PRC Ranger Club forum A family friendly UTV forum for the Polaris side by side enthusiast, 2013 models, Ranger XP 900. The Polaris Ranger RZR XP 4 900 Forum on www.prcforum.com , 2013 Rangers, RZR,570, HD, 170, RZR-S, xp 900, rzr xp 4 900, crew, orv,side x side, SSW, off-road Information.
PRC Polaris Ranger Club LLC Forum Index PRC Polaris Ranger Club LLC
© 2013 PRC Ranger Club, LLC. All Rights Reserved
 FAQFAQ   SearchSearch   MemberlistMemberlist    UsergroupsUsergroups   ProfileProfile   RegisterRegister   Log in to check your private messagesLog in to check your private messages  Log inLog in
400 Starting Problems or just me?
Post new topic   Reply to topic    PRC Polaris Ranger Club LLC Forum Index -> Mid-Size Rangers
View previous topic :: View next topic
Author Message
SoonerWil
Starting Member
PostPosted: Sun Sep 18, 2011 4:25 pm    Post subject: 400 Starting Problems or just me? Reply with quote
Hi my new 400 has difficulties starting sometimes. On rare occasions when it has been setting 7 cranks for it to finally get going. It's only a week old I am making the assumption that the battery was sitting around the dealer for a while and that it is the source of my woes. Also, any tips on starting these things I know you go from start to battery but how long should it take to finally turn over. Appreciate any and all comments.
_________________
SoonerWiL
2011 Polaris Ranger 400 Camo
O-K-L-A-H-O-M-A
Our chant rolls on and on! Thousands strong Join heart and song In Alma maters praise.
Of campus beautiful by day and night.
Of colors proudly gleaming Red and White
'Neath a western sky" OU's chant will never die.
Live on University!
Back to top
View user's profile Send private message
doug63
Veteran Member
PostPosted: Sun Sep 18, 2011 5:50 pm    Post subject: Reply with quote
when it is cold use some choke. let the fuel pump run 2 or 3 seconds to get fuel to the carb. when you crank give it 1/2 throttle. when it is warm out or the eng is warm don't use choke but DO give it 1/2 throttle. If it was your battery you woulden't be able to crank it 7 times. doug
Back to top
jokout
Elite Member
PostPosted: Sun Sep 18, 2011 6:34 pm    Post subject: Reply with quote
First off, I am assuming you have the carbed 400 HO. Normally the cold starting is VERY good, but this has been a bit of an issue with the carbed 400 when the engine is warm. Some say it is a slight jetting issue and others seem to think it is caused by the long restricive intake setup! Since the wifeys Sportsman 400 HO has the same engine and starts flawlessly in all temps, warm or cold, the intake seems to make sense to me.
The 400 runs so good other then this that most just give it a little gas when cranking the warm engine and don't worry about it, but if you are having this much problem with a new machine, I would definately take it back to the dealer so they can make it right!
Keep us up to date!
Cheers!
_________________
2011 Ranger 400 HO w/2" lift & Rhino axles
Polaris roof, two-piece folding windshield, back panel, 1/2 windshield, custom box rack, custom snorkle system, RZR bucket seats, custom center console, Viper Max 4500# winch, relocated deep cycle battery, LED cab lite, Pioneer stereo, ITP 212 rims and Swamplite tires, clutch spacer mod, Blazer Flood lites, 66" American Eagle snowplow
Back to top
SoonerWil
Starting Member
PostPosted: Sun Sep 18, 2011 7:31 pm    Post subject: Reply with quote
Ok thanks for all the help. I'll try working the pedal a bit I just was a little concerned as I am in the infancy stage of the vehicle.
_________________
SoonerWiL
O-K-L-A-H-O-M-A
Live on University!
Back to top
1400HO
Regular Member
PostPosted: Mon Sep 19, 2011 9:23 am    Post subject: Reply with quote
I've only had mine for about a week so might not be much help. I haven't figured out the proper start procedure either. I usually just give it a little gas while starting, maybe 1/8th throttle, but that doesn't work every time. I'm moving from a '95 400 2 stroke so I understand some machines just have a specific way they like to start.
Edit; Just thought I would update...if I turn the key to On for about 5 secs until the fuel pump stops, it starts quickly with no throttle input, cold or hot.
Back to top
jokout
Elite Member
PostPosted: Tue Sep 27, 2011 4:20 pm    Post subject: Reply with quote
may have stumbled on to something here recently...I have had this starting issue for some time now and it seemed to improve some when i installed my snorkle setup, but i would still experience somewhat prolonged cranking when hot and recently a bit harder starting initially! I even experienced the Ranger dieing unexpectedly on the trail a couple times! It always restarted and never stranded me, but just a bit annoying! I had also been running into the battery being dead a couple times when it sat for a while...I had come to the conclusion that i had a minor dead short some where in the electical accessories I had installed and was in the process of tracking it down when i determined that the actual problem was the deep cycle replacement battery I was using! Turns out the battery had a dead cell and was only taking a partial charge at best!
After replacing the battery I am AMAZED at how much better this thing starts!!! It pops off IMMEDIATELY!
If your having to crank a while, you may want to check your battery, it sure fixed my problem!
best part is the battery was under full warrenty so it was a free fix!!!
Cheers
_________________
Back to top
trafdeputy
Starting Member
PostPosted: Fri Sep 30, 2011 9:34 am    Post subject: 400 Starting Problems or just me? Reply with quote
I had same issues so my local polaris mechanic simply told me to turn the key on, pump the pedal a few times and it should crank. Voila', that was it. Cranks every time.
Back to top
View user's profile Send private message Send e-mail
camoranger400
Veteran Member
PostPosted: Sat Oct 01, 2011 6:49 am    Post subject: Reply with quote
I turned my idle up, I don't have a tach so I can't tell what it is idling at but I do know it now starts up without choke or throttle when cold.
When it has warmed up I give it a little throttle and it works perfectly, I also installed a bigger battery I bought from tractor supply that I mounted under the hood to give it a much better cranking power, works sweet and only cost me 35 bucks on sale of course. Smile
Back to top
Ron Dodds
Starting Member
PostPosted: Sat Oct 01, 2011 6:58 pm    Post subject: Reply with quote
I install a vapor dash in mine and love it RPM, temp, distance,and speed all in one there are pics i posted in test area if you want to check them out.
Ron
Back to top
Display posts from previous:
Post new topic   Reply to topic    PRC Polaris Ranger Club LLC Forum Index -> Mid-Size Rangers All times are GMT - 5 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Website Design & Hosting provided by Silverton Software
