PRC Ranger Club forum A family friendly UTV forum for the Polaris side by side enthusiast, 2013 models, Ranger XP 900. The Polaris Ranger RZR XP 4 900 Forum on www.prcforum.com , 2013 Rangers, RZR,570, HD, 170, RZR-S, xp 900, rzr xp 4 900, crew, orv,side x side, SSW, off-road Information.
PRC Polaris Ranger Club LLC © 2013 PRC Ranger Club, LLC. All Rights Reserved
| View previous topic :: View next topic |
| Author |
Message |
biggurn Elite Member
Joined: 10 Jun 2010 Posts: 690 Name: R. Location: out west-
Posted: Wed Mar 14, 2012 10:04 am Post subject: Namura Piston Kits... got the Ranger up and running again. |
Well I finally had time to finish off the engine rebuild on my Ranger. After the disaster with clutch kit I bought via a sponsor (primary weights too heavy= too many engine RPMs, ruined seals in the head and piston rings) anyhow, I rebuilt the head (all new valves, seals, recut seats) and new top end (fresh bore with a namura piston .40 over (92.50 mm))... well with the correct primary clutching (clutching by ME) and the team roller 2ndary from the sponsor, the Ranger is a MONSTER! I can spin all four tires and power is instant. I still need to build the new rear seating but we are excited to get it back on the trail ASAP. For those needing to rebuild the top end, I highly recommend the Namura piston kits, they are advertised to come with a complete top end gasket set (they don't, you only get a head, base, and exhaust gasket) but for the price and performance they are amazing! (a whole kit is less than an OEM piston alone, and even less money than a Pro-x piston and WAY less than a seizco kit) However, FYI, Namura does not show a kit to fit the series 10/11 and ’05 and newer Rangers with the Fuji 500, however because the engine is the same as the sportsman 500s and the ’99 ranger 500s the kit offered for those units is correct. The Namura head gasket is slightly thinner than the OEM multi-plate gasket and so it slightly raises compression. I have used Namura piston kits in several bikes now for a couple of years with great results, infact it is my default piston now (I was previously a PRO-X guy and when no namura is available I still use them). For those who have a 2x4 series 10/11 you may have the 425cc engine and will therefore need the piston kit for the magnum 425 engines. If you have a TM ranger… replace the Robin engine with a B&S and you can thank me later.  _________________ off lurking... |
| Back to top |
POS POLARIS 1000+ Member
Joined: 03 Mar 2009 Posts: 1892 Name: bubba Location: north country
Posted: Wed Mar 14, 2012 1:33 pm Post subject: |
when you want it done right you gotta do it yourself!
Glad you got the beast up and running! _________________ "A superior Operator is best defined as someone who uses his superior
judgement to keep himself out of situations that would require a display of his
superior skills."
-2006 700xp 2300hours /traded/
-2007 700xp 1650hours /traded/
-2012 ranger Diesel TURBO'D / 600 hours/traded/
-2011 ranger XP / 700 hours
-2012 ranger HD / 870 hours
"Fast is fine, but accuracy is final."
Wyatt Earp
| Back to top |
Posted: Wed Mar 14, 2012 1:56 pm Post subject: |
Yeah, ain't that the tuth! Well now that its done I have a ATC 250R that needs rebuilt and I want to build a loader for my tractor... not to mention I have several antique engines to restore, and my wife thinks I take on too much? _________________ off lurking... |
| Back to top |
trackerkelpie Regular Member
Joined: 25 Aug 2010 Posts: 126 Name: David Location: Queensland Australia
Posted: Wed Mar 14, 2012 4:37 pm Post subject: Re: Namura Piston Kits... got the Ranger up and running agai |
| biggurn wrote: | | ... well with the correct primary clutching (clutching by ME) and the team roller 2ndary from the sponsor, the Ranger is a MONSTER! I can spin all four tires and power is instant. |
Thanks for the insight into motor rebuilding. Can you explain the workings and benefit of the team roller secondary please? _________________ 2012 Ranger HD
26.5 Pitt Bull Rockers
Trail Armor Skid
Sport Roof
Trail Armor Cv Guards
SATV Roo Bar
Warn XT 40
Cargo Box
Spal Fan in Engine Bay
Rigid 6" Led Light Bar
DDP Clutch
Ranger HD Review http://fairdinkumkelpie.wordpress.com/atvsxs/polaris-ranger-hdxp/
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
