Light bar wire routing? - Page 2
This is a discussion on Light bar wire routing? within the Ranger Crew Discussions forums, part of the Polaris Ranger Forums category; My headlight is hooked up to the bus bar. That is the wire that is connected. Unless that is just for grounding purposes?...
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Light bar wire routing?
    Starting Member Bumrush's Avatar
    Mar 2018
    Regular Member 410Customs's Avatar
    North Idaho
    XP1K Northstar crew
    69 times
    The one wire that is already there is switch on power or ACC ON, it should be 12V+ when the key is turned on
    Very nice of Polaris to add this wire since it is easy to run battery + and - but harder to find a good acc on feed
    2018 XP1K Crew Northstar, 2014 XP1K, 2015 XP1K4, 2014 Ace 325, 2004 Sportsman 450ho, 2005 RMK IQ 900 mod sled, Polaris THE WAY OUT
    Mar 2018
    So I can just tap into this power and just have to have the key on? That is what I'm understanding?
    (Josh) Elite Member jobo2856's Avatar
    Aug 2016
    Rayne, Louisiana
    2016 900XP HL
    444 times
    Quote Originally Posted by Bumrush View Post
    No. That power should only be used to run relay / contactors. It will not carry the load of lighting, radio equipment, winches, etc.
    2016 - 900XP EPS Highlifter Edition
    Mar 2018
    Again im sorry I feel really stupid about this as I am no good with electrical. However I did purchase a wiring harness for the light bar that has a relay and inline fuse. Will this still not work on the switched power?
    Starting Member Rockmart ranger's Avatar
    Oct 2017
    7 times
    Looks like you need this part from Polaris if your not to good with electrical. This would be the easiest way to power your bus bar. IMO
    Battery Connection Cable
    Item # 2879685
    $54.99 USD
    2017 Ranger 900XP
    Front 1.5' SuperATV forward A arms
    Rear Highlifter high clearance A arms
    29' Maxxis Bighorns
    Polaris General 14" wheels
    Mar 2018
    Talked to my local dealer's service department and he told me I could use that switched power, he said that's what it is for? Seems reasonable.
    Mar 2018
    Yeah looks like no power there. I think they are using it as a ground for the head light. Ordered the wiring kit, I hope it comes with instructions.
  1. Wire Routing from back to under hood
    By jcas2005 in forum Ranger XP 900 & 570 FS Discussions
    Last Post: 11-09-2016, 12:29 PM
  2. Routing wire from battery to bus bar
    By prov1ml in forum Ranger XP 900 & 570 FS Discussions
    Last Post: 05-02-2016, 10:26 PM
  3. Wire routing
    By TJE81 in forum Ranger Technical
    Last Post: 02-06-2016, 12:45 PM
  4. Wire routing
    By Ragweed in forum General Member Discussions
    Last Post: 04-01-2014, 08:02 PM
  5. Wire routing for work lights
    By Glngib in forum Ranger Technical
    Last Post: 01-19-2014, 02:50 PM
