Welcome to the PRC Ranger Club forum. A family friendly UTV forum for the Polaris side by side enthusiast. Ranger, RZR, HD, 170, RZR-S, Can-Am off-road Information.
PRC Polaris Ranger Club LLC Forum Index PRC Polaris Ranger Club LLC
A "family friendly" Polaris Ranger - RZR Forum
 FAQFAQ   SearchSearch   MemberlistMemberlist    UsergroupsUsergroups   ProfileProfile   RegisterRegister   Log in to check your private messagesLog in to check your private messages  Log inLog in
RZR Airbox Trouble Issues List
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Post new topic   Reply to topic    PRC Polaris Ranger Club LLC Forum Index -> Ranger RZR Discussions
View previous topic :: View next topic
Author Message
Sandblaster
1000+ Member
PostPosted: Sat Sep 20, 2008 10:52 am    Post subject: Reply with quote
Sandblaster wrote:
Quote:
I just got the word back from Polaris and they will only replace my top end.
Hear your anger and frustration. Buddy had same issue, the top end rebuild did the job for them. My lower end was shot as well and the engine was replaced.
_________________
Sandblaster
http://oohva.org
Back to top
View user's profile Send private message Send e-mail
Sandblaster
1000+ Member
PostPosted: Sat Sep 20, 2008 10:54 am    Post subject: Reply with quote
Quote:
I'm sure you meant "lower"... right?
Yep. Just one letter off. Laughing Should have proofed it one ore time. Laughing
_________________
Sandblaster
http://oohva.org
Back to top
madinidaho
Starting Member
PostPosted: Sat Sep 20, 2008 5:49 pm    Post subject: Reply with quote
Sandblaster
[Hear your anger and frustration. Buddy had same issue, the top end rebuild did the job for them. My lover end was shot as well and the engine was replaced.]
Who replaced your engine? Did Polaris and if so, how did you go about getting it done?[/quote]
_________________
Pictures of 2008 Polaris RZR air intake problems
http://s371.photobucket.com/albums/oo158/madinidaho/?action=view&current=Dirtyfilter.jpg
http://s371.photobucket.com/albums/oo158/madinidaho/?action=view&current=Lookatdirtringinsideoffilter.jpg
http://s371.photobucket.com/albums/oo158/madinidaho/?action=view&current=Intakeafterremovingfilter.jpg
http://s371.photobucket.com/albums/oo158/madinidaho/?action=view&current=VideoofOEMoildrainedoutof2008Polari.flv
http://s371.photobucket.com/albums/oo158/madinidaho/?action=view&current=CleanedthebestIcould.jpg
Back to top
Sandblaster
1000+ Member
PostPosted: Sat Sep 20, 2008 11:04 pm    Post subject: Reply with quote
It was done under the free extended warranty Polaris gave the first several hundred RZR buyer's. The oil turned black and was very full of metal. The metal went through everything. There was noting that would not have needed replaced in the bottom end. One cylinder had a nice groove. The whole engine was shot. It was not a matter of just the rings being worn and using oil. The rings on my buddies were razor sharp, his comment, his lower end was not torn up like mine.
I really do understand your concern. The amount of dirt in the bottom of the jug could have done lots of damage to the crank and bearings, oil pump, lifters, cam, etc. The dealer needs to do a complete tear down and inspection all of the lower end. At least they need to pull the lifters out and inspect the bottom of them. That will give a great indication as to how much or little wear the lower end has had. Then look at the cam lobes also. Those are two very high pressure wear points and will show damage quickly.
From what I have learned, it REALLY is up to the dealer going to bat and making it happen for you. IF your dealer will give you a real person to talk to in Polaris to state your case and have that person look at your video. Warranty work such as this, is the real test that separates the great dealers from all the rest. The way Polaris gets around this is to claim the air filter has to be cleaned every 25 minutes in flower type dust and if not, it is the owner's lack of maintenance who is at fault.
The extended warranty company sent an underwriter to the dealer to take pictures and make a written report. The engine was so bad a blind man could have seen there was only one option.
With my new engine, I have spent many, many hours and between $1000 to $1500 hard money trying to stop the very fine dust from getting in the engine. Have not had total success, but the new engine has 185 to 190 compression as of Thursday. After every ride it eats dust, the oil and filter is changed. Along with another intake refinement.
Anyone what to know of a really GREAT dealer in Oregon, just ask me.
Still hoping before the end of this month we will have some resolution to this major problem. Of course, if they wait and time it just right, the dusty season will be over for the year and they can give us all a 6 month extended warranty and it will be expired before the next dusty season arrives.
