the check engine light?
This is a discussion on the check engine light? within the Ranger Problems & Solutions forums, part of the Polaris Ranger Forums category; well after a long ride lastnight i noticed that the checkengine lite was on and it started driving rough at lower speeds between 15 and ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: the check engine light?
    (Brian) Regular Member freekdawg's Avatar
    Jul 2009
    Richmond,Texas
    well after a long ride lastnight i noticed that the checkengine lite was on and it started driving rough at lower speeds between 15 and 25 mph like no power does anyone know what this might be on my 09 xp
    2009 Ranger XP 700 Mossy Oak Breakup
    2500 lbs Warn Winch
    24 times
    Brian, Has it provided you with any codes to start with ?
    How to read blink codes when the orange wrench light comes on:
    Turn your ignition on and off three times, leaving it on the third time. It will blink 2 codes (example: 2 blinks =2, and 1 blink = 1, to read 21)
    XP blink codes:
    21: Loss Synchronization
    22: TPS: Open or Short Circuit to Ground
    22: TPS: Short Circuit to Battery
    23: RAM Error: Defective ECU
    25: Transmission Input: Invalid Gear
    26: Vehicle Speed Sensor: Implausible
    41: Intake Air Temp Sensor: Open or Short Circuit to =Sensor Vlotage (ECU)
    41: Intake Air Temp Sensor: Short Circuit to Ground
    42: Engine Tempurature Sensor Circuit: Short to Ground
    42: Engine Tempurature Sensor Circuit: Open or Short to Battery
    45: Barometric Pressure Sensor: Circuit Low Input
    46: Barometric Pressure Sensor: Circuit High Input
    51: Injector 1: Open Load
    51: Injector 1: Short Circuit to Ground
    51: Injector 1: Short Circuit to Battery
    52: Injector 2: Open Load
    52: Injector 2: Short Circuit to Ground
    52: Injector 3: Short Circuit to Battery
    54: Engine Temperature Lamp: Open Load
    54: Engine Tempurature Lamp: Short Circuit to Ground
    54: Engine Temperature Lamp: Short Circuit to Battery
    55: Diagnostic Lamp: Open Load
    55: Diagnostic Lamp: Short Circuit to Ground
    55: Diagnostic Lamp: Short Circuit to Battery
    56: Pump Relay: Open Load
    56: Pump Relay: Short Circuit to Ground
    56: Pump Relay: Short Circuit to Battery
    58: Cooling Fan: Open Load
    58: Cooling Fan: Short Circuit to Ground
    58: Cooling Fan: Short Circuit to Battery
    (Curt) PRC Team Leader carnivore's Avatar
    Mar 2006
    Grand Ledge, Michigan
    173 times
    Rich, your awesome man, you save me a lot of typing
    Curt
    2012 RZR XP4 900 from Ball Equipment
    Racer Tech:
    Roll cage, Nerf bars, A arms, and bumper,
    DDP clutch
    Jul 2009
    Richmond,Texas
    well i did the key thing and the only code that came up was 21 then it went off and the checkengine light went off as well so is everything ok now or will it be a problem again
    btw thanks for the codes i printed it out
    2500 lbs Warn Winch
    Mar 2006
    173 times
    It suggests that for some reason your ECU wasn't communicating with the system. I would make sure the connection to the ECU is attached properly.
    Curt
    Racer Tech:
    DDP clutch
    Jul 2009
    Richmond,Texas
    rgr that i will check it now thanks
    2500 lbs Warn Winch
    Jul 2009
    Richmond,Texas
    where is the ECU
    2500 lbs Warn Winch
    Mar 2006
    173 times
    Its under the drivers side seat attached to the front wall, its black, and is about 5x5x1
    Curt
    Racer Tech:
    DDP clutch
    Jul 2009
    Richmond,Texas
    thats what i thought it was ok im checking it now
    2500 lbs Warn Winch
    Jul 2009
    Richmond,Texas
    ok checked it and from what i can tell its connected but just alittle dirty i will ride around close to the house today and see if it happens again
    2500 lbs Warn Winch
2009 polaris ranger 700 battery light flashing and check engine light on
2009 polaris ranger 700 check engine light
2009 polaris ranger 700 xp showing check engine
check engine light on 2009 polaris ranger700xp
checking codes on a 2009 ranger xp700
polaris ranger 2009 check engine light
polaris ranger 700 2009 hd check engine
polaris ranger crew check engine light
