PRC Ranger Club forum A family friendly UTV forum for the Polaris side by side enthusiast, 2013 models, Ranger XP 900. The Polaris Ranger RZR XP 4 900 Forum on www.prcforum.com , 2013 Rangers, RZR,570, HD, 170, RZR-S, xp 900, rzr xp 4 900, crew, orv,side x side, SSW, off-road Information.
PRC Polaris Ranger Club LLC © 2013 PRC Ranger Club, LLC. All Rights Reserved
| View previous topic :: View next topic |
| Author |
Message |
treed67 Starting Member
Joined: 13 Nov 2012 Posts: 2 Name: Tim Location: Tennessee
Posted: Tue Nov 13, 2012 5:57 pm Post subject: 2006 Polaris Ranger 700 flutter off idle |
| I bought the ranger with a bad ecu. I wasn't firing on one cylinder. I replaced it with a sportsman ecu to fix that. The problem I am having is that its got a flutter around 1200-1500 RPM. It will not accelerate smoothly until above that point. It idles good at low RPM and runs great up above 1500 or so. I have checked the TPS and reset it. I replaced the wires on the TBAP sensor...no change. I actually can't tell any difference running it with that sensor unplugged totally...except it sets off the check engine light. I do have a code 51 and 52, but the injector wires look fine. Do the TBAP's go bad? Any way to test it? Is one off of a 2008 the same? My brother has one that I might rob to try. Please help. I sold a Mule to go to a Ranger for the benefits of fuel injection and it really isn't much better yet. |
| Back to top |
commanderjjones Moderator/Rally Committee
Joined: 29 Dec 2006 Posts: 18229 Name: Jerry Location: Harriman, TN
Posted: Fri Nov 16, 2012 8:42 am Post subject: |
Welcome to PRC, Tim.
You might need to adjust the TPS. Depending on what year Sportsman the ECU came from, it could need to be set at either .660 or .710 volts.
A broken wire to the TPS is another possibility. Mine did exactly what you're describing when it had a broken wire, so check those thoroughly.
It's very rare for the TBAP to fail, although it could be dirty. The 2008 sensor is the same, so try swapping them to see if there's any difference.
Since 51 and 52 are injector codes, I would also verify that you've got good fuel pressure. A weak fuel pump can cause it to show an injector code......and bad fuel pumps are a farily common issue. _________________ Jerry
PRC staff / SSW staff
2012 RZR XP4 LE liquid silver / 2006 Ranger XP LE, midnight red, built 10/25/05 |
| Back to top |
Posted: Mon Nov 19, 2012 9:45 pm Post subject: |
| Ok, I had forgot to mention that I had reset the baseline tps voltage and even adjusted the throttle stop to get the .660 and .710 settings. It seems to idle much better at the .660 voltage. When you adjust it up to around .710, it idles too fast and really approaches the "dead spot" in the throttle. I noticed the other day that if you slowly accelerate while in neutral, it will actually die if you don't go fast enough to get past that point. I'm going to check the tps again to make sure the voltage increases smoothly. I have cleaned the tbap, but it didn't make any difference either. |
| Back to top |
Posted: Tue Nov 20, 2012 8:49 am Post subject: |
Based on the above, it sounds like the TPS might be bad and that's where the dead spot is coming from. _________________ Jerry
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
