| View previous topic :: View next topic |
| Author |
Message |
deanrowski Regular Member
Joined: 01 Feb 2008 Posts: 72 Location: Grand junction, colo.
Posted: Mon Sep 01, 2008 12:14 pm Post subject: RZR voltage regulator |
Here's a pic of my voltage regulator! I was riding this spring and all of a sudden I smelled something burning, The worst kind of course! ELECTRICAL!! I Inspected every piece of wiring on my RZR and found nothing!! Everything seemed to be working ok other than my battery icon would come on every once in a while and when I went into diagnostic mode on my display it showed 11.0v to 11.8!! This was with no accessories on! Well since you cannot be in diag. mode while driving I purchased an inexpensive volt/battery tester at wallyworld so I could actually see what was happening! To my surprise It was registering from 17.8v to 11.0v!! So I kind of pinpionted the prob. to my regulator which had a small bulge on the backside. When I peeled the sealant off this is what I found!! I have installed a new regulator and cooling fan on it and now it stays between 12.6-13.9 all the time!! I am running an optima batt. also. So far so good!! [im g][/i mg] _________________ Dr.RZR |
| Back to top |
Posted: Mon Sep 01, 2008 12:48 pm Post subject: |
PS- I know that this mounting technique for the cooling fan is not approved for use by prc members!! Just in the testing stages to see if it would help!! Also I must be able to remove it for washing! You may also see my patented Dust Deletion Tape Or DDT for short!! that I use to block some of the gaping chasms left behind by POPO!!! _________________ Dr.RZR |
| Back to top |
ElecTech Assistant Administrator
Joined: 04 Dec 2004 Posts: 18583 Name: Bruce Location: North Carolina
Posted: Mon Sep 01, 2008 12:56 pm Post subject: |
On the new '09 RZR's, they moved the regulator to a spot out front for cooling air to flow over it. I think someone has posted also that the wiring is too small running between this unit and the battery. A fan though would do the trick. _________________ Bruce
Member #2
'05 4X4 Ranger
Rangerware accessories
1 Peter 5:7 Casting all your care on HIM for HE careth for you. |
| Back to top |
rzrcrzy Regular Member
Joined: 27 Feb 2008 Posts: 145 Name: Corey Location: Canada
Posted: Mon Sep 01, 2008 1:01 pm Post subject: |
That gaping hole you taped off was to cool the regulator, or did you do that after the regulator cooked up. _________________ 2008 RZR 05-21-08
2010 Dodge Ram 1500 Hemi
1999 RMK 600
1987 Yamaha Warrior |
| Back to top |
Posted: Mon Sep 01, 2008 1:06 pm Post subject: |
I know you are exactly right!! I taped it up before it burned up but It was 42 degrees when that happend!! Still could have and probably was a contributing factor!! This was all done pre DFR Cyclone when all I was worried about was STOPPING as much dust as possible!!! _________________ Dr.RZR |
| Back to top |
martymoe 1000+ Member
Joined: 10 May 2007 Posts: 2320 Name: Marty Location: Texas
Posted: Mon Sep 01, 2008 10:54 pm Post subject: |
as we were talking about earlier, the reason the fan makes it work is because the voltage regulator gets hot and shuts down.. the stator makes plenty of power, but the voltage regulator doesnt get enough air..
i noticed on the 09's that they moved the voltage regulator up front (in front of the radiator) that seemed like a good solution so i moved mine up there.. that is the fix.. i took it to the dunes over the weekend, and i'm able to run 4x4, all my top lights, my headlights, my backup lights, stereo and gps at the same time (while moving) and the voltage was at 13.8 and building..
i had 0 problems with the flashy low battery dash or even problems engaging 4wd like i did before.. this is the fix..
another weakness in this was that the stock harness's wire from the regulator is too light and gets hot.. i was dropping more than a volt from the regulator to the battery
in the next few days i will write up the steps to move it.. i would have done it sooner but i wanted to test it on this dune trip.. i did and i'm happy. _________________ www.extremerzr.com
08 Titanium RZR (mē Edition)..
martymoe@martymoe.info
| Back to top |
guy48065 PRC Sponsor
Joined: 13 May 2007 Posts: 2235 Name: Mark Location: S.E. MI
Posted: Tue Sep 02, 2008 12:36 pm Post subject: |
Looking forward to it Marty. Good to have guys like you around  _________________ Romeo, MI
http://tinyurl.com/8ltm8
Now a 2-Rzr family!
| Back to top |
agentzoey Veteran Member
Joined: 18 Apr 2008 Posts: 237 Location: Ontario, Canada
Posted: Tue Sep 02, 2008 4:04 pm Post subject: |
| guy48065 wrote: | Looking forward to it Marty. Good to have guys like you around  |
Yes sounds great. I can't wait to read it. _________________ 2008 Polaris RZR - Gen 1. |
| Back to top |
new8812 Veteran Member
Joined: 14 Feb 2008 Posts: 233 Name: Pierre+(Pete) Location: Qc, Canada
Posted: Tue Sep 02, 2008 10:33 pm Post subject: |
Me too, thanks in advance  _________________ 4500km of pure fun! |
| Back to top |
| Back to top |
Posted: Wed Sep 03, 2008 5:51 pm Post subject: |
| Back to top |
bagman Elite Member
Joined: 21 Jun 2007 Posts: 581 Name: YourFirstName Location: SoCal
Posted: Sat Sep 06, 2008 9:49 pm Post subject: |
Deanrowski, you gave me an idea. Along the same lines just mounted different. Should help provide extra cooling.
| Back to top |
RGERBER Elite Member
Joined: 21 May 2007 Posts: 855 Location: SANGER, CALIFORNIA
Posted: Sun Sep 07, 2008 10:59 am Post subject: |
I wish someone would make up a harness and set of instructions with pictures and sell them. _________________ Polaris RZR - build date - 6-15-2007 - Black ITP True Beadlock Wheels with Polished Rings.26"- 6x9x14 front, 6x11x14 Maxxis Bighorn Tires rear, 1.5 adapters - total width in rear of 63" - Gibson exhaust, Factory UTV skid plate,W.E. Shocks, 2" lift, Holtz front bumper, Polaris flares. AEM gauges, HID headlights,
Overcome, Adapt, and Attack. |
| Back to top |
Sandblaster 1000+ Member
Joined: 21 Jun 2007 Posts: 1282 Name: Leonard Location: Eugene, Oregon
Posted: Sun Sep 07, 2008 11:09 am Post subject: |
| Quote: | | I wish someone would make up a harness and set of instructions with pictures and sell them. |
I wish Polaris would, but it might be easier asking a cow to fly. Wouldn't it be nice to have a harness with the ends that just plug into the present harness. The bracket can be purchased for a couple of bucks. The whole thing would cost less then $20 or $30.
There are several updates and changes from Gen 1 to the 09'. ECU and coil update part number. Those two are expensive. All the plastic changes, regulator changes, inside transmission changes, makes it shift easier. Air intake changes. What else? _________________ Sandblaster
http://oohva.org |
| Back to top |
Posted: Sun Sep 07, 2008 11:24 am Post subject: |
Yea, that make us the ginnie pigs _________________ Polaris RZR - build date - 6-15-2007 - Black ITP True Beadlock Wheels with Polished Rings.26"- 6x9x14 front, 6x11x14 Maxxis Bighorn Tires rear, 1.5 adapters - total width in rear of 63" - Gibson exhaust, Factory UTV skid plate,W.E. Shocks, 2" lift, Holtz front bumper, Polaris flares. AEM gauges, HID headlights,
| Back to top |