I know, I'm such as optimist. Smile
Oops! Noticed what topic this is under. Probably not the correct one for this discussion. I would have no concerns if those in charge deem it best to relocate this discussion.
_________________
Sandblaster
http://oohva.org
Back to top
madinidaho
Starting Member
PostPosted: Sat Sep 20, 2008 11:42 pm    Post subject: Reply with quote
Confused Sandblaster thanks for the reply again. I appreciate it. Unfortunately I did not get the extended warranty when I purchased the product. I have always had Honda's and you just ride them. Sure I did my maintenance always before it was due and kept a fresh clean filter pre-oiled and ready for use when needed. The only time I would take the Honda in was when there was some type of recall. This is my first Polaris and my past history of my maintenance and the product itself did not dictate the need for an extended warranty. I really hope this all turns out well in the end.
Don't take this the wrong way but I like the product and if I would have known of the issue to begin with I would have waited until the mfg fixed it correctly or I would have started diffently. Unfortunately the damage is already done and I have to go on from here.
If I trade it in I will expect to take it in the shorts where it is 6 months old with 500 miles on it. If I sell it outright I would feel obligated to tell the new owner of the potential problems.
I've seen enough modifications online to work with the dust issue but spending a ton of money on something that already may have engine problems doesn't work well for me. I will keep you posted on how this turns out.
_________________
Back to top
87youngblood
Regular Member
PostPosted: Sun Sep 21, 2008 10:25 am    Post subject: Reply with quote
Built 04/05/07 745 miles 110 hrs not using oil yet changed oil yesterday and had some dirt in oil I have seviced filter after every ride since new now I guess I will be changing oil more often as well this is my 4th oil change I had dealer do service bulletin on airbox then I went behind them and sealed everything they missed installed holz intake and access panel retainer will be shopping for new airbox next have already spent about $300.00 in air filters so far.
_________________
08 RZR born on 04/05/07 Polaris prerunner bumpers F&R rockslider nerf bars L&R cab glass shield&wiper kicker stereo glove&overhead bags rangerware heater bruiser wheels w/kenda bounty hunters highlifter springs 3" super atv lift & 2" wheel spacers gorilla axles holz intake grill hpd pipe powercommander S fender flares thunderhawk shock tower brace & heatshield tcp 2" rec. hitch aluminum products a arm guards halogen rally lights odyssey batt heated seat 4 the wife
Back to top
NATHAN
Veteran Member
PostPosted: Tue Sep 23, 2008 6:50 pm    Post subject: Reply with quote
already posted about my problem on this topic but it whent from bad to worse this wekend rode 53 miles in simi dusty condetion and it the motor started pecking about 25 miles in and it was very low on power got it home and there was no oil on the dipstick air box full of dust of course again.called my dealer today they said they did not no anything about any recall so i called polaris and they said i need to call my dealer just going in circles.have 1000 miles on the rzr cleaned filter & changed oil after every ride and of course no warenty! so i am going to leet my local mechanic fix the motor tired of wating on polaris i bought this machine to ride and if i wait on polaris to fix the problem i will never get to ride.after i get it fixed i quees i will have to whait tell it rains again to go riding though and that has not happend in a long time around here.polaris you need to do somthing about this you have had plenty of time personly iam tired of this crap it is not right to have a machine with only 1000 miles on it ready to be rebuilt!so do somthing before you all go bank rupt because i am going to tell everybody i ride with what a crapy service you have .
_________________
SCOTT STORIE
Back to top
matthewc66
Starting Member
PostPosted: Tue Sep 23, 2008 7:56 pm    Post subject: Reply with quote
I called my dealer yesterday and they said the fix happened months ago and I already had it.
I explained the situation and he asked around the shop and no one knew a thing.
My questions is why would Polaris go on this site, make claims about a letter, a fix, etc and not clue in their dealers to what they are doing.
Also, you would think that the people that sell and service these machines would lurk on these websites once in a while just to see what people are talking about.
Still waiting for word back from dealer. He said he would investigate which I assume means call Polaris.
Getting frustrated on this end.
Back to top
striperman
Elite Member
PostPosted: Tue Sep 23, 2008 8:56 pm    Post subject: Reply with quote
I just bought the BTI air box for both of my RZRs, an 08, and a 09 RZR S at $1,100 dollars. I told my dealer I wanted the new bellows boot for them. He called Polaris and they told him I could buy them along with the new filter if I wanted to, but they were not providing them for free. I went ahead and bought the boots at $25, as I did not want to wait any longer for them. I am more than a little disappointed in Polaris, and I think they are blowing smoke to the PRC admin people. I have bought 3 RZRs in the last 18 months and expected a little more from Polaris. BTW, my dealer made this call in my presence on speaker phone. So, no B.S. On the part of the dealer.
