front Brush guard with wrap sides.
    (BILLY) Starting Member BADDAD's Avatar
    Aug 2009
    TUCSON AZ
    my friends 2008 does the same thing but not all the time and then it only whines a couple times and it starts goodluck with that cause polaris wont throw parts at it and my buddy had his to the dealer twice with them unable to duplicate the problem my suggestion if its still under warranty take it to dealer after you have taken it on a good long ride if its not then i think the other guys are right
    Jun 2009
    fixed the problem with some grease on the bendix.
    (Raymond) Starting Member raymond88's Avatar
    East TX
    same problem here with the starter spinning free when hot. what kind of grease for the starter and bendix?
    http://onfinite.com/libraries/1572320/f50.jpg http://onfinite.com/libraries/1572340/ae2.jpg
    2009 Polaris Ranger XP 700,2" Highlifter kit, 28" AMS Swamp Fox Tires, Baja Dual upper spot lights/ Dual lower fog lights, Roof Mounted Dual Gun rack,Warn Xt 40
    Jun 2009
    Quote Originally Posted by raymond88
    i just used some polaris grease on the bendix but i still have to keep reapplying it every 2-3 months;i've also had a problem with the bolts on the cover to get at the bendix where they didn't want to bite on the threads once i took them out so i had to go with some longer bolts on some of the holes and one of them above the water pump went through a well or something and now it leaks coolant from the bolt hole. good luck!
    East TX
    Quote Originally Posted by misterman39
    Did you remove the starter at all or just the cover for the bendix. And are you referring to the Polaris Premium Starter grease or some other regular grease from Polaris. please specify thanks
09 ranger 700 wont start when hot
2009 polaris ranger 700 xp starter
2009 polaris ranger 700 xp starting problems
2009 polaris ranger 700xp starter problem
2009 polaris ranger hd starter bendix
how to troubleshoot starter on polaris ranger
polaris ranger starter problem
polaris ranger starter wont engage when hot
polsris ranger starter problem
rzr starts ok when cold but the starter whines when hot
