Ranger is backfiring and popping ???
This is a discussion on Ranger is backfiring and popping ??? within the Ranger Problems & Solutions forums, part of the Polaris Ranger Forums category; I have a 2006 Ranger XP. I'll give a brief description of my issue. I used my ranger on Aug long weekend. It ran fine ...
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Ranger is backfiring and popping ???
    (Jason) Starting Member DENDEN's Avatar
    Jul 2007
    Alberta Canada
    I have a 2006 Ranger XP. I'll give a brief description of my issue. I used my ranger on Aug long weekend. It ran fine and there was no issues. At the end of the weekend i filled it up and parked it outside. It was pretty dirty so I left the cover off. I returned a month later and it fired right up no problem. It idles fine with no issues. But when you drive it pops and "stalls" but only at low speed. Once you get about 1/3rd of the throttle pushed it runs fine right up to full throttle. I suspected maybe bad fuel so I drained the tank and ran it out. Refueled with fresh and still the same problem. I checked the air cleaner and it is clean. Before I start taking everything apart I thought I would ask if someone has had a similar issue and what did they do to remedy it. Any and all comments would be greatly appreciated.
    Thanks , Jason
    Sounds alot like a dirty tbap or broken wires leading to it.
    Jul 2007
    Alberta Canada
    I was thinking that myself , bugs where really bad all over unit. What is the procedure to clean it?
    65 times
    The TBAP sensor is located in the air-tube between the throttle body and the air filter. Most of the time when there is an issue with the TBAP it is due to *broken/bare wires, or occasionally dirt on the TBAP. If you clean the TBAP sensor use an carburetor cleaner or an electronics type cleaner, something that WILL NOT leave any residue behind on the sensor.
    *New connecter for TBAP #2875542 Kit Harness (Repair Kit )
    Jul 2007
    Alberta Canada
    Can do , have lots of contact cleaner. It looks like it is set in a specific position. How critical is it that it goes back exactly the same way?
    Quote Originally Posted by DENDEN
    Not an issue. Just don't touch the sides as you're putting it in and get it dirty again. If yours is like mine (and it sounds like it probably is), it's a PITA to get at.
    (jason) Starting Member bassmaster1000's Avatar
    Sep 2010
    zavalla
    havin pretty much same problem out of my 2004 ranger4x4 let me know how u solve your problem please
    Quote Originally Posted by bassmaster1000
    Your '04 is likely a different issue because those 2 machines are very different......his is EFI and your is carb'd, so yours doesn't have the tbap sensor mentioned above. I responded to your other post about this issue.
    (Randy) Regular Member planter8's Avatar
    Jun 2009
    Utica, MI
    Check for error codes. I have a 2009 Crew that had a similiar problem. It turned out that I had a bad CPS. Folks here helped me diagnose it and $42 later it was cured!
    2009 Ranger Crew LE Sunset Red ~Polaris brushguards~Polaris full poly windshield~Polaris soft top and rear~Viper 4000Max winch~2 Hella 55w lights
    (MIKE) Starting Member riverranchman's Avatar
    Oct 2009
    NAPLES FL
    Sounds like it could have water in the fuel ?.
2006 polaris ranger backfiring and popping
polaris ranger 500 backfire
polaris ranger back fires
polaris ranger backfire
polaris ranger backfires
polaris ranger is backfiring
what makes a polaris ranger backfire
why does my polaris ranger backfire
why is my poliaris ranger backfiring
