Welcome to the PRC Ranger Club forum. A family friendly UTV forum for the Polaris side by side enthusiast. Ranger, RZR, HD, 170, RZR-S off-road Information.
PRC Polaris Ranger Club Forum Index PRC Polaris Ranger Club
A "family friendly" Polaris Ranger - RZR Forum
 FAQFAQ   SearchSearch   MemberlistMemberlist    UsergroupsUsergroups   ProfileProfile   RegisterRegister   Log in to check your private messagesLog in to check your private messages  Log inLog in
RZRS voltage regulator VS RZR 08
Goto page 1, 2, 3, 4, 5  Next
Post new topic   Reply to topic    PRC Polaris Ranger Club Forum Index -> Ranger RZR Discussions
View previous topic :: View next topic
Author Message
Adam12
1000+ Member
PostPosted: Mon Nov 03, 2008 7:50 pm    Post subject: RZRS voltage regulator VS RZR 08 Reply with quote
Im having issues with my regulator notice RZRS has a different part number wondering if any one has changed there older one for a new. Dont now if its different inside or just a different part number due to its mounted on the front now.
_________________
Gibson, MPI controller, power commander, pistons, cam, porting, Long Travel Industries Long Travel and cage, HID all around, wide band O2,ect,ect, ect....
Fly low avoid the radar !!!
Back to top
View user's profile Send private message Send e-mail
striperman
Elite Member
PostPosted: Mon Nov 03, 2008 9:44 pm    Post subject: Reply with quote
Probably a different part number for the different length of the wiring harness.
_________________
Ed 08 RZR. 09 RZR S
I don't suffer from Post Traumatic Stress Disorder...I cause it.
Merced, California. The gateway to Yosemite.
Back to top
Johnpeq
Veteran Member
PostPosted: Mon Nov 03, 2008 11:06 pm    Post subject: Reply with quote
this would be interesting to know for I was planning on checking with my dealer while I was up in Utah for the bracket SKU # in hopes of getting the bracket to reposition the regulator to the 09 spot. I was hoping that the regulator would be the same and I would just need the bracket. What do you think guys?
John
Back to top
Sandblaster
1000+ Member
PostPosted: Mon Nov 03, 2008 11:42 pm    Post subject: Reply with quote
All you need is the bracket, wiring and time.
_________________
Sandblaster
http://oohva.org
Back to top
Adam12
1000+ Member
PostPosted: Tue Nov 04, 2008 3:15 am    Post subject: vr Reply with quote
I dont mind spending the $$ if the 09 is been reworked to be better not just longer wires.
_________________
Back to top
new8812
Veteran Member
PostPosted: Tue Nov 04, 2008 3:41 am    Post subject: Reply with quote
I got the bracket, it's # 5252587 and it's 2,25$. 5,00$ with the screws.
Not installed yet but just by looking, seem to fit. if not, new holes will appear Wink
_________________
4500km of pure fun!
Back to top
Johnpeq
Veteran Member
PostPosted: Tue Nov 04, 2008 12:49 pm    Post subject: Reply with quote
thanks guys, I hope they have an 09 that I can look at and order the bracket,
John
Back to top
cisco kid
1000+ Member
PostPosted: Tue Nov 04, 2008 12:56 pm    Post subject: Reply with quote
Adam12
Have you move your REG to the front, I did and it works awesome Wink
_________________
Frank
Thousand Palms, CA
07' 700XP
08' 800RZR
Back to top
Sandblaster
1000+ Member
PostPosted: Tue Nov 04, 2008 12:57 pm    Post subject: Reply with quote
The bracket comes with protrusions at the mounting holes. I found the easy way was to grind the bracket flat, position and drill 1/4" holes. Used bolts with lock nuts to mount. To make the bracket work otherwise seemed to require drilling and mounting from the radiator side. So much simpler to make the bracket flat and drill from the front of the RZR. Also take off the front grill plastic the lights mount in.
_________________
Sandblaster
http://oohva.org
Back to top
Johnpeq
Veteran Member
PostPosted: Tue Nov 04, 2008 1:04 pm    Post subject: Reply with quote
Thanks Sandblaster, was it you that had the installation notes somewhere on the forms as to wires and routing?
I plan on doing the move this winter when I can't get on the dunes,
John
Back to top
Sandblaster
1000+ Member
PostPosted: Tue Nov 04, 2008 1:18 pm    Post subject: Reply with quote
Wasn't me. Forgot who it was for sure. I did things different then he stated. If I was doing it again, I would simple use the same size and color of wire and extend the harness. The length given, 5' I think, was not enough for me. Short by about 18" or so. I would make the extension plenty long, easier to cut off then to add a second time. Soldering is good, but I used the blue wire crimps on the OEM mounting area. Hard to get to otherwise with the short wires. Again, use the same size, not larger wires. The larger wires are overkill, look at 09', and make the job harder. If using crimps, after crimping, pull firmly on the connections to make sure it is crimped correctly. Better to find a weak crimp now then wonder why things are not working. Have used crimps for many years in many application without issue. The only problem is bad crimps to start with, use the pull test to avoid that issue. Also wrap all connections real will with good black tape. That keeps the water out. Tape is cheap, use generously.
_________________
Sandblaster
http://oohva.org
Back to top
Johnpeq
Veteran Member
PostPosted: Tue Nov 04, 2008 1:42 pm    Post subject: Reply with quote
I would add that seal with RTV. I'm down by the ocean most rides and I'm amazed @ where the corrosion occurs, When I'm down for this maintance I'm going to go all over this ride to seal and paint,
John
Back to top
Sandblaster
1000+ Member
PostPosted: Tue Nov 04, 2008 2:06 pm    Post subject: Reply with quote
Yep! Been there. What I found worked the best is lots and lots of fresh water as soon as possible to wash off the salt. Rode sport quads for years in the sand. Lots of water and good chain lube, for them, had very little problems with corrosion. Did have some in wiring connectors after years. Learned to pull, clean and lube at the first sign of problems. But the sand fun was sure worth it.
_________________
Sandblaster
http://oohva.org
Back to top
Adam12
1000+ Member
PostPosted: Tue Nov 04, 2008 2:47 pm    Post subject: Reply with quote
Instead of remounting it why not just put a computer fan on it......
_________________
Back to top
Johnpeq
Veteran Member
PostPosted: Tue Nov 04, 2008 3:32 pm    Post subject: Reply with quote
Have you seen where it is? I don't think a fan would last more than a day or two. Also thats just another load that the system that is already under powered would have to power.
If Polaris feels that the regulator needs more room to breath (the 09) than that's good enough for me.
I have one of those Walmart voltage monitors that plug into the plug on the dash and you would be amazed how the voltage falls when you turn on your lights.
John
Back to top
Display posts from previous:
Post new topic   Reply to topic    PRC Polaris Ranger Club Forum Index -> Ranger RZR Discussions All times are GMT - 4 Hours
Page 1 of 5
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Website Design & Hosting provided by Silverton Software
