Tire Wear
Tire Wear
This is a discussion on Tire Wear within the Ranger Problems & Solutions forums, part of the Polaris Ranger Forums category; I have a 2006 Ranger XP. In the past year I have started to notice a very inconsitent wear pattern on the front tires. Some ...
Results 1 to 10 of 13
Thread: Tire Wear
    (Marc) Starting Member mmccoyharrells's Avatar
    Nov 2009
    Ionia, Michigan
    Tire Wear
    I have a 2006 Ranger XP. In the past year I have started to notice a very inconsitent wear pattern on the front tires. Some of the tire "knobs" are close to full tread at one end, and at the other almost wore right down to the tire. The wear pattern is the same with both tires. Is this typical? Could this be from plowing the driveway in the winter in AWD?
    In the market for new tires. Any recommendations would be greatly appreciated.
    Thanks for the help!
    (Steve) SSW Moderator slane01's Avatar
    Sep 2007
    Attica, Michigan
    Is the excessive wear on the inside or the outside of the tire. If it is on the inside part of the tire, there could be some excessive sag in the front end, This could be encountered with the additional weight of the plow.
    You could install some rubber spring spacers or buy an optional front preloader kit for that model of machine which could help with the sag. You could also get a heavy duty set of front springs.
    Finally, as far as Tires go, Maxxis Bighorns will get the most votes here on PRC. They are a great all around tire, that peform very well in a variety of terrain.
    Good Luck
    Steve Lane
    PRC Member# 5117
    Sidexside World Member# 152
    http://img.photobucket.com/albums/v214/absea/prc109.jpg
    http://img.photobucket.com/albums/v214/absea/s57.jpg
    http://i254.photobucket.com/albums/h...SW_Profile.jpg
    2010 Red Ranger Crew, Polaris Tip-out Windshield, Rear Panel, & Steel Roof and Boss Snow Plow from Ball Equipment.
    Ditto on the Bighorns. They are an awesome tire for all around use.
    You may want to check the toe adjustment on your machine. Worn ball joints, wheel bearings, and tie rod ends can also cause tire wear issues. Mine wore the stock tires the same way and is doing the same to my Bighorns now that they are almost in need of replacement, so it may just be the nature of the beast.
    (Laud) 1000+ Member Whtshos's Avatar
    DFW TX
    I've noticed something similar with our 09. The front side of the lugs are worn less than the back side of the lugs.
    This is mostly on the front tires as well. Almost like the lugs are being shaven off as they leave the road surface versus first contact to the surface.
    --'09 700XP-- Home made roof, Dual Batteries,Viper 4500 synthetic, EMP CV Guards, Whelen Strobes
    2" Pro Lift, Snorkeled, blinkers, 55W Aux Lights w/guard, remote spotlight, STI 14" Blades/27" TSL Radial Swampers, Nerf Bars
    --'09 Browning Crew-- Viper Max 5000, 2" lift, Full Roof and Rack, Forward A-Arms, 27" Bighorns, Strobes
    Odyssey Batteries, Tunes on Top, EMP full Windshield, Nerf Bars, Front Brush guard with wrap sides.
    Regular Member 2008rngrrzr's Avatar
    Sep 2008
    Des Moine, Iowa
    This is caused from riding on pavement or hardpacked dirt. these tires only run 8-12PSI and when on a hard surface the roll-out of the tire is different than a regular car/truck tire radial. it is a pretty common thing. Airing up the tires will help a bit next time
    (James) Regular Member 65welder's Avatar
    Jan 2010
    Cisco, Illinois
    big horns
    I have read a lot of posts here where you all brag about bighorns. My only experience with them was bad. I watched a rzr-s with bighorns pulling out a stuck ranger and they filled full of mud and wouldnt clean out. They looked as smooth as inner tubes. my 09 xp has the pxt's on it and they seem to do quite a bit better in the same mud hole.
