Front drivetrain noise - Page 2
This is a discussion on Front drivetrain noise within the Ranger XP 900 & 570 FS Discussions forums, part of the Polaris Ranger Forums category; Ask you'r dealer to grease the splines on you'r front axles, these are sometimes totaly dry from the factory and will rattle especialy when the ...
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 56
Like Tree8Likes
Thread: Front drivetrain noise
    (Jim) Elite Member catmanLE's Avatar
    Pa.
    69 times
    Ask you'r dealer to grease the splines on you'r front axles, these are sometimes totaly dry from the factory and will rattle especialy when the front wheels are pulling!!
    Regular Member Exlawdog's Avatar
    I will do that, thanks. I also found an old thread about front propshaft wear at the pinion stub that is quite interesting.
    2017 900xp EPS
    Full cab, w/heat and wipers
    All glass W/tip out front
    All camo
    Hydro dump
    Glacier pro w/ hydro
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    Rear LED in bumper lights
    2" Bracket lift
    28" Attack tires
    Air relocate box
    Dragonfire seat belt bypass
    Custom Bed Rack w/led floods and tool holder
    1500# Winch on Bed Rack
    WhoMoto rock sliders
    More to come
    "I may not be the Boss, but I've got a lot of pull"
    Supporting Member Chemguy's Avatar
    Aug 2015
    AZ
    32 times
    I had the same problem just put it in 4 wheel drive and the noise will stop. I have the metal cage. I don't know if the 17 has the metal cage or the plastic one. Couldn't hurt to try it.
    2015 Ranger Crew 900-6
    Mine rattles all the time. Under power or deceleration.
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
    Z71
    Z71 is offline
    (Mike) Elite Member Z71's Avatar
    U.P. of Michigan
    67 times
    Friend just got a 2017 General (basic 2-seater) in May. He asked me if my front RZR 900 axle makes any noise. Have not heard anything in 1200 miles. Said he took it back to the dealer and they told him nothing is wrong, typical of the bigger SxS's. He thinks they are bs'ing him.
    Mike
    2018 RZR S 900 EPS
    You can't bang steel together without some kind of wear or damage. Just my 2c
    Naylor649 likes this.
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
    (Steve-o) Supporting Member Naylor649's Avatar
    Jul 2015
    Southern Illinois
    225 times
    Quote Originally Posted by Exlawdog View Post
    Unless you have a good lube
    Rangerwhit likes this.
    Union Electrician
    2015 900 XP Sandstone Metallic
    Fixed Glass Windshield
    Lock & Ride Rear Glass
    Lock & Ride Sport Roof
    Polaris Radio
    Polaris Extreme Bumper
    Viper Elite 4000 winch
    12" Light bar
    3" Full Outkast lift
    14" MSA Vibe wheels
    30" Pro Armor Crawler XG
    Dragonfire Doors
    Garage Products Bushings
    Fueled by Busch Light
    (SlimRockett) Elite Member SlimRockett's Avatar
    May 2012
    Waxahachie Texas
    118 times
    My 17 1000 crew on hard pack road rattles like that almost to the point where I slow down and think it's about to lock up but it's been doing it since new my full cab makes it even louder.
    2017 Ranger Crew 1000 Bronze
    That's it. Dealer is putting in new prop shaft soon. Prop shafts are on back order everywhere. I guess that says something.
    We will see what that does for me.
    2017 900xp EPS
    All camo
    Hydro dump
    Super ATV Bumpers
    #6000 Front Winch
    #4000 Rear Winch
    Four Point Strobes
    2" Bracket lift
    28" Attack tires
    Air relocate box
    More to come
    2433 times
    You have the new CV prop shaft in your unit, I seriously doubt that is where your noise is coming from, more than likely it is the stacked loose tolerances of the front gear case causing your noise.
    The prop shafts being on back order, probably has something to do with people wanting to upgrade and get rid of the U joints.
    But the OEM CV prop shaft, in stock form, only fits the 17' 1000/900 standard cab models.
    Will not fit 13' to 16' without mods.
    Toxic-21 Motorsports.
    It Costs a lot of Money to look Cool!
polaris tanger 570 drivetrain noise
