backup alarm
backup alarm
This is a discussion on backup alarm within the General Member Discussions forums, part of the The RANGER STATION ~ Rangers and RZRs category; Have a new 2017 Ranger 570 crew EPS and need to find a circuit for the reverse lights and or in my case a back-up ...
Results 1 to 6 of 6
Thread: backup alarm
    Starting Member airwrench's Avatar
    Question backup alarm
    Have a new 2017 Ranger 570 crew EPS and need to find a circuit for the reverse lights and or in my case a back-up alarm. The directions from Polaris do not seem to be correct, as the pin hole in the ECU connector is already occupied. Any ideas how to find the reverse circuit?
    1000+ Member Conquistador73's Avatar
    Mar 2015
    254 times
    Do a search there is quite a few threads on that here. Myself I would just put some cube/pod lights on a rocker switch. Not sure about the alarm. It's the weekend so you might not get many replies until Monday.
    1032 times
    Assuming this machine doesn't have the leads under the bed by the motor coming out of the harness for a reverse alarm?
    The 570's confuse me. There must be 15 different models.
    Unit has no pre-wiring, instal guide has u running a wire into the #45 port in the ECU plug. Problem is there is already a wire there, and I can't see that it is linked to the reverse signal. Am thinking there is a bust from Polaris???
    (Forde) Super Moderator fswan's Avatar
    1852 times
    Quote Originally Posted by airwrench View Post
    Airwrench, take a look at this thread 2015 Ranger 570 LE/EPS Reverse beeper p/n 2880631 ECM pin? there are 'two' pin #45's!
    Always give 100%... except when you donate blood.
    Wow, thanks for the help, never even thought to pull that second plug off, when I talked with the dealer he had indicated that they were # 1-120, dumb me never even thought to check that second plug!!