Keep in mind, my 09 RZR S is less than a month old and did not come with the new improvements.
_________________
Ed 08 RZR. 09 RZR S
I don't suffer from Post Traumatic Stress Disorder...I cause it.
Merced, California. The gateway to Yosemite.
Back to top
Impatient1
Veteran Member
PostPosted: Wed Sep 24, 2008 1:22 am    Post subject: Reply with quote
[Keep in mind, my 09 RZR S is less than a month old and did not come with the new improvements.[/quote]
X2 I have thoroughly inspected my new '09 RZR S and have none of the supposed new fixes. The only thing I have is the third clip on the air box and the closed cell foam in the cab air box. I am not going to change anything on it because I do not want Polaris denying my warranty for after market products. I did buy the extended warranty and I am hoping everything will be ok. I did go for a pretty dusty ride last week and everything seems to be ok and I will keep my fingers crossed that it stays that way. I am very disappointed after all of the talk from Polaris and the pics on the forum and UTVguide.net of all of the imprvements to find out that none of them were on there. I was under the impression from written statements that the S was supposed to have a larger filter and all of the rest of the things that Polaris published. Oh well I guess we will see.
_________________
John
Go BIG Or Go Home!!!!!
Back to top
idahopilgrim
1000+ Member
PostPosted: Wed Sep 24, 2008 9:35 pm    Post subject: Polaris Razor Free Air FIlter Offer Letter Reply with quote
The Polaris Dealers received notice today about the letter that was being sent out by Polaris offering Razor customers the Free Air Filter. The copy that I have is very hard to read but I see where no other parts are offered for the Air Intake/Filter problem.
_________________
Back to top
View user's profile Send private message Send e-mail Visit poster's website
racer3031
Starting Member
PostPosted: Fri Sep 26, 2008 7:48 pm    Post subject: Reply with quote
I also have an '09 without the upgrades what gives POLARIS!!!!!!!!!!!!!!!! Question
Back to top
FRBear
Starting Member
PostPosted: Sat Sep 27, 2008 9:15 am    Post subject: Polaris Letter Reply with quote
Here is a link to the letter to Polaris dealers. It tells about the extended warranty. On the 2nd page is the URL to sign up for your free filter upgrade. You do not need to wait for your letter. I signed up for mine last night.
Dealer letter:
https://www.polarisdealers.com/files...r%20Update.pdf
Sorry. I just tried the dealer link and it said it was not available at this time. I would keep trying since it worked last night. Maybe too many people signing up.
This is the sign up site:
www.polarisindustries.com/rzrairfilter
_________________
2008 RZR
2007 Sportsman 500 X2
Back to top
hallrzr05
Starting Member
PostPosted: Sun Oct 05, 2008 8:58 pm    Post subject: Is this air intke related Reply with quote
I have posted complain's about rzr air box before. Bought in sept 07 riddin about 96 hrs. Now a NEW problems is accurring machine idle's at about 800 . First notice's about two weeks ago while at winrock. I figure it's the t-bap sensor. Has anyone else had this problem? Would air box dust be the problem? My budddies started doing the same thing yesterday while riding winrock. I love this machine but i just want to be able to ride without having problem. COME ON POLARIS FIX THIS DAMN AIR BOX PROBLEM..........
_________________
steven hall
maryville,tn
Back to top
wa5pho
Starting Member
PostPosted: Tue Oct 07, 2008 11:56 pm    Post subject: Excessive oil consumption - no help from dealer Reply with quote
My Rzr purchased new Oct 07 was in to the local dealer twice during the warranty for rough running, twice they cleaned out the throttle body (documented by mechanics). Compression was never checked and I was not smart enough to ask for this to be done.
Shortly after warranty expired I asked for compression check as I was burning 10 oz of oil every 100 miles. Dealer said it was at "125" and needed rings. It has been 2 months since I asked them to contact Polaris on my behalf for at least some help in footing part (or all of the bill). Dealer claims "they are working on it".
I am disappointed by the lack of backup. I love the design concept of my Razor, but I will never buy another Polaris product. I suppose I will find a local independent mechanic, have rings replaced, pay the bill and move on. No more Polaris for me.
Back to top
Display posts from previous:
Post new topic   Reply to topic    PRC Polaris Ranger Club LLC Forum Index -> Ranger RZR Discussions All times are GMT - 4 Hours
Page 7 of 8
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Website Design & Hosting provided by Silverton Software
