09 Ranger Help please!
This is a discussion on 09 Ranger Help please! within the Ranger Problems & Solutions forums, part of the Polaris Ranger Forums category; Ok, Too start off I went for a big ride this weekend. Friday and Friday night it ran great. Saturday morning i noticed it started ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: 09 Ranger Help please!
    (Michael) Regular Member muddymonkey's Avatar
    Jun 2009
    Farmersville, Texas
    Ok,
    Too start off I went for a big ride this weekend. Friday and Friday night it ran great. Saturday morning i noticed it started to sputter and loose power. I was a little confused since it is only 6 months old. it just got woarse and woarse. So at this ATV park there was an on site Mech. and he ran a pressure check for me and it was at 40 pounds, but thats all he could tell me. any ideas??
    i have lots of faith that someone on here has seen this
    2010 RZR
    ITP SS108 Black
    28" Gorilla Silverbacks
    Half Windshield
    Dunertunes Audio Systeam
    HID's
    Highlifter Belt
    08 Ranger XP(SOLD)
    3" Lift
    Carbon Fiber Steering Wheel
    2 Polaris Center Console's
    ITP SS108 Black 14"
    ITP 30" Mudlites
    Half Windshield
    HID's
    HD Rhino Axles
    Highlifter Belt
    (Chase) 1000+ Member Rabbit Chaser's Avatar
    Aug 2007
    West Liberty, Ky
    Sounds like a TPS Issue or TBap issue. I would check and see if there are any codes.
    07 Ranger XP DDP Cam, DDP Clutch Kit, Boondocker, 26" bighorns
    09 RZR DDP Cam, Head porting, Bored Throttle Body, 11.2.1 Pistons DDP Complete Big Air kit DDP Custom ECU, DDP Custom Secondary Helix, DDP Adjustable Clutch Weights, LTE Dual Exhaust Watermark Custom paint, 26" Bighorn Tires on Vision 14" Buckshot wheels Dragon Fire Racing shifter, and harnesses, Racer Tech 2" lift kit, Walker Evans Racing Shocks, SuperATV 1.5" wheel spacers
    Jun 2009
    Farmersville, Texas
    how would you check the code? i ran threw all the stages with the yellow button and did not see anything differant?
    2010 RZR
    ITP SS108 Black
    Half Windshield
    HID's
    Highlifter Belt
    08 Ranger XP(SOLD)
    3" Lift
    ITP SS108 Black 14"
    ITP 30" Mudlites
    Half Windshield
    HID's
    HD Rhino Axles
    Highlifter Belt
    (Laud) 1000+ Member Whtshos's Avatar
    DFW TX
    Try this...
    --'09 700XP-- Home made roof, Dual Batteries,Viper 4500 synthetic, EMP CV Guards, Whelen Strobes
    2" Pro Lift, Snorkeled, blinkers, 55W Aux Lights w/guard, remote spotlight, STI 14" Blades/27" TSL Radial Swampers, Nerf Bars
    --'09 Browning Crew-- Viper Max 5000, 2" lift, Full Roof and Rack, Forward A-Arms, 27" Bighorns, Strobes
    Odyssey Batteries, Tunes on Top, EMP full Windshield, Nerf Bars, Front Brush guard with wrap sides.
    240 times
    Re: 09 Ranger Help please!
    Quote Originally Posted by muddymonkey
    .....he ran a pressure check for me and it was at 40 pounds, but thats all he could tell me. any ideas??
    Do you mean he ran a cylinder compression test and it was only 40 psi??? I hope that's not the case. If that is correct, then you have an issue that needs attention. Hopefully Curt or somebody will chime in to confirm, but I think cylinder compression should be up around 120 psi.
    24 times
    Quote Originally Posted by commanderjjones
    When I read that I took it as meaning fuel pressure - I'm hoping that's what he was meaning. Fuel pressure / 39 psi.
    (Curt) PRC Team Leader carnivore's Avatar
    Mar 2006
    Grand Ledge, Michigan
    137 times
    As long as he meant fuel pressure its OK. Cylinder pressure is 150. I would check the codes first, then look at the wiring at the Tbap sensor, and at the TPS. Theres even a chance the Tbap sensor is dirty. You could try cleaning it with carb cleaner. Its usually one of 4 things, Tbap issues, TPS issues, CPS issues, or fuel pump issues. Make sure your fuel tank vent is not plugged either.
    Curt
    2012 RZR XP4 900 from Ball Equipment
    Racer Tech:
    Roll cage, Nerf bars, A arms, and bumper,
    DDP clutch
    Jun 2009
    Farmersville, Texas
    yeah sorry. it was the fuel PSI. he connected a gauge right on the injection rail?
    ok so last night I washed the machine real good and seam to run alot better, but that was up and down a short road. i dont think a good bath would have fixed it. I looked at all the wires by the motor and dont think there is a broke wire, but they where real muddy.
    2010 RZR
    ITP SS108 Black
    Half Windshield
    HID's
    Highlifter Belt
    08 Ranger XP(SOLD)
    3" Lift
    ITP SS108 Black 14"
    ITP 30" Mudlites
    Half Windshield
    HID's
    HD Rhino Axles
    Highlifter Belt
    (Ken) 1000+ Member Roadrunner's Avatar
    Casa Grande, AZ USA
    30 times
    Curt, you recommend cleaning the Tmap Sensor with carb cleaner? I was told recently that we should be using a electronic cleaner for the Tmap? You have worked on more of these things than most and I assume that is the process you have been using without any problems. Just curious.
    Ken
    1324 Roadrunner 12/29/05
    Casa Grande, Arizona
    www.3dflags.com
    Aug 2007
    West Liberty, Ky
    Yeah carb cleaner, brake cleaner, and or starting fluid will work.
polaris ranger clutch problems