    2009 Ranger xp700 se: 3000lb superwinch; KFI winch mount; EMP aluminum a-arm guards; ABM 2" lift; 2" rear wheel spacers; 1.5" front wheel spacers; 28" swamp lites on black ITP SS108; fog lights; backup light; homemade soft roof; homemade cooler, toolbox, axe, and chainsaw rack. Welcome to your new addiction!
    Re: big horns
    Quote Originally Posted by 65welder
    I never claimed that they are the best for mud. There are definitely better tires for the gooey stuff......but the Bighorns are awesome for all around use......rocks, gravel, hardpack dirt, and light to medium mud. If I were a hardcore mudbogger, I would definitely choose a more aggressive tire.
    (Braidy) Elite Member aczr2k's Avatar
    Mar 2007
    NW Minnesota
    My stock front tires have a odd wear pattern as well, so does my buddies. 90% of our driving is field roads/tar. I have 2200 miles on my 07 he has around 1200 on his 08 miles. I think with the full cab and other crap on it its plenty front heavy for the size of stock tire, I have mine aired up and added the TM2 spring spacers to help out.
    '11 XP 800 LE "Orange Madness"
    '14 XP 1000 LE
    (Bill) 1000+ Member Arizona Flying Dutchman's Avatar
    Oct 2009
    Prescott Valley, Arizona
    I'm with Jerry,
    No tire is perfect for every application. Big Horns work great in a variety of different settings. I had them on my quads for almost 8000 miles and they wore in the same manner as described above. In my case I am sure that it was from pavement and hardpacked, rocky trails.
    I used them in deep mud in Eagar / White Mountains with no problems, but the deep mud here is more like clay and sticks to everything until it packs your fender wells like giant brake shoes. I don't think any tire would do well in that stuff.
    So far though, the Big Horns are the best all-around tire I have ever run across and wear really well compared to the OEM's I've had.
    I AM proud to be an American where at least I know I'm free. And I WON'T forget the men (and women) who died, who gave that right to me ... And I WILL gladly standup next to you and defend her still today ... 'Cause there ain't no doubt I love this land ... God bless the U.S.A. (Lee Greenwood)
    2015 Ranger Crew 900 EPS, White Lightening, Street Legal, Polaris Lock & Ride Poly Top, Polaris Lock & Ride Half Windshield, Multi-Mount Viper Elite EX4000 SE/Wide Spool Winch, Dragonfire Doors, Seizmik Side View Mirrors, Garmin eTrex Vista HCX GPS, Ram Mount,
    (Joe) 1000+ Member jaybey's Avatar
    Nov 2005
    Tucson- Joe
    51 times
    I filled my wheel wells and everything else up with mud elk hunting up near Flagstaff in December 2008. It was fun carrying an extra 500 pounds of Arizona around. I went to the lake twice a day to wash most of it off and start over. My Maxxis Big Horns pulled me thru it all.
    Joe in Tucson
    Freedom has a taste only those who have fought for it will ever know.
    If guns are outlawed only outlaws will have guns. An armed society is a polite society.
    FEAR THE GOVERNMENT THAT WANTS TO TAKE AWAY YOUR GUNS!
    2015 Ranger 900 XP EPS, Polaris tip out windshield, glass rear window, Polaris canvas doors. 3600 lumen driving lights, TMH 20'' Dual Row High Power 126w Cree Light Bar 13000 Lumens
    , led driving lights for back up light, EZ turn signal kit, Garmin Montana 600, UMC ATV tool/storage box, Ricochet rock sliders, home made mud blockers, in bed mounted spare tire, Big Sky roof mount gun rack, Wolo Bad Boy air horn.
    PRC # 1164
    Life Member NRA & Golden Eagle Member
    Joe - Tucson, Arizona
06 polaris ranger 700 xp wearing out my tire on the one wheel drive side
900 ranger crew front tire wear
front tires wearing on the inside on polarir rzrz
polaris ranger 800 excessive tire wear
polaris ranger front tire excessive ware
polaris ranger tire wear
rzr tires wearing funny
trouble rear tires wearing on inside 800 rzr
why do my back tires wear on the inside on polaris ranger
why does the front wheels on a polaris ranger crew wear funny
