Razor will not keep running over 1/4 throttle. - Page 3
This is a discussion on Razor will not keep running over 1/4 throttle. within the RZR 170 Discussions forums, part of the Polaris RZR Forums category; Or seat belt safety? Originally Posted by MikeT Did those units have two different ignition keys, One for adults (no governor) and one for kids ...
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Razor will not keep running over 1/4 throttle.
    RJ is online now
    (Rod) Veteran Member RJ's Avatar
    87 times
    Quote Originally Posted by MikeT View Post
    Did those units have two different ignition keys, One for adults (no governor) and one for kids (with a speed limit governor)? The service manual should be able to help you out with that information.
    If not does it have a way to turn the governor on and off - maybe it's on? Although I would think that this would be the first thing a dealer service dept would look for.
    Mike
    2016 XP900LE Titanium Matte Metallic
    MMA Lift
    28 Zillas
    RVS Stage 1 Tune
    Lock and Ride glass windshield.
    Winch
    Home made mud blockers.
    More to come!
    (beto) Starting Member betocazares's Avatar
    Apr 2016
    alaska
    No. You can bypass the governor to test. That didn't help. I'm getting a fuel pump coming and going to pull the spark arrestor to check for build up. I've read that could be an issue. Those 2 things were never mentioned about being checked by the couple shops I took it too. I'll update on my progress. Going to start on the exhuast while I wait for the fuel pump to get in. Thanks
2012 polaris ranger rzr does not idle
information in razor 170 carborator
polaris razor 170 not running right
polaris rzr 170 carb cleaning
polaris rzr 170 carburetor problems
polaris rzr 170 wont rev up
rzr 170 carb settings
rzr 170 not getting fuel
rzr 170 runs fine then starts bogging
where is fuel filter on polaris razor 170
